Home » Modeling » OCL » Re: [OCL] String Operations
| Re: [OCL] String Operations [message #1230] |
Tue, 30 January 2007 07:47  |
Ian,
OCL has its own newsgroup now: eclipse.modeling.mdt.ocl.
Ian Bull wrote:
> Does OCL support String regular expression operations. I need to
> select items whose name matches a particular regex. (Actually I just
> need startWith) but I could imagine the need for more powerful
> operations.
> Cheers,
> Ian
| Re: [OCL] String Operations [message #1255 is a reply to message #1230] |
Tue, 30 January 2007 09:45   |
Hi, Ian, Ed,
OCL defines the following operations on Strings:
size() : Integer
concat(s : String) : String
substring(lower : Integer, upper : Integer) : String
toInteger() : Integer
toReal() : Real
You can implement startsWith and endsWith using the substring operation:
context String
def: startsWith(s : String) : Boolean =
s.size() <= self.size() and self.substring(1, s.size()) = s
def: endsWith(s : String) : Boolean =
let start : Integer = self.size() - s.size() + 1 in
start > 0 and self.substring(start, self.size()) = s
In the latest build of OCL, you can actually implement def expressions of
this nature on the String library class! Or, you can follow Chris Lenz's
example on the OCL Wiki of extending the OCL Environment to add custom
operations to suit your needs:
http://wiki.eclipse.org/index.php/CustomizingOclEnvironments
I will need to update this example for M5 when it comes.
Christian
Ed Merks wrote:
> Ian,
>> operations.
>> Cheers,
>> Ian
| Re: [OCL] String Operations [message #1276 is a reply to message #1255] |
Tue, 30 January 2007 12:55   |
Originally posted by: irbull.cs.uvic.ca
Thanks Christian,
I looked at the example on the wiki about extending the environment.
What is the OCLHelperFactory? Do I have to define this (Is this where
my extensions come from)?
Do you have any advice on how to implement def expressions directly on
the String Class?
Ian
P.S. Sorry Ed, I'm sure it must get tiring when everyone posts in the
wrong spot :(
Christian W. Damus wrote:
> Hi, Ian, Ed,
> size() : Integer
> toReal() : Real
> context String
> Cheers,
> Christian
> Ed Merks wrote:
>> Ian,
>>> operations.
>>> Cheers,
>>> Ian
| Re: [OCL] String Operations [message #3134 is a reply to message #1276] |
Wed, 31 January 2007 10:31   |
Hi, Ian,
See some replies in-line, below.
HTH,
Christian
Ian Bull wrote:
> Thanks Christian,
No. This is just Chris's way of modeling his OCL extension. He modeled
(using Ecore) an object that he injects into the every OCL environment via
a "global" variable named "helper".
> the String Class?
Just do this, for example:
import org.eclipse.ocl.ecore.OCL;
OCL ocl = OCL.newInstance();
OCL.Helper helper = ocl.createHelper();
EClassifier stringType =
ocl.getEnvironment().getOCLStandardLibrary().getString();
helper.setContextClassifier(stringType);
helper.defineOperation("startsWith(s : String) : Boolean = ...");
I haven't tried this, so YMMV ;-)
> Ian
> wrong spot :(
<snip>
| Re: [OCL] String Operations [message #3198 is a reply to message #3134] |
Wed, 31 January 2007 17:52   |
Ok, I see what you have done here. I could write my routines in OCL
like this, but for some routines it might be easier to write them in
Java (for example, regex routines since they already exist in Java
libraries).
I have hacked together a way of doing this using a custom
EcoreEnvironment and Ecore Evaluation Environment.
I then added my operation to the environment, and in the evaluation
environment, if I get my operation I execute the appropriate method on
the String class.
Does this make sense? Do you expect people to use OCL in this way? If
this is an expected use of OCL I can post the code on the wiki. It is
similar to what Chris Lenz's did, but it extends primitive types with
additional operations.
cheers,
ian
> Hi, Ian,
> HTH,
> Christian
> Ian Bull wrote:
>> Thanks Christian,
>> the String Class?
>> Thanks,
>> Ian
>> wrong spot :(
> <snip>
| Re: [OCL] String Operations [message #3264 is a reply to message #3198] |
Thu, 01 February 2007 15:42   |
Hi, Ian,
Yes, this does make sense. It is one way in which the OCL
parser/interpreter is meant to be extended by clients. I think it's more
interesting to support the overriding of existing operation
implementations. Otherwise, you run the risk of creating OCL constraints
that aren't portable between applications because they don't adhere to the
spec or the model. Of course, that's why OCL allows to define "additional
operations" as helpers, which are also portable. It kinda breaks down,
though, when what's missing is primitives provided by OCL, itself ...
This would make a fine contribution to the Wiki examples corner.
Thanks!
Christian
> libraries).
> the String class.
> cheers,
> ian
<snip>
Current Time: Sun May 19 11:37:26 EDT 2013
Powered by FUDForum. Page generated in 0.01845 seconds
