| Transition to 2.0.4 Connectors: update site issues? [message #34778] |
Thu, 02 October 2008 08:31  |
Dann Martens Messages: 65 Registered: July 2009 |
Member |
What is the status of the update site at:
http://www.polarion.org/projects/subversive/download/eclipse /2.0/update-site/
at the moment?
The reference to
org.polarion.eclipse.team.svn.connector_2.0.3.I20080814-1500 is broken,
the web server is falling back to a page offering downloads for 2.0.4
plug-ins:
--- SNIP ---
Multiple Choices
The document name you requested
(/projects/subversive/download/eclipse/2.0/update-site/featu res/org.polarion.eclipse.team.svn.connector_2.0.3.I20080814- 1500.jar)
could not be found on this server. However, we found documents with
names similar to the one you requested.
Available documents:
projects/subversive/download/eclipse/2.0/update-site/feature s/org.polarion.eclipse.team.svn.connector.javahl.sources_2.0 .4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl.win32_2.0. 4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl15.sources_ 2.0.4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl15.win32_2. 0.4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl15_2.0.4.I2 0081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.javahl_2.0.4.I200 81001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.sources_2.0.4.I20 081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.source_2.0.4.I200 81001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.svnkit.sources_2. 0.4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.svnkit15.sources_ 2.0.4.I20081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.svnkit15_2.0.4.I2 0081001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector.svnkit_2.0.4.I200 81001-1900.jar
(common basename)
/projects/subversive/download/eclipse/2.0/update-site/featur es/org.polarion.eclipse.team.svn.connector_2.0.4.I20081001-1 900.jar
(common basename)
Please consider informing the owner of the referring page about the
broken link.
--- SNIP ---
Is this intended behaviour?
Dann
| Re: Transition to 2.0.4 Connectors: update site issues? [message #34983 is a reply to message #34847] |
Sat, 04 October 2008 18:58  |
Member |
Hi Alexei,
I've successfully upgraded the connectors to 2.0.4, yet I have to admit
I did have to wait until the 2.0.4 showed up directly on the update
site, replacing 2.0.3 completely.
My Eclipse (Ganymede) didn't pick up the changes until I restarted -
refreshing P2 didn't work. Goes with the territory for an Eclipse
aficionado: I never shut Eclipse down, I just close the lid of my
Thinkpad in the evening, open it up in the morning and continue working :)
Dann
Alexei Goncharov wrote:
> Dann Martens wrote:
>> at the moment?
>> The reference to
>> broken, the web server is falling back to a page offering downloads
>> for 2.0.4 plug-ins:
>> Best regards,
>> Dann
> Hello Dan.
> Yes, it is so.
> This URL contains connectors Updates for the latest Subversive release.
> And the latest one was yesterday - 0.7.4, but you can install 2.0.4
> Connectors even to Subversive 0.7.3 - they are compatible with it.
> Best regards, Alexei Goncharov.
> Subversive Team.
FUDForum. Page generated in 0.24265 seconds
