Home » Eclipse Projects » Eclipse Platform » Classloader problem when loading resource files
Classloader problem when loading resource files [message #336762] Wed, 01 July 2009 11:01 Go to next message
Kai Schlamp is currently offline Kai Schlamp
Hello.
I have a classloader problem that I am unable to solve.
Let's assume one plugin (org.core) and one fragment (org.core.test) with tests for that plugin.
org.core now uses a class of a third party library that needs a filepath (as string) of an
configuration XML file.
No problem until now. I simply solve that by using Bundle.getResource() and
FileLocator.toFileURL(url).getPath() to get the correct path of the configuration file.
The problem is now that the configuration file also contains filepaths that are again used by the
third party library, and I don't have any influence of those library classes.
So it comes that those third party library classes can't find the files and throw an exception.
The only two solutions here I see:
- Change the current working directoy.
E.g. if I start a test (from org.core.test) from within the Eclipse workbench, then the current
working directory seems to be /home/kai/.../org.core.test. So I have to change the current working
directoy to /home/kai/.../org.core.
- Dynamically generate the XML configuration file
Regenerate the XML file with the correct file paths each time my application is started.
I don't like both ideas. Any better solutions? If not, how do I change programmatically the working
directory?
Kai
Re: Classloader problem when loading resource files [message #336766 is a reply to message #336762] Wed, 01 July 2009 11:10 Go to previous messageGo to next message
I found out, it's even worse.
The third party libraries also directly use resources relative to the current working directory.
So it seems that changing the current working directory is the only solution.
Are there other solutions?
Kai
Kai Schlamp wrote:
> Hello.
> (as string) of an configuration XML file.
> and FileLocator.toFileURL(url).getPath() to get the correct path of the
> configuration file.
> that are again used by the third party library, and I don't have any
> workbench, then the current working directory seems to be
> programmatically the working directory?
> Kai
Re: Classloader problem when loading resource files [message #336774 is a reply to message #336766] Wed, 01 July 2009 21:20 Go to previous messageGo to next message
Walter Harley is currently offline Walter Harley
"Kai Schlamp" <schlamp@gmx.de> wrote in message
news:h2fu7v$tme$2@build.eclipse.org...
> solution.
From what you've said it seems that the problem is happening because by
putting your tests into a separate fragment, you've broken an assumption of
the third-party libraries, namely that they are always called from a process
executing in a certain directory relative to the resources.
Perhaps it is worth exploring whether these third-party libraries can be
fixed? For instance, so that they search for resources on the classpath,
rather than in a relative filesystem path?
If not, another possibility might be to copy the necessary resources into
the test fragment folder.
Re: Classloader problem when loading resource files [message #336776 is a reply to message #336774] Wed, 01 July 2009 21:29 Go to previous message
Thanks Walter.
Thats exaclty the problem. And I already wrote them. But they also provide a solution. A static
class to set the working directory for their party library.
But indeed, loading the resources from the classpath would have made things much more easier. Too
bad that many Java devolopers can't even think of environments where a specific folder structure is
not possible.
Kai
>> solution.
Previous Topic:Various Style Commands in View Toolbar
Next Topic:Problems in cheatsheet passing parameters to commands.
Current Time: Thu May 23 19:11:30 EDT 2013
Powered by FUDForum. Page generated in 0.01789 seconds
