Home » Eclipse Projects » Eclipse Platform » How to make an editor readonly
How to make an editor readonly [message #336240] Tue, 02 June 2009 16:25 Go to next message
Eclipse User
Originally posted by: bulklodd.yandex.ru
How to show a file in the editor in readonly mode without changing its
readonly attribute?
Thanks in advance,
Sergey Klimov
Re: How to make an editor readonly [message #336241 is a reply to message #336240] Wed, 03 June 2009 02:58 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
Sergey Klimov wrote:
> readonly attribute?
From the UI there's no other way than that.
Dani
> Thanks in advance,
> Sergey Klimov
Re: How to make an editor readonly [message #336251 is a reply to message #336240] Wed, 03 June 2009 12:39 Go to previous messageGo to next message
Eclipse User
> readonly attribute?
Which editor? Specifically Java, or any editor in general?
Eric
Re: How to make an editor readonly [message #336256 is a reply to message #336251] Wed, 03 June 2009 15:06 Go to previous messageGo to next message
Eclipse User
I suppose the code will explain that better
IFileStore fileStore =
EFS.getLocalFileSystem().getStore(fileToOpen.toURI());
IWorkbenchPage page =
PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActi vePage();
try {
IDE.openEditorOnFileStore( page, fileStore );
// I want to add some code here to prevent user from modifying the file
// I don't want to change file's attribute because it might be located
on samba server
// and this attribute might just not work
Thanks in advance
"Eric Rizzo" <eclipse-news@rizzoweb.com> wrote in message
news:h0690g$9sn$3@build.eclipse.org...
>> readonly attribute?
> Eric
Re: How to make an editor readonly [message #336280 is a reply to message #336256] Thu, 04 June 2009 18:59 Go to previous messageGo to next message
Eclipse User
Originally posted by: wim.jongman.gmail.com
Hi Sergey,
Can't you take a local copy of the file and make that read-only? What editor
is called, is it your own editor or the defaul editor for the file type?
Best Regards,
Wim Jongman
Posted with Salvo, the Eclipse based newsreader
> try {
> on samba server
> Thanks in advance
>>> Hi,
>>> readonly attribute?
>> Eric
Re: How to make an editor readonly [message #336312 is a reply to message #336280] Fri, 05 June 2009 14:41 Go to previous message
Eclipse User
Hi Wim,
I've found out a clumsy way to do that
ITextEditor editor = (ITextEditor) page.getActiveEditor();
ITextViewer viewer =
(ITextViewer)editor.getAdapter(ITextOperationTarget.class);
if (viewer != null) {
viewer.setEditable(false);
without changing the readonly attribute, but it's really clumsy. At least it
a bit prevents from user modification.
Sergey Klimov
"Wim Jongman" <wim.jongman@gmail.com> wrote in message
news:h09jkn$v06$2@build.eclipse.org...
> Hi Sergey,
> editor
> Best Regards,
> Wim Jongman
>> try {
>> on samba server
>> Thanks in advance
>>>> Hi,
>>>> readonly attribute?
>>> Eric
Previous Topic:CollapseAll Action(Ctrl+Shift+Numpad_Divide) is specific to java editor
Next Topic:How to tailor the Conext menu of text editor?
Current Time: Sat May 25 03:43:44 EDT 2013
Powered by FUDForum. Page generated in 0.04857 seconds
