| Re: Service release 0.7.2 [message #28382 is a reply to message #28307] |
Mon, 04 August 2008 14:40   |
Originally posted by: noah.roberts.eng-software.com
Alexander Gurov wrote:
> Hello All,
> We have published Subversive service realease 0.7.2. This release
> supports usage of important SVN 1.5 features. Unfortunately introducing
> this features made new connectors incompatible with the Subversive
> version which is included into the Ganymede simultaneous release because
> SVN 1.5 has major API changes in compare to 1.4 version.
> So, we moved Ganymede-related update sites to the following URLs:
> connectors to
> http://www.polarion.org/projects/subversive/download/eclipse /2.0/ganymede-site/
> and integrations to
> http://www.polarion.org/projects/subversive/download/integra tions/ganymede-site/
> in order to allows installing of the Ganymede's Subversive version. Also
> please note that Subversive 0.7.2 contains lot of fixes in compare to
> previous release and it is strongly recommended to update your
> Subversive instance to the 0.7.2 one.
Well, updating this completely broke it. The sites you list above (for
connectors and integrations) do not appear to have anything of a later
date than 20080612, which I have installed.
I added the update site listed here:
http://www.eclipse.org/subversive/downloads.php
It had the 0.7.2 update. I selected the following packages to update:
JavaHL 1.5.0 binaries
Subversion Native Library Adapter
Subversive integration for mylyn
subversive svn connectors
SVN Team Provider
SVNKit 1.2.0
SVNKit Cliend Adapter
SVNKit Library
The versions on these are now respectively:
2.0.1.I20080612-1500
1.5.1
0.7.2.I20080801-1500
1.5.1
1.2.0.4583
I get this error:
SVN: '0x00400006: Validate Repository Location' operation finished with
error: Selected SVN connector library is not available or cannot be loaded.
If you selected native JavaHL connector, please check if binaries are
available or install and select pure Java Subversion connector from the
plug-in connectors update site.
If connectors already installed then you can change the selected one at:
Window->Preferences->Team->SVN->SVN Client.
The correct path appears to be Preferences->Team->SVN
Select SVN Connector tab.
The list of SVN Connector plugins is then entirely empty.
My bet would be that the 20080612 connectors are not compatible with
0.7.2 but there is nothing more recent in the sites you list nor in any
others I can find. Alternatively there may be a conflict with Subclipse?
| Re: Service release 0.7.2 [message #28451 is a reply to message #28382] |
Mon, 04 August 2008 15:04   |
I tried a completely fresh install from the Ganymede CDT installation.
Same results. No SVN connector in the list of connectors.
| Re: Service release 0.7.2 [message #28952 is a reply to message #28916] |
Mon, 04 August 2008 16:46   |
Originally posted by: pazu.pazu.com.br
Finally managed to install 0.7.2 by building subversive itself from source
and exporting the relevant projects to an extension location. Connectors
were then successfully installed from the updated site.
Something must be wrong with the update site descriptors, preventing the
right plugins from showing up.
I was supposed to be training a team in subversion (using subversive)
tomorrow, and the new merge features in 1.5 (and subversive 0.7.2) are
probably the most interesting part of the training. Hmm... maybe I should
wait a couple days before referring them to the new version, or maybe just
pretend my local copy installed OK, and hope everything will be alright
before the students try to install it by themselves :)
| Re: Service release 0.7.2 [message #29211 is a reply to message #29173] |
Tue, 05 August 2008 08:23   |
Originally posted by: alexander.gurov.polarion.org
Hello Francois,
>Am I the only to find this a bit painful?
No, we also think that the installation process is to hard, but at this
moment this is the best that we can propose. Following is citation from
the bug 241135:
"I agree with you, but unfortunately we have two conflicting requirements:
the first point is that we should provide users with support of the SVN
1.5 features (exactly merge tracking) as soon as possible (because SVN 1.5
is released a few days later than Eclipse Ganymede), the second point is
that we should graduate our project and this step requires a major changes
in the plug-in functionality. We made these changes while implementing SVN
1.5 support, but if we perform release review in order to make 0.8.0
version, we will lose our chance to graduate Subversive in the nearest
time. So, regarding to this situation we should leave existing major and
minor numbers until plug-in is graduated to 1.0.0 version that also will
point to API changes."
