Home » Eclipse Projects » EPF » Q: How do I avoid circular references and get the job done
| Q: How do I avoid circular references and get the job done [message #27882] |
Fri, 26 January 2007 17:34  |
Rob Robason Messages: 72 Registered: July 2009 |
Member |
After experiencing the cons of creating circular references, I'm eager to
avoid that in the future, but some of the plugins I'm working on seem to
demand them. I'm looking for a way to structure my information to avoid
catastrophe.
I've opted to use Option 1: Organizing the content packages along the major
areas of concern of the plug-in. from the Packaging Guidelines in the
Plug-in Development Guide. My plugins are structured along the lines of the
CMMI process areas.
What I'm finding now is that dependencies between process areas are forcing
me to move more and more content into my top level plugin in order to avoid
circular references.
So here's my dilemma: I'd prefer to create a single plugin with multiple,
per-process-area, content packages that can cross reference each other, but
I need to have multiple people working on these materials in parallel, and
collisions in the plugin.xmi file seem to preclude that approach.
Am I missing something? Is there a way around this?
Rob Robason
Software Process Manager
Wind River Systems
| Re: How do I avoid circular references and get the job done [message #27962 is a reply to message #27882] |
Mon, 29 January 2007 15:16   |
Originally posted by: phaumer.xxx.com
Hello Rob.
You got it right. A bit of architectural layering is required here. You
can move elements up a layer or move elements down a layer. You could
set-up a hierarchy of base plug-ins (i.e. more than one base plug-in; higher
layer) if it is possible to partition the interdependent content. You can
also create integration plug-ins (lower layer) that depend on the plug-ins
that they integrate and use contribution to add cross-plug-in relationships.
For example, the integration plug-in could contains tasks that contribute to
a base task input/output relationships to work products from the different
plug-ins that you want to integrate.
Thanks and best regards,
Peter Haumer.
____________________________________________________________ __
PETER HAUMER
IBM | Eclipse Process Framework Committer
"Rob Robason" <rob.robason@windriver.com> wrote in message
news:epdvle$mbn$1@utils.eclipse.org...
> catastrophe.
> major areas of concern of the plug-in. from the Packaging Guidelines in
> the Plug-in Development Guide. My plugins are structured along the lines
> of the CMMI process areas.
> forcing me to move more and more content into my top level plugin in order
> to avoid circular references.
> but I need to have multiple people working on these materials in parallel,
> and collisions in the plugin.xmi file seem to preclude that approach.
> Rob Robason
> Wind River Systems
| Re: Q: How do I avoid circular references and get the job done [message #28455 is a reply to message #27882] |
Fri, 02 February 2007 08:45  |
jan masaryk Messages: 50 Registered: July 2009 |
Member |
nice summary. :-)
I also feel dilemma between managing authoring of process areas (access
rights, reviewing)
and Method Plugin reference hell. :-)
what can help, is using continuos integration features/topics
as information summary of authoring changes in repository ...
Rob, what's your Method Library structure now?
How do you manage authoring?
all the best,
jan
On Fri, 26 Jan 2007 23:34:22 +0100, Rob Robason
> catastrophe.
> major
> the
> CMMI process areas.
> forcing
> avoid
> but
> and
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
| Re: How do I avoid circular references and get the job done [message #575559 is a reply to message #27882] |
Peter Haumer Messages: 228 Registered: July 2009 |
Hello Rob.
Peter Haumer.
PETER HAUMER
> catastrophe.
> Rob Robason
> Wind River Systems
| Re: How do I avoid circular references and get the job done [message #575657 is a reply to message #27962] |
Thu, 01 February 2007 19:56  |
Member |
Thanks for confirming.
"Peter Haumer" <phaumer@xxx.com> wrote in message
news:eplknk$idc$1@utils.eclipse.org...
> Hello Rob.
> higher layer) if it is possible to partition the interdependent content.
> You can also create integration plug-ins (lower layer) that depend on the
> plug-ins that they integrate and use contribution to add cross-plug-in
> relationships. For example, the integration plug-in could contains tasks
> that contribute to a base task input/output relationships to work products
> from the different plug-ins that you want to integrate.
> Peter Haumer.
> PETER HAUMER
>> catastrophe.
>> order to avoid circular references.
>> parallel, and collisions in the plugin.xmi file seem to preclude that
>> approach.
>> Rob Robason
>> Wind River Systems
| Re: Q: How do I avoid circular references and get the job done [message #575813 is a reply to message #27882] |
Member |
nice summary. :-)
rights, reviewing)
all the best,
jan
> catastrophe.
> major
> the
> CMMI process areas.
> forcing
> avoid
> but
> and
Current Time: Wed May 22 10:04:58 EDT 2013
Powered by FUDForum. Page generated in 0.01967 seconds
