Home » Eclipse Projects » BIRT » Memory Usage of Viewer
Memory Usage of Viewer [message #366147] Wed, 03 December 2008 10:17
Assaf  is currently offline Assaf
Hi ,
I integreated the Viewer into my J2EE application and noticed the memory
usage has increased extremly (when runing several apps under Tomcat it
becomes a serious issue).
The integration was done by taking the entire WebViewerExample and copying
its contents into my application :under Web-Inf in my application I added
the entire platform sub directory of the viewer. Under the WEB-INF/LIB I
added the required Jars as well(and other changes to the web.xml etc)
Can I use the shared lib directory in tomcat to reuse the Viewer jars (for
all applications) rather then holding a copy for each app ?
Is there any configuration I can do (perhaps delete several unneeded
jars/folders) that will reduce the memory usage ??
Many Thanks
Previous Topic:Report renders as html but NoClassDefFoundError for PDF
Next Topic:Deploying reports into run time environment with tomcat
Current Time: Thu May 23 00:56:11 EDT 2013
Powered by FUDForum. Page generated in 0.01424 seconds
