Home » Eclipse Projects » BIRT » Scripted Datasource inside Eclipse RCP application
Scripted Datasource inside Eclipse RCP application [message #366430] Mon, 29 December 2008 11:05
Doménique Tilleuil is currently offline Doménique Tilleuil
I'm trying to run a report inside an RCP application that using a scripted
Datasource.
First of all, this is how my application looks like :
Plugin
|-> /rpt
|--> offerteReport.rptdesign
|->bin
|--> be/dewaal.offertes/report/OfferteFactory.class
When I run the report, I get the following error :
TypeError: [JavaPackage be.dewaal.offertes.report.OfferteFactory] is not a
function, it is org.mozilla.javascript.NativeJavaPackage. (#2). at
org.eclipse.birt.data.engine.core.DataException.wrap(DataExc eption.java:118)
org.eclipse.birt.data.engine.script.ScriptEvalUtil.evaluateJ SAsExpr(ScriptEvalUtil.java:717)
org.eclipse.birt.data.engine.script.JSMethodRunner.runScript (JSMethodRunner.java:76)
org.eclipse.birt.report.engine.script.internal.DtEScriptExec utor.handleJS(DtEScriptExecutor.java:71)...
87 more
This error makes me believe that he can't find the ObjectFactory class in
the classpath of the jetty server instance he started to create the
report.
Below is the code snippet I use to display the report inside an Editor :
public void createPartControl(Composite parent) {
Composite container = new Composite(parent, 0);
container.setLayout(new FillLayout());
Browser browser = new Browser(container, 0);
org.osgi.framework.Bundle bundle = Platform.getBundle("deWaalOffertes");
URL locationUrl = FileLocator.find(bundle, new Path(
"/rpt/offerteReport.rptdesign"), null);
URL fileUrl = null;
try {
fileUrl = FileLocator.toFileURL(locationUrl);
} catch (IOException e1) {
e1.printStackTrace();
WebViewer.startup(browser);
String format = "html";
String preParameters = createURL("frameset", fileUrl.getFile(), format);
String parm1NameString = null;
String parm1ValueString = null;
try {
parm1NameString = URLEncoder.encode("offerteID", "utf-8");
parm1ValueString = URLEncoder.encode("1", "utf-8");
} catch (UnsupportedEncodingException e) {
Activator.logError("Fout tijdens het tonen van het rapport.", e);
String finalUrl = (new StringBuilder(String.valueOf(preParameters)))
.append("&").append(parm1NameString).append("=").append(
parm1ValueString).toString();
browser.setUrl(finalUrl);
I would like to know how I can make the report viewer use the correct
classpath so that it finds my Factory class for creating the reports.
Krgds
Previous Topic:Installing BIRT after DTP - connection profiles lost?
Next Topic:How to add html attribute in BIRT
Current Time: Sun May 19 00:36:48 EDT 2013
Powered by FUDForum. Page generated in 0.02597 seconds
