| How to create new Reposity [message #36625] |
Mon, 10 November 2008 06:40  |
Originally posted by: silver.zachara.gmail.com
I want to ask You how can I create new reposity in Subversive, every
thing is all right and work with Subversive is very simple, but I can't
find how create new reposity, so I have to (must) use TortoiseSVN or svnadmin create
| Re: How to create new Reposity [message #36729 is a reply to message #36695] |
Wed, 12 November 2008 04:38   |
Igor Burilo napsal(a):
> Hello Silver Zachara,
> Subversive is a SVN client and it doesn't support any administration
> operations like creating repository etc. So before working you need to
> create repository using other tools, e.g. TortoiseSVN or svnadmin as you
> wrote.
OK, and plan Subversive support for admin operations ?
| Re: How to create new Reposity [message #37234 is a reply to message #37032] |
Wed, 12 November 2008 13:36   |
> We don't plan any support for admin operations
But I would be very happy if You at least thought about implementing only of a repo creating.
Other admin commands are not so important as command for repo creating, because this
command is used very often.
Where the problem is ?
| Re: How to create new Reposity [message #37570 is a reply to message #37539] |
Thu, 13 November 2008 07:07   |
> If we implement this feature, it would allow to create repositories only
> locally, which is not very useful as most of developers work with
> centralized remote repositories.
you are right ;), but I would be very happy if you implement that, because most off
developers use local svn server for developing project, e.g. I have (as developer) 10
local repos and for every new project I have to create new repo ;)
But if you don't plan implment this, never mind, becuase Subversive is great project also
without this feature, but with this feature would be better ;) :)
| Re: How to create new Reposity [message #37815 is a reply to message #37570] |
Fri, 14 November 2008 03:04   |
Jorrit Schippers Messages: 22 Registered: July 2009 |
Junior Member |
I think that you can create this using the svnadmin tool, the external
tools functionality in Eclipse and the {folder_prompt} macro easily.
Jorrit
| Re: How to create new Reposity [message #37848 is a reply to message #37815] |
Fri, 14 November 2008 04:43  |
Hi, Jorrit Schippers
I did not realize that option, thank you
FUDForum. Page generated in 0.15302 seconds
