Home » Eclipse Projects » DSDP - Target Management » help on SaveAs
help on SaveAs [message #33644] Mon, 23 March 2009 12:18 Go to next message
Carmelo  is currently offline Carmelo
Hi all
I'm using the subsystem I created to populate my own rcp ...
I more or less recreated the SystemEditableRemoteFile to open a file ...
works fine if I have to just open / save / close the file ....
but
what is the right way to deal with the save as action ...
right now if I have an editor opened the action from the File menu
File/"Save As" fails with an exception
what is the right way to call the saveas from the
eomsystemeditableremotefile ...
any help will be appreciated ...
thanks
kar
Re: help on SaveAs [message #33909 is a reply to message #33644] Wed, 25 March 2009 20:35 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
Hi Kar,
Since I assume you copied SystemEditableRemoteFile.saveAs()
which is working in RSE but not in your app, I'm afraid
that you need to debug this yourself...
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Kar wrote:
> Hi all
> but
> thanks
> kar
Re: help on SaveAs [message #34056 is a reply to message #33909] Thu, 26 March 2009 11:57 Go to previous message
Hi Martin,
got the problem ...
org.eclipse.ui.dialogs;
public class SaveAsDialog extends TitleAreaDialog {
dlgTitleImage = IDEInternalWorkbenchImages.getImageDescriptor(
IDEInternalWorkbenchImages.IMG_DLGBAN_SAVEAS_DLG).createImag e();
guess I'm doing something wrong in the way I create my rcp application ...
clearly the XMLMultiPageEditorPart (or any editor) when I do the save as
from the file menu will call the save as dialog ... and this return a null
pointer exception during the IDEInternalworkbenchimage ...
I believe the workspace is not properly initialized somewhere
will see if I can find what I need to do ..
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:49CACDE4.3000605@windriver.com...
> Hi Kar,
> Cheers,
> Kar wrote:
>> Hi all
>> but
>> thanks
>> kar
Re: help on SaveAs [message #580116 is a reply to message #33644] Wed, 25 March 2009 20:35 Go to previous message
Hi Kar,
Kar wrote:
> Hi all
> but
> thanks
> kar
Re: help on SaveAs [message #580141 is a reply to message #33909] Thu, 26 March 2009 11:57 Go to previous message
Hi Martin,
got the problem ...
> Hi Kar,
> Cheers,
> Kar wrote:
>> Hi all
>> but
>> thanks
>> kar
Previous Topic:Active Project Handling - Howto
Next Topic:serverPortRange recommendation
Current Time: Sun May 19 09:16:31 EDT 2013
Powered by FUDForum. Page generated in 0.01552 seconds
