Home » Eclipse Projects » Eclipse Platform » debug plugin resolution
debug plugin resolution [message #310426] Fri, 01 December 2006 18:42 Go to next message
Adam Cabler is currently offline Adam Cabler
I have some plugins that work with the sdk, but not with the
platform. Is there a way I can see why they aren't resolved in the
platform? I'm looking for messages like "Plugin A requires Plugin B".
thanks,
adam
Re: debug plugin resolution [message #310427 is a reply to message #310426] Fri, 01 December 2006 19:04 Go to previous messageGo to next message
Found it - run eclipse with -console, then type "ss" to get a list of
plugins and their state. You can then do "diag <id>" to see what the
problem is.
AdamC wrote:
> Hello,
> thanks,
> adam
Re: debug plugin resolution [message #310428 is a reply to message #310427] Fri, 01 December 2006 23:56 Go to previous message
John J. Barton is currently offline John J. Barton
you can also try Core Tools http://wiki.eclipse.org/index.php/Core_Tools
Harder to get to started but has more info.
> problem is.
> AdamC wrote:
>> Hello,
>> thanks,
>> adam
Previous Topic:how to run infocenter in an application server
Next Topic:Bugzilla new bug wizard??
Current Time: Sat May 18 17:19:21 EDT 2013
Powered by FUDForum. Page generated in 0.06918 seconds
