Home » Eclipse Projects » Eclipse Platform » Finding a trim contribution
Finding a trim contribution [message #335532] Mon, 13 April 2009 14:18 Go to next message
Kent Beck is currently offline Kent Beck
Once I have contributed an item to the status line trim, how can I find it
programmatically?
I have:
<extension point="org.eclipse.ui.menus">
<menuContribution
locationURI="toolbar:org.eclipse.ui.trim.status">
<toolbar id="org.junit.max.ui.trim.toolbar">
<control
id="org.junit.max.ui.trim.widget"
class="org.junit.max.ui.internal.TrimContribution">
</control>
</toolbar>
</menuContribution>
</extension>
And my contribution is showing up just fine. I would like to find it later
with something like findView(String id).
Kent Beck
Three Rivers Consulting, Inc.
Author of JUnit Max
Re: Finding a trim contribution [message #335546 is a reply to message #335532] Tue, 14 April 2009 08:25 Go to previous message
Paul Webster is currently offline Paul Webster
> later with something like findView(String id).
There is no API to find the contributions later. The pattern that is
most prevalent in eclipse is that the control contribution (our status
contribution, for example) gets its data from a manager. ex:
protected Control createControl(Composite parent) {
final ImageHyperlink hyperlink = new ImageHyperlink(parent, SWT.NONE);
IStatusManager m = Activator.getDefault().getStatusManager();
hyperlink.setText(m.getLinkText());
m.addStatusListener(this);
return hyperlink;
PW
Paul Webster
Previous Topic:Enabling content assist using template proposals
Next Topic:Reload org.eclipse.ui.workbench.prefs in 3.4?
Current Time: Sat May 18 12:30:35 EDT 2013
Powered by FUDForum. Page generated in 0.01679 seconds
