Home » Modeling » OCL » Evaluation of transformations with OCL
Evaluation of transformations with OCL [message #33638] Fri, 20 July 2007 13:02 Go to next message
Andrew Carton is currently offline Andrew Carton
I was wondering if anyone has experience with evaluating transformations
with OCL. From my limited knowledge on the subject, I believe constraint
based checking can be used to verify that a transformation is correct.
By providing a redundant specification in OCL of the result of the
transformation can a transformation be evaluated? If anyone have any
tips, tools, papers or links that may be of interest I would appreciate it.
Andrew.
Re: Evaluation of transformations with OCL [message #33671 is a reply to message #33638] Fri, 20 July 2007 16:06 Go to previous messageGo to next message
Eclipse User
Hi, Andrew,
Are you dealing with metamodel-to-metamodel transformations, or with
model-to-model transformations in the same metamodel? Note that OCL (as
implemented in MDT) supports only the Ecore and UML metamodels, to date.
You may want to ask about this on the GMT and/or M2M newsgroups. There QVT
implementations in the works in these projects, and their communities have
some valuable insight.
Christian
Andrew Carton wrote:
> it.
> Andrew.
Re: Evaluation of transformations with OCL [message #33805 is a reply to message #33638] Tue, 24 July 2007 04:45 Go to previous message
Eclipse User
Originally posted by: wah.zurich.ibm.com
Andrew,
we have written a paper a while ago in which we use OCL to specify the
preconditions and postconditions of transformations. It may contain some
useful information for you.
You can find a PDF version of the paper here:
http://www.research.ibm.com/journal/sj/441/koehler.pdf
Michael
> Andrew.
Previous Topic:Bug getting the CollectionType Name
Next Topic:declaring a parameter of a operation of type Sequence
Current Time: Wed May 22 21:36:38 EDT 2013
Powered by FUDForum. Page generated in 0.02481 seconds
