Home » Eclipse Projects » Eclipse Platform » FilteredItemsSelectionDialog - refreshing content provider
FilteredItemsSelectionDialog - refreshing content provider [message #328955] Sun, 08 June 2008 06:11 Go to next message
Eclipse User
Originally posted by: fraserofthenight.gmail.com
Hi all,
I have a filtered content selection dialog, and in the extended content
area I have a checkbox that adds an extra filter. I added a selection
listener to the checkbox so that whenever the user selects/deselects it,
I want the dialog to empty its content and re-call
fillContentProvider(). However, I can't seem to make it do this (I've
tried refesh(), scheduleRefresh() and reloadCache()).
Is there any way to force the dialog to call fillContentProvider().
Short of that, I can't even seem to make it call matches() on every
item, so is there a way to force it to do that and re-match the items?
Robert
Re: FilteredItemsSelectionDialog - refreshing content provider [message #328966 is a reply to message #328955] Mon, 09 June 2008 09:19 Go to previous messageGo to next message
Eclipse User
Robert Fraser wrote:
> Hi all,
Have you tried calling applyFilter()? In order for that to work, the new
filter will have to be different from the previous one.
Hope this helps,
Eric
Re: FilteredItemsSelectionDialog - refreshing content provider [message #328994 is a reply to message #328966] Tue, 10 June 2008 03:26 Go to previous messageGo to next message
Eclipse User
>> Hi all,
>> content area I have a checkbox that adds an extra filter. I added a
>> selection listener to the checkbox so that whenever the user
>> selects/deselects it, I want the dialog to empty its content and
>> re-call fillContentProvider(). However, I can't seem to make it do
>> this (I've tried refesh(), scheduleRefresh() and reloadCache()).
> Hope this helps,
> Eric
Okay, this is really weird. I'm initializing the dialog with "**" and at
that point if I check/uncheck the box in the extended content area,
nothing happens. But if I change the filter text to something else &
then go back to ** and check/uncheck the box which is supposed to change
the filter, it works fine.
Relevant code (I've tried to remove everything not relevant to this
particular issue):
private abstract class AbstractModuleFilter extends ItemsFilter
public boolean isConsistentItem(Object item)
return true;
public boolean matchItem(Object item)
return matches(getName(item));
private final class AllModulesFilter extends AbstractModuleFilter
public boolean equalsFilter(ItemsFilter filter)
return filter instanceof AllModulesFilter &&
super.equalsFilter(filter);
private final class OnlyMainFilter extends AbstractModuleFilter
return isMainModule(item) && super.matchItem(item);
return filter instanceof OnlyMainFilter &&
protected Control createExtendedContentArea(Composite parent)
// ...[snip creating a composite with fOnlyMainCheckbox]...
fOnlyMainCheckbox.addSelectionListener(new SelectionAdapter()
public void widgetSelected(SelectionEvent e)
fOnlyMain = fOnlyMainCheckbox.getSelection();
applyFilter();
return comp;
protected ItemsFilter createFilter()
return fOnlyMain ? new OnlyMainFilter() : new AllModulesFilter();
Than you so much for your help,
Robert
Re: FilteredItemsSelectionDialog - refreshing content provider [message #329116 is a reply to message #328994] Thu, 12 June 2008 23:21 Go to previous messageGo to next message
Eclipse User
>>> Hi all,
>> new filter will have to be different from the previous one.
>> Hope this helps,
>> Eric
> particular issue):
> return true;
> @Override
> @Override
> @Override
> @Override
> @Override
> applyFilter();
> return comp;
> @Override
> Robert
Anyone know...?
Robert
Re: FilteredItemsSelectionDialog - refreshing content provider [message #329396 is a reply to message #328994] Mon, 23 June 2008 01:44 Go to previous messageGo to next message
Eclipse User
>>> Hi all,
>> Hope this helps,
>> Eric
> particular issue):
> return true;
> @Override
> @Override
> @Override
> @Override
> @Override
> applyFilter();
> return comp;
> @Override
> Robert
Might anyone have an example of how FliteredItemsSelectionDialog is
used, perhaps with an additional filter like this...?
Re: FilteredItemsSelectionDialog - refreshing content provider [message #894458 is a reply to message #328955] Mon, 09 July 2012 06:01 Go to previous message
Shiyam Hoda is currently offline Shiyam Hoda
Hi Robert Fraser
Have you figured out how to do this?
I have to do the same and stuck.
Help Please.
Question same as OP.
Previous Topic:Is it possible to debug a GPU code with Eclipse ?
Next Topic:Question about FilteredItemsSelectionDialog
Current Time: Tue May 21 20:08:49 EDT 2013
Powered by FUDForum. Page generated in 0.05456 seconds
