| Selected Resource [message #1687] |
Tue, 07 November 2006 09:45  |
Chris Lenz Messages: 214 Registered: July 2009 |
Is it possible to get the selected file in a dash script
Is it also possible to create a new file ?
| Re: Selected Resource [message #2731 is a reply to message #1695] |
Tue, 14 November 2006 11:00  |
if i try to run that i get serveral errors
"TypeError: getFirstElement is not a funciton
"Error File is not defined
Bjorn Freeman-Benson schrieb:
> Sure - anything you can do in Java you can do in Monkey.
> --- Came wiffling through the eclipsey wood ---
> * Menu: Selected File
> * Kudos: Bjorn Freeman-Benson
> * License: EPL 1.0
> * DOM: http://download.eclipse.org/technology/das\
> h/update/org.eclipse.dash.doms
> function main() {
> selection = window.getSelectionService().getSelect\
> ion().getFirstElement();
> Packages.org.eclipse.jface.dialogs.MessageDialog.o\
> penInformation(
> window.getShell(),
> "Monkey Dialog",
> selection.toString()
> --- And burbled as it ran! ---
> and
> * Menu: IO > File Sample
> * Kudos: Paul Colton, Aptana, Inc.
> * License: EPL 1.0
> function main()
> var date = new Date();
> // Write out new file
> var file = new File("myFile.txt");
> file.createNewFile();
> file.write("Date: " + date);
> // Read lines from file
> var text = file.readLines();
> // Display what we read
> Packages.org.eclipse.jface.dialogs.MessageDialog.\
> openInformation(
> window.getShell(),
> "File I/O",
> "Contents: " + text
| Re: Selected Resource [message #560418 is a reply to message #1687] |
Wed, 08 November 2006 20:57  |
Bjorn Freeman-Benson Messages: 336 Registered: July 2009 |
* License: EPL 1.0
function main() {
penInformation(
window.getShell(),
"Monkey Dialog",
and
* License: EPL 1.0
function main()
openInformation(
window.getShell(),
"File I/O",
"Contents: " + text
| Re: Selected Resource [message #560426 is a reply to message #1695] |
> * License: EPL 1.0
> function main() {
> penInformation(
> window.getShell(),
> "Monkey Dialog",
> and
> * License: EPL 1.0
> function main()
> openInformation(
> window.getShell(),
> "File I/O",
> "Contents: " + text
FUDForum. Page generated in 0.01670 seconds
