Home » Eclipse Projects » DSDP - Target Management » SSH Permission denied, double Upload?
SSH Permission denied, double Upload? [message #28169] Thu, 09 October 2008 12:30 Go to next message
Ulrich is currently offline Ulrich
I have a problem when connecting via RSE/"SSH only" to an external server.
As soon as I edit a file and try to save it I get the error "Operation
failed. Security violation" ("Message reported from file system:
Permission denied"), although the file is saved correctly (which makes
this error even more annoying, I could just ignore it...).
The debugger outputs this:
Sftp-monitor <--
2008-10-09 18:21:11.137 | Worker-7 | SftpFileService.upload admin.php ok
2008-10-09 18:21:11.199 | Worker-7 | SftpFileService.upload
/html/editor/admin.php failed: 3: Permission denied
Preliminary I do not understand why eclipse tries to save the file two
times and while looking at the java classes I found that it should just
output a filename, so why is there a directory in the debugger output?
I would be really graceful, when someone could help me out here. Works
nice besides this error.
(btw. my ssh account does not have write access to all parent directories.
This might be the source of this problem, but this does not really affect
writing to deeper (allowed) directories, so I am a little bit helpless)
Kind regards,
Ulrich
Re: SSH Permission denied, double Upload? [message #28208 is a reply to message #28169] Thu, 09 October 2008 13:45 Go to previous messageGo to next message
Martin Oberhuber is currently offline Martin Oberhuber
What version of RSE do you use?
I think that we had a problem in 3.0 or probably even 3.0.1,
where uploading a file always tried to change the modification
timestamp of the uploaded file, and that permission was denied on some
systems.
The bug has since been fixed, and if you get the most recent 3.1 I-build
I'm sure it is fixed, I'd need to find the bug report to see whether
it's fixed in 3.0.1 already.
Martin Oberhuber, Senior Member of Technical Staff, Wind River
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Ulrich wrote:
> Hi
> Sftp-monitor <--
> directories. This might be the source of this problem, but this does not
> really affect writing to deeper (allowed) directories, so I am a little
> bit helpless)
> Kind regards,
> Ulrich
Re: SSH Permission denied, double Upload? [message #28247 is a reply to message #28208] Thu, 09 October 2008 14:25 Go to previous messageGo to next message
I use the current version available via the download-URL for eclipse. I
think this is 3.0.1.
Where can I find the current build?
These packages here?
http://download.eclipse.org/dsdp/tm/downloads/drops/S-3.1M2- 200809301300/
And how I can install them into eclipse?
Installing via URL is easier ^^,
Kind regards,
Ulrich
> systems.
> Cheers,
Re: SSH Permission denied, double Upload? [message #28361 is a reply to message #28247] Mon, 13 October 2008 08:19 Go to previous messageGo to next message
Hi Ulrich,
This is the bug, fixed in 3.1m2:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=237616
Yes, you can download the drop from the link that you
posted, and simply extract the archive(s) into your
eclipse/dropins/ folder.
If you prefer an update site, use
http://download.eclipse.org/dsdp/tm/updates/3.1milestones
as referenced on the TM homepage,
Where else do you think that this information is missing?
What do you mean by "download-URL"?
Ulrich wrote:
> Hi
> Kind regards,
> Ulrich
>> systems.
>> I-build I'm sure it is fixed, I'd need to find the bug report to see
>> whether it's fixed in 3.0.1 already.
>> Cheers,
Re: SSH Permission denied, double Upload? [message #28398 is a reply to message #28361] Thu, 16 October 2008 06:12 Go to previous messageGo to next message
Okay, I used this way and it worked fine. The bug is gone :)
I meant the update site.
Besides:
What is about this url?
I used this one first (found via Google) and installed a really old
version.
Wouldn't it be a could idea to ship the 3er version there too?
(So just 2 update sites, one for the stable versions and one for the
milestones? Just for clarity.)
Kind regards,
Ulrich
Re: SSH Permission denied, double Upload? [message #28434 is a reply to message #28398] Thu, 16 October 2008 11:37 Go to previous message
The problem here is, that between 2.0 and 3.0 there occurred
some API change. If we put 3.0 on that site, then people who
have 2.0 installed and do Eclipse "check for updates" could
get 3.0 installed by accident, which might break their
environment.
We don't want that.
Re: SSH Permission denied, double Upload? [message #577560 is a reply to message #28169] Thu, 09 October 2008 13:45 Go to previous message
systems.
Ulrich wrote:
> Hi
> Sftp-monitor <--
> bit helpless)
> Kind regards,
> Ulrich
Re: SSH Permission denied, double Upload? [message #577581 is a reply to message #28208] Thu, 09 October 2008 14:25 Go to previous message
Kind regards,
Ulrich
> systems.
> Cheers,
Re: SSH Permission denied, double Upload? [message #577639 is a reply to message #28247] Mon, 13 October 2008 08:19 Go to previous message
Hi Ulrich,
Ulrich wrote:
> Hi
> Kind regards,
> Ulrich
>> systems.
>> Cheers,
Re: SSH Permission denied, double Upload? [message #577647 is a reply to message #28361] Thu, 16 October 2008 06:12 Go to previous message
Besides:
version.
Kind regards,
Ulrich
Re: SSH Permission denied, double Upload? [message #577656 is a reply to message #28398] Thu, 16 October 2008 11:37 Go to previous message
environment.
We don't want that.
Previous Topic:ssh fails with "Argument cannot be null" if /etc/issue[.ssh] file exists
Next Topic:WEBDAV Support
Current Time: Sun May 19 04:51:04 EDT 2013
Powered by FUDForum. Page generated in 0.06624 seconds
