Home » Eclipse Projects » Eclipse Platform » Syntax Coloring for a Non-File based Editor
Syntax Coloring for a Non-File based Editor [message #336137] Tue, 26 May 2009 03:30 Go to next message
Eclipse User
Originally posted by: pajai.extrabright.com
Hi everybody,
I am trying to get the syntax coloring working when setting an editor's
content programmatically (for an existing editor, e.g. the Java one),
but I have not come to a solution until now. I am not able to set the
content type programmatically. The syntax coloring appears to work only
when opening a file which extension is defined in the
org.eclipse.ui.editors extension point.
What I am doing until now:
- define MyEditorInput extending IEditorInput
- define MyDocumentProvider extending AbstractDocumentProvider and
override createDocument, where I return a Document with the content I
want if getting a parameter of type MyEditorInput. (I tried to override
the method getContentType(Object), but it is never called.)
- Open the Java editor programmatically with my custom input.
Anyone has an idea what I should do for the syntax coloring to work or
how I can set the content type programmatically?
Thanks in advance.
Patrick
Re: Syntax Coloring for a Non-File based Editor [message #336205 is a reply to message #336137] Fri, 29 May 2009 03:22 Go to previous messageGo to next message
Eclipse User
Anyone?
It seems to me like a tricky thing, since syntax coloring within an
editor is linked to a file extension. I am wondering if no one had a
similar problem...
P.
Re: Syntax Coloring for a Non-File based Editor [message #336208 is a reply to message #336205] Fri, 29 May 2009 05:59 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
Patrick J. wrote:
> Anyone?
This is not true. Syntax coloring has nothing to do with a file or a
file extension.
Dani
> I am wondering if no one had a similar problem...
> Cheers,
> P.
Re: Syntax Coloring for a Non-File based Editor [message #336213 is a reply to message #336137] Fri, 29 May 2009 14:13 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Patrick J. wrote:
> Hi everybody,
Have you tried implementing IStorageEditorInput and *not* overriding
the document provider?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Find fields with SearchEngine
Next Topic:Sample for using FilteredItemsSelectionDialog
Current Time: Thu May 23 19:53:56 EDT 2013
Powered by FUDForum. Page generated in 0.01665 seconds
