Home » Eclipse Projects » SWTBot » Swing support
Swing support [message #32851] Mon, 20 April 2009 15:05 Go to next message
Richard Koop is currently offline Richard Koop
I'm using SWTBot to test my Eclipse RCP application. Most things worked
well when I moved some initialization code from the interactive splash
screen handler to the ApplicationWorkbenchAdvisor.
Only remaining issue I see is using SWTBot to test an Eclipse plug-in that
has an embedded Swing component. I'm using the SWT_AWT.new_Frame and when
I call the bot.views() method it returns an exception when I try to
retrieve the control for the plug-in that contains the embedded SWT_AWT
frame. It seems the call to getControl() returns NULL.
The code I'm using in the createPartControl for the plug-in is...
public void createPartControl(Composite parent)
Composite comp = new Composite(parent,SWT.EMBEDDED | SWT.NO_BACKGROUND);
Frame frame = SWT_AWT.new_Frame(comp);
Does this code need to be restructured?
Richard
Re: Swing support [message #32998 is a reply to message #32851] Wed, 22 April 2009 04:55 Go to previous message
Ketan Padegaonkar is currently offline Ketan Padegaonkar
SWTBot is not activated at the splash handler so you won't be able to
automate anything at that level.
> that has an embedded Swing component. I'm using the SWT_AWT.new_Frame
> and when I call the bot.views() method it returns an exception when I
> try to retrieve the control for the plug-in that contains the embedded
> SWT_AWT frame. It seems the call to getControl() returns NULL.
The code in theory looks fine. I assume that getControl should have
returned the composite that you created. But I'll need to try this out
before I make any comments :)
Could you just try a creating another composite to see what happens ?
-- Ketan
Previous Topic:java.lang.NoSuchMethodError while running SWTBot on Mac OS
Next Topic:Problem with opening File Menu
Current Time: Sat May 18 17:47:47 EDT 2013
Powered by FUDForum. Page generated in 0.04636 seconds
