| Re: IBM announces the Contribution of STEM to the Eclipse OHF project [message #30913 is a reply to message #30878] |
Fri, 22 June 2007 16:40  |
Werner Keil Messages: 1067 Registered: July 2009 |
Thanks a lot for the reply.
As I have not received all of them from the magazine, I may not have
enough of them before you leave, but my contact there also received the
offer from your colleague Jenny Hunter.
So I guess, she can also answer most of those while you are gone.
Have a nice vacation.
Werner
Daniel Ford wrote:
> Werner,
> I can probably answer most of your quesitons....until Friday, then I'm
> on vacation.
> Dan Ford
> IBM Almaden Research Center
> "Werner Keil" <werner.keil@gmx.net> wrote in message
> news:f5cait$rqd$1@build.eclipse.org...
>> John,
>> I was asked to write a little bit about OHF and STEM in particular, as I
>> already contributed a longer OHF article in the German Eclipse Magazin.
>> Would you be able to answer some questions about it?
>> Or who else would you consider best?
>> Even if they just seem to get started with it, users like Marlies are of
>> course also welcome.
>> The article is in German, so people and institutions there thinking of
>> using STEM are sure of interest for this.
>> Thanks in Advance,
>> Werner
>> John Thomas wrote:
>>> The announcement is at the following URL:
>>> http://www-03.ibm.com/press/us/en/pressrelease/21656.wss
>>> The OHF STEM project page is at:
>>> http://www.eclipse.org/ohf/components/stem/
>>> The OHF STEM Wiki is at:
>>> http://wiki.eclipse.org/index.php/STEM
| Re: IBM announces the Contribution of STEM to the Eclipse OHF project [message #579429 is a reply to message #30878] |
Werner
Daniel Ford wrote:
> Werner,
> on vacation.
> Dan Ford
>> John,
>> Thanks in Advance,
>> Werner
FUDForum. Page generated in 0.01861 seconds
