Home » Eclipse Projects » Eclipse Platform » Maximize/restore a view programmatically
Maximize/restore a view programmatically [message #269795] Thu, 02 September 2004 09:02 Go to next message
Maya Barnea is currently offline Maya Barnea
Is there a way to maximize/restore a view programmatically?
Re: Maximize/restore a view programmatically [message #269827 is a reply to message #269795] Thu, 02 September 2004 10:12 Go to previous messageGo to next message
Eclipse User
Originally posted by: Ines_Khelifi.ca.ibm.com
Take a look at the API for the "ActionFactory" class
(org.eclipse.ui.actions.ActionFactory).
Here is quick example:
ActionFactory.IWorkbenchAction maximizeAction =
ActionFactory.MAXIMIZE.create(workbenchWindow);
maximizeAction.run(); // Will maximize the active part
Ines
Re: Maximize/restore a view programmatically [message #832803 is a reply to message #269827] Fri, 30 March 2012 11:57 Go to previous message
Chris Mooney is currently offline Chris Mooney
I recently found a solution for doing this within the view that you are trying to control:
class MyView extends ViewPart {
	 * @param state  one of the IWorkbenchPage STATE_* values: STATE_MAXIMIZED,
         * STATE_MINIMIZED, STATE_RESTORED
	private void setViewState(int state) {
		IWorkbenchPage page
                    = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();
		int currentState = page.getPartState(page.getReference(this));
		if(currentState != state) {
			page.activate(this);
			page.setPartState(page.getReference(this), state);
Adding this method to your view class will let you maximize the view by calling:
setViewState(IWorkbenchPage STATE_MAXIMIZED)
restore it by calling:
setViewState(IWorkbenchPage STATE_RESTORED)
and of course minimize it by calling:
setViewState(IWorkbenchPage STATE_MINIMIZED)
The effect will be that if you maximize this view, all other views get minimized, restore it and all the views go back to their previous state, and minimize and the other views will fight it out for real-estate Smile
share and enjoy!
Previous Topic:javadoc generation and ${tags}
Next Topic:Eclipse freezes/hangs before Workspace selection
Current Time: Thu May 23 07:35:25 EDT 2013
Powered by FUDForum. Page generated in 0.01570 seconds
