| Cant install connectors [message #28193] |
Sun, 03 August 2008 08:34  |
Originally posted by: h.seifert.ssc-services.de
i followed the installation instructions from Eclipse.org and installed
the SVN Team Provider 0.7.1.I20080612-1500. But i cant install the svn
connectors. Every connector throws the same failure if i click on
"instal...":
Cannot complete the request. See the details.
Unsatisfied dependency:
[org.polarion.eclipse.team.svn.connector.svnkit.feature.grou p
2.0.2.I20080801-1500] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.2.I20080801-1500,1.0.0)
Cannot find a solution where both Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.1.I20080612-1500,0.7.1.I20080612-1500]]
and Match[requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.team.svn.feature.group /[0.7.2.I20080801-1500,1.0.0)]
can be satisfied.
I am using Eclipse IDE for Java EE Developers, Version: 3.4.0, Build id:
I20080617-2000. A new installation throws the same errors...
Is there something wrong with the actual version of the connectors?
| Re: Cant install connectors [message #28417 is a reply to message #28230] |
Mon, 04 August 2008 14:42  |
Originally posted by: noah.roberts.eng-software.com
Stevo Slavic wrote:
> Hello,
> I've experienced same issue when trying to update 0.7.1 to 0.7.2. Then I
> thought it was something wrong with my eclipse/workspace and tried to
> install Subversive into a new workspace using fresh extract of eclipse
> (3.4) but failed to do it because every try to add Subversive update
> site to list of update sites just fails, no update site gets added.
Go to "manage sites..." I found the subversive update site listed in
there unchecked along with many others. I checked it off and the update
site appeared.
FUDForum. Page generated in 0.01550 seconds
