Home » Eclipse Projects » XML Schema Definition (XSD) » Determining XSD/EMF versions programmatically
Determining XSD/EMF versions programmatically [message #27860] Wed, 03 September 2003 10:41 Go to next message
Shane Curcuru is currently offline Shane Curcuru
Member
I know the answer is somewhere simple, but could someone remind me?
How can I determine the current XSD and/or EMF versions programmatically
from a standalone program? I'm experimenting with swapping XSD, Xerces,
and other component versions (unsuccessfully so far) in standalone
programs, and this would really help my test scripts.
Oh: Xerces - at least newer versions - uses simply this:
java -classpath xercesImpl.jar org.apache.xerces.impl.Version
Shane Curcuru
Re: Determining XSD/EMF versions programmatically [message #27979 is a reply to message #27860] Wed, 03 September 2003 12:41 Go to previous message
Eclipse User
Shane,
No, there isn't a programatic way when running standalone.
> Shane Curcuru
Re: Determining XSD/EMF versions programmatically [message #577099 is a reply to message #27860] Wed, 03 September 2003 12:41 Go to previous message
Ed Merks is currently offline Ed Merks
Shane,
> Shane Curcuru
Previous Topic:Removing components from an XML schema
Next Topic:Treatment of annotation documentation in ecore builder
Current Time: Thu May 23 18:29:17 EDT 2013
Powered by FUDForum. Page generated in 0.01523 seconds
