Home » Eclipse Projects » Eclipse Platform » Editors updating command enablement
Editors updating command enablement [message #336263] Thu, 04 June 2009 05:18 Go to next message
Rob is currently offline Rob
Hi all,
I have created my own app, and I have added commands to my main menu using
CommandContributionItems in the ApplicationActionBarAdvisor. I have
configured the enablement of these commands in the plugin.xml <handlers>
tag. Everything seems to be working ok for most of the commands.
I have also created my own editor (extending TextEditor). The problem is
that I have some commands that I want to be enabled as soon as my editor
goes dirty. However, when I make my editor dirty, the enabled state of the
command is not checked, and it remains disabled in my main menu. I know
it's not being called because part of the <enabledWhen> tag is a
propertytester which is not being called.
Would anyone know how to get the editor to tell the handler to check its
enabled state when it is made dirty? I tried getting my editor to
implement IDocumentListener, so that when documentChanged() is called, I
could try to update the handler, but I don't know what sort of event to
fire in this case.
Any help would be greatly appreciated!
Re: Editors updating command enablement [message #336268 is a reply to message #336263] Thu, 04 June 2009 09:03 Go to previous message
Paul Webster is currently offline Paul Webster
If you are checking the dirty state already in a property tester, all
you need to do is request that property be re-evaluated when the dirty
state changes. See
org.eclipse.ui.services.IEvaluationService.requestEvaluation (String)
PW
Paul Webster
Previous Topic:Migrating a Europa custom installer to Galileo P2
Next Topic:Making an executable jar that includes a properties xml
Current Time: Wed May 22 11:14:29 EDT 2013
Powered by FUDForum. Page generated in 0.01672 seconds
