Home » Eclipse Projects » BIRT » Cant startup the OSGI framework
Cant startup the OSGI framework [message #365793] Mon, 03 November 2008 14:05
Eclipse User
Originally posted by: cgardner.goodpacket.com
I'm trying to deploy the Birt Runtime using the instructions found at
http://www.eclipse.org/birt/phoenix/deploy/viewerSetup.php. The
application seems to be deployed on Tomcat properly as I am able to get
the verification page. However, when I try to run the example report, I
get a message that says "Cant startup the OSGI framework".
Thanks for your help.
Here's more detailed debugging information:
org.eclipse.birt.core.exception.BirtException: Cant startup the OSGI
framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:91)
org.eclipse.birt.report.service.ReportEngineService.setEngin eContext(ReportEngineService.java:328)
org.eclipse.birt.report.service.BirtViewerReportService.setC ontext(BirtViewerReportService.java:975)
org.eclipse.birt.report.servlet.ViewerServlet.__getContext(V iewerServlet.java:148)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doGet(BirtSoapMessageDispatcherServlet.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service(BirtSoapMessageDispatcherServlet.java:112)
at java.lang.reflect.Method.invoke(libgcj.so.81)
org.apache.catalina.security.SecurityUtil$1.run(SecurityUtil .java:244)
at java.security.AccessController.doPrivileged(libgcj.so.81)
at javax.security.auth.Subject.doAsPrivileged(libgcj.so.81)
org.apache.catalina.security.SecurityUtil.execute(SecurityUt il.java:276)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:162)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:262)
org.apache.catalina.core.ApplicationFilterChain.access$0(App licationFilterChain.java:192)
org.apache.catalina.core.ApplicationFilterChain$1.run(Applic ationFilterChain.java:171)
org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:167)
org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerF ilter.java:68)
org.apache.catalina.security.SecurityUtil.doAsPrivilege(Secu rityUtil.java:218)
org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:210)
org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:213)
org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:172)
org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:117)
org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:108)
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:151)
org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:874)
org.apache.coyote.http11.Http11BaseProtocol$Http11Connection Handler.processConnection(Http11BaseProtocol.java:665)
org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(Poo lTcpEndpoint.java:528)
org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt( LeaderFollowerWorkerThread.java:81)
org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.ru n(ThreadPool.java:689)
at java.lang.Thread.run(libgcj.so.81)
Caused by: org.eclipse.birt.core.exception.BirtException: Can not start
up OSGI - {0}
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:169)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:79)
...43 more
Previous Topic:Load Balancing (BIRT_VIEWER_WORKING_FOLDER)
Next Topic:Functions in beforeFactory not available in JBOSS
Current Time: Sun May 19 20:33:22 EDT 2013
Powered by FUDForum. Page generated in 0.07308 seconds
