Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » context sensitive help will not work allways.
context sensitive help will not work allways. [message #36281] Wed, 18 March 2009 03:58 Go to next message
Gunter Pfeiffer is currently offline Gunter Pfeiffer
Some of my function will not displayed in an hover when i move the courser
on it.
And this is at the same time when will work correct for other functions
from the same library.
Normally this should not possible unless there is a list of not allowed
words or something like this.
Any idea ??
best regards
Gunter
Re: context sensitive help will not work allways. [message #36347 is a reply to message #36281] Thu, 19 March 2009 06:44 Go to previous messageGo to next message
Alex Panchenko is currently offline Alex Panchenko
Hi Gunter,
Probably in some cases DLTK is not able to detect the reference to your
functions, e.g. if the function call is deeply nested inside curly
braces, etc.
If you could provide simple examples I can check what exactly happens.
Alex
> courser on it.
> Any idea ??
> best regards Gunter
Re: context sensitive help will not work allways. [message #36376 is a reply to message #36347] Thu, 19 March 2009 10:04 Go to previous messageGo to next message
Hello Alex,
at the Moment i had no simple example.
But an example:
for { set num 1000 } { $num <= 10000 } { incr num 1000 } {
if { [CheckBreak] } {break}
TlPrint ""
TlPrint "activate Gear, Immediate synchronisation, factor =
$num:$denom"
if { ![pdoActivateMode $mode $action $denom $num] } { break }
doWaitMs 500
pdoCheckMotionStatBit $AW_NACT_P 1
pdoCheckDriveStatBit $PDO_DSTAT_X_ERR 0
pdoCheckDriveStatBit $PDO_DSTAT_X_END 0
set sollSpeed [expr round( ($WagoSpeed * 60.0 / $INC_PRO_1U) *
($num/$denom) )]
checkNAct $sollSpeed [expr abs(round($sollSpeed*0.02))] ;# +2% Tol
checkNPRef $sollSpeed [expr abs(round($sollSpeed*0.02))] ;# +2% Tol
} ;# for
The definition of "pdoActivateMode" is not found.
But the definition off :
is found. And all procs are in the same file.
Hope this will help.
If not please call for more infos.
Gunter
Re: context sensitive help will not work allways. [message #36516 is a reply to message #36376] Thu, 26 March 2009 09:21 Go to previous messageGo to next message
Hi Gunter,
I have expected something like that - function calls inside [] are not
always handled.
We have it in plans, though there some different cases here,
like 'set a [func]' and 'if { [func] } ....'.
Alex
> Hello Alex,
> But an example:
> TlPrint ""
> $num:$denom"
> doWaitMs 500
> ($num/$denom) )]
> } ;# for
> pdoCheckMotionStatBit pdoCheckDriveStatBit
> Thanks
> Gunter
Re: context sensitive help will not work allways. [message #36544 is a reply to message #36516] Fri, 27 March 2009 05:13 Go to previous message
Hello Alex,
thank you for your information.
If you will go on with this problem
it would be very kindly from you
if you could inform me.
Than i can test for you.
Thanks in advance.
Best regards
Gunter
Previous Topic:Content assist contributor extension points?
Next Topic:LTK: Need to replace DeleteResourcedRefactoringContribution
Current Time: Thu May 23 13:42:23 EDT 2013
Powered by FUDForum. Page generated in 0.01647 seconds
