| Disable Text hover on comments [message #34238] |
Fri, 07 November 2008 06:02  |
Sheela Messages: 52 Registered: July 2009 |
Member |
We are working on eclipse 3.4 version with DLTK framework. We have
observed that while hovering over any keyword it shows related hover
information, which is correct. Butif a keyword also appears in a comment
or within quotes as a string, text hover still works for it! Is there any
way to disable text hovering inside comments, string literals, etc. ?
Thanks in advance
Sheela
| Re: Disable Text hover on comments [message #34272 is a reply to message #34238] |
Mon, 10 November 2008 01:53  |
Alex Panchenko Messages: 332 Registered: July 2009 |
Hi Sheela,
At the moment it is not configurable - if no matching model elements are
found then the word under cursor is used to find documentation.
We would like to extend this part of the DLTK, unfortunately there are
no exact dates when it will be implemented, probably it will be done
during M4 or M5 releases (end of December - beginning of February),
since it is better to make API changes earlier.
Alex
Sheela wrote:
> any way to disable text hovering inside comments, string literals, etc. ?
> Thanks in advance
> Sheela
FUDForum. Page generated in 0.01531 seconds
