| STEM: problem building a project [message #32593] |
Mon, 23 July 2007 15:47  |
Originally posted by: araratjan.yahoo.com
Hi all,
I was finally able to populate all subfolders in the project with
appropriate scenior/graph/model/sequencer. However, when I try to run the
scenario, I got an error "The Scenario cannot be run becasue it does not
have a sequencer". Well, I did create a sequencer in the Sequencer folder.
Apparently, it will not associate the created sequencer with the Scenario.
Is there somthing I am not doing right?
Thanks.
Armen
| Re: solved! [message #32697 is a reply to message #32662] |
Tue, 24 July 2007 11:57   |
The problem I was having was that I was dragging and dropping onto the
window, rather than onto the project icon/name. It is wokring now. May
also be another issue to incude in the documentation: to specify that the
items must be dragged and dropped onto the listing, not just anywehere on
the window.
Thanks!
| Re: solved! [message #32728 is a reply to message #32697] |
Tue, 24 July 2007 12:32  |
Daniel Ford Messages: 138 Registered: July 2009 Location: New York |
Cool & Congrats!....So, you used the editors to create your own Scenario(s)
and they're running, awesome.
Thanks for sticking through the process. We know the editors and the entire
process needs work...getting some bug reports with your feedback would be
great. https://bugs.eclipse.org/bugs/enter_bug.cgi?product=OHF
Dan
Daniel Ford
IBM Almaden Research Center
San Jose, CA
"Armen" <araratjan@yahoo.com> wrote in message
news:4608c1afc56b7e39e45a8aa484b32277$1@www.eclipse.org...
> the window.
> Thanks!
| Re: problem building a project [message #580633 is a reply to message #32593] |
Mon, 23 July 2007 16:14  |
Armen,
open the Scenario in the editor and then drag the Sequencer from the folder
to the Scenario and drop it.
Dan
Daniel Ford
San Jose, CA
"armen" <araratjan@yahoo.com> wrote in message
news:f55c537a3ffb0983f32c4316c9c7c833$1@www.eclipse.org...
> Hi all,
> Thanks.
> Armen
| Re: solved! [message #580660 is a reply to message #32662] |
the window.
Thanks!
| Re: solved! [message #580700 is a reply to message #32697] |
Dan
Daniel Ford
San Jose, CA
> the window.
> Thanks!
FUDForum. Page generated in 0.05694 seconds
