| new Grid control :-) [message #2088] |
Thu, 18 May 2006 08:49  |
Originally posted by: ivanooi.gmail.com
Nice work guys! Nice if you guys able to provide some samples code :-D
There's no sample code in current download... :-(
Nice IF Grid control are follow JTable/KTable Modal... presentation and
data are seperate..
| Re: new Grid control :-) [message #3452 is a reply to message #2088] |
Tue, 30 May 2006 09:56   |
Is the grid widget a custom draw widget ?
Just wondering if the grid widget will follow the look & feel of each
platform ..
Yves
| Re: new Grid control :-) [message #3485 is a reply to message #3452] |
Tue, 30 May 2006 14:54  |
Chris Gross Messages: 253 Registered: July 2009 |
Yes the grid is a custom widget. It currently does not match the l&f of
each platform. SWT may add a new API to hook into the theme support on
each platform. If/when that is added, Grid will use it.
-Chris
> platform ..
> Yves
| Re: new Grid control :-) [message #561551 is a reply to message #2088] |
Thu, 18 May 2006 11:18  |
Chris Gross Messages: 471 Registered: July 2009 |
Hi Ivan,
I will be adding examples, sample code and more as the project continues.
The Grid widget is designed to more closely match the SWT Table API.
Its unlikely that will change.
Hopefully KTable will be contributed to Nebula...
-Chris
Ivan wrote:
> data are seperate..
> Thanks
| Re: new Grid control :-) [message #561798 is a reply to message #3452] |
-Chris
> platform ..
> Yves
FUDForum. Page generated in 0.02190 seconds
