Home » Eclipse Projects » DSDP - Target Management » how to correctly init RSE
how to correctly init RSE [message #32205] Mon, 23 February 2009 05:07 Go to next message
Carmelo  is currently offline Carmelo
Hi all,
I'm using my own subsystem to connect to a db in an RCP application ...
The question is what is the right wait to initialize the RSE Core library?
I have tried with
try
RSECorePlugin.waitForInitCompletion();
catch (InterruptedException e)
// TODO Auto-generated catch block
e.printStackTrace();
ISystemRegistry sr = RSECorePlugin.getTheSystemRegistry();
but still I get the following error in the application log:
!MESSAGE While loading class
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner ", thread
"Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
"Thread[main,6,main]" to finish starting bundle
"update@plugins/org.eclipse.rse.ui_3.0.2.v200812041720.jar [988]". To avoid
deadlock, thread "Thread[Worker-1,5,main]" is proceeding but
" org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner " may not be
fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle
"update@plugins/org.eclipse.rse.ui_3.0.2.v200812041720.jar" by thread
"main".
org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1141)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:258)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPref erencesManager.java:510)
Caused by:
org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 15 more
Root exception:
Re: how to correctly init RSE [message #32342 is a reply to message #32205] Mon, 23 February 2009 09:14 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
Hi Kar,
at the moment, the RSE UI / Non-UI separation has not yet proceeded
enough that you could initialize RSEcorePlugin only without also loading
RSEUIPlugin.
For now, please reference RSEUIPlugin in any way before waiting for init
completion.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Kar wrote:
> Hi all,
> I have tried with
> try
> thread "Thread[Worker-1,5,main]" timed out waiting (5000ms) for thread
> avoid deadlock, thread "Thread[Worker-1,5,main]" is proceeding but
> not be fully initialized.
> !STACK 0
> "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: how to correctly init RSE [message #32377 is a reply to message #32342] Mon, 23 February 2009 09:48 Go to previous message
Thanks Martin
"Martin Oberhuber" <martin.oberhuber@windriver.com> wrote in message
news:49A2AF61.4050603@windriver.com...
> Hi Kar,
> at the moment, the RSE UI / Non-UI separation has not yet proceeded enough
> RSEUIPlugin.
> completion.
> Kar wrote:
>> Hi all,
>> library?
>> I have tried with
>> try
>> !STACK 0
>> "main".
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> ... 15 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: how to correctly init RSE [message #579256 is a reply to message #32205] Mon, 23 February 2009 09:14 Go to previous message
Hi Kar,
RSEUIPlugin.
completion.
Kar wrote:
> Hi all,
> I have tried with
> try
> !STACK 0
> "main".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Caused by:
> ... 15 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: how to correctly init RSE [message #579270 is a reply to message #32342] Mon, 23 February 2009 09:48 Go to previous message
Thanks Martin
> Hi Kar,
> RSEUIPlugin.
> completion.
> Kar wrote:
>> Hi all,
>> library?
>> I have tried with
>> try
>> !STACK 0
>> "main".
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> ... 15 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Previous Topic:Working with Synchronize as part of Export
Next Topic:Locator is null when using the APIs to start up TCF
Current Time: Wed May 22 14:22:54 EDT 2013
Powered by FUDForum. Page generated in 0.17651 seconds