Direct link to the bug:
Build 0.7.1 seems broken, invoking abstract methods
https://bugs.eclipse.org/bugs/show_bug.cgi?id=241135
| Re: Service release 0.7.2 [message #30014 is a reply to message #29211] |
Wed, 06 August 2008 02:06   |
Francois Cottet Messages: 19 Registered: July 2009 |
Junior Member |
> Hello Francois,
Actually I understand your will to provide users the best possible
experience of SVN by adding 1.5 features ASAP. But IMHO the first rule
is "do not brake the existing installations", even if this implies some
delays.
Thanks for the direct link to the bug, it helps to understand the pros
and cons. As always it's all about trade-off.
Noah Roberts wrote:
> We're not laymen. We're all software developers, right?
Sorry Noah but even if most of us are developers, not all of us.
And the Eclipse foundation is pushing forward the idea that Eclipse
Platform is much more than an IDE.
Francois
| Re: Service release 0.7.2 [message #30413 is a reply to message #28307] |
Wed, 06 August 2008 10:50   |
Originally posted by: afbagwe.sandia.gov
OK, problem with the update.
I'm using Europa (v3.3.2)
The standard update site URL when viewed through my Firefox web browser
clearly shows that the latest 0.7.2 plugin released on Aug 1 is there.
But using both "update installed features" or "search for new features"
inside of Eclipse stubbornly insists that no new software is available.
Yes I've checked the URL... in fact I'm using the remote site URL that
Subversive creates after it is installed the first time.
The upgraded connectors (via the Polarion site) are the only updates
showing as available, but they are blocked from install due to a
dependency error about the missing plugin upgrade.
When will this issue be fixed?
Allen
| Re: Service release 0.7.2 [message #30454 is a reply to message #30413] |
Wed, 06 August 2008 11:40   |
Hello Allen,
I have no issue in the same environment and I've successfully installed
Subversive 0.7.2 into the my Eclipse 3.3.2 instance. The possible reason
for this issue is the proxy (if applicable) which have stale information
cached or any other network issue. In order to avoid the problem you also
can try to download zipped update site and use it in order to install
newest Subversive version.
| Re: Service release 0.7.2 [message #30659 is a reply to message #30454] |
Thu, 07 August 2008 09:45   |
I found the source of the problem. I was letting the Eclipse software
install feature automatically select mirrors. It appears that one or maybe
more of the site mirrors were not updated. I just re-tried, picking a
different mirror until I hit one that had the new plugin update.
Thanks!
| Re: Service release 0.7.2 [message #30694 is a reply to message #30014] |
Thu, 07 August 2008 18:42   |
Hi all,
I'd like to agree with Francois. I know there's a trade off; I know there
are benefits, and the people who use the advanced features of SVN will
certainly enjoy the new stuff. But these are not certainly all of us. Some
of us are really basic users, who just want to enjoy the simplicity that a
release train like Ganymede offers - download the platform and install
everything you need with a couple of clicks.
By forcing people to lurk newsgroups to know at all times where you want
to move the connectors that should work with the original release, you are
breaking the whole Ganymede experience. Basic users are the ones who end
up screwed. I guess there's not too many of us who just want to connect to
a repository, work on code, and commit it, right?
Besides causing damage to the ones you should satisfy the most, I think
you also broke your commitment to the Eclipse foundation. A release train
only works when each one of the components in it sticks to the build and
update policies, and it seems you have failed to do so. I'm not Ganymede
expert, but isn't the september release supposed to be a maintenance
release, which basically means "No more features; just fix bugs"?
Moreover, why do you call this a "Service Release" and mention at the same
time that you're adding new features?
Thanks a lot for your attention.
-Juan Cadavid
| Re: Service release 0.7.2 [message #31680 is a reply to message #31503] |
Wed, 13 August 2008 04:14  |
Kal Sze wrote:
> I'm using Ganymede and somehow got the Update Manager to update the
> Subversive SVN Connectors and SVN Team Provider plug-ins to
> 2.0.2.I20080801-1500 and 0.7.2.I20080801-1500 respectively.
> Do you mean that these newer versions will fail to operate correctly in
> Ganymede even if they can be installed?
No. The configuration described by you will works fine.
FUDForum. Page generated in 0.02284 seconds
