Home » Eclipse Projects » EPF » Can't Select... or Add... references
Can't Select... or Add... references [message #26939] Mon, 22 January 2007 17:57 Go to next message
Rob Robason is currently offline Rob Robason
Member
I've recently encountered a new problem. The "Add..." and "Select..."
buttons that generate pop-ups to select Method Elements are not working. I
click the button, get visual feedback (button color and brief hourglass) but
no pop-up.
I see this when I try to Select... the "Primary performer" for a Task, or
Add... "Additional performers" (on the Roles tab), or similar operations on
the Work Products tab or even other object types. Same problem whether
trying to add/select Roles, Work Products, Guidance, or Categories.
This was all working early last week, then boom, it stopped! I'm stuck and
cannot do any meaningful authoring until I get this resolved.
I've tried completely removing epf-composer and my workspace and starting
from scratch, with no difference. What's particularly grating about this bug
is that it's totally silent. I get none of the usually helpful feedback that
accompanies other errors I've encountered.
Has anyone seen this/got a solution?
Rob Robason
Software Process Manager
Wind River Systems
Re: Can't Select... or Add... references [message #27057 is a reply to message #26939] Tue, 23 January 2007 16:33 Go to previous messageGo to next message
Eclipse User
Originally posted by: storaskar.xx.xxx.xxx
We haven't seen this. I suspect may be something wrong with your method
library. If your error continues even after cleaning workspace etc, I
suggest you enter a bug in bugzilla with as much as details as possible -
which EPF version, steps to reproduce the bug, .log file etc
Shilpa
Re: Can't Select... or Add... references [message #27136 is a reply to message #26939] Tue, 23 January 2007 20:32 Go to previous messageGo to next message
Shashidhar Kannoori is currently offline Shashidhar Kannoori
This is a multipart message in MIME format.
--=_alternative 00086C188825726D_=
Content-Type: text/plain; charset="US-ASCII"
Can you please copy and paste content of ".log" file located under your
epf workspace (usually, .log file located in <document
settings>/epf/workspace/.metafile/ directory)?. ".log" file will tell us
complete story of whats wrong with library and why filter dialog unable to
open it.
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Can you please copy and paste content
of &quot;.log&quot; file located under your epf workspace (usually, .log
file located in &lt;document settings&gt;/epf/workspace/.metafile/ &nbsp;directory)?.
&nbsp;&quot;.log&quot; file will tell us complete story of whats wrong
with library and why filter dialog unable to open it.</font>
--=_alternative 00086C188825726D_=--
Re: Can't Select... or Add... references [message #27214 is a reply to message #27136] Wed, 24 January 2007 16:17 Go to previous messageGo to next message
Member
------=_NextPart_000_000C_01C73FBA.0760CD80
charset="iso-8859-1"
I've recorded this problem as bug 171336 =
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D171336), and pasted the =
relevant .log records there.
It appears my plugin dependencies are screwed up, but I can't figure out =
how to patch up the error.
Rob
<skannoor@us.ibm.com> wrote in message =
news:ep6d03$ehv$1@utils.eclipse.org...
Can you please copy and paste content of ".log" file located under =
your epf workspace (usually, .log file located in <document =
settings>/epf/workspace/.metafile/ directory)?. ".log" file will tell =
us complete story of whats wrong with library and why filter dialog =
unable to open it.
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.5730.11" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>I've recorded this problem as bug =
171336 (<A=20
href=3D"https://bugs.eclipse.org/bugs/show_bug.cgi?id=3D171336">https://b=
ugs.eclipse.org/bugs/show_bug.cgi?id=3D171336</A>),=20
and pasted the relevant .log records there.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>It appears my plugin dependencies are =
screwed up,=20
but I can't figure out how to patch up the error.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Rob</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A =
href=3D"mailto:skannoor@us.ibm.com">skannoor@us.ibm.com</A>&gt;=20
wrote in message <A=20
href=3D"news:ep6d03$ehv$1@utils.eclipse.org">news:ep6d03$ehv$1@utils.ecli=
pse.org</A>...</DIV><BR><FONT=20
face=3Dsans-serif size=3D2>Can you please copy and paste content of =
".log" file=20
located under your epf workspace (usually, .log file located in =
&lt;document=20
settings&gt;/epf/workspace/.metafile/ &nbsp;directory)?. &nbsp;".log" =
file=20
will tell us complete story of whats wrong with library and why filter =
dialog=20
unable to open it.</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000C_01C73FBA.0760CD80--
Re: Can't Select... or Add... references [message #27322 is a reply to message #27214] Wed, 24 January 2007 21:25 Go to previous messageGo to next message
Eclipse User
--=_alternative 000D41008825726E_=
Looked at bugzilla record, seems like the plugin's reference is causing
circular dependency, usually UI prevents and check circular dependency at
time of reference plugin selection, can you please recollect the steps you
did earlier which landed into circular plugin references.
You might know the steps i want you to try but in case, Open MethodPlugin
editor of the content element (Task) you are editing, and check the plugin
reference, which other words called as base plugins of plugin you are
working in, check the heirarchy if any base plugin causing circular.
<br><font size=2 face="sans-serif">&nbsp;Looked at bugzilla record, seems
like the plugin's reference is causing circular dependency, usually UI
prevents and check circular dependency at time of reference plugin selection,
can you please recollect the steps you did earlier which landed into circular
plugin references. &nbsp;</font>
<br><font size=2 face="sans-serif">You might know the steps i want you
to try but in case, Open MethodPlugin editor of the content element (Task)
you are editing, and check the plugin reference, which other words called
as base plugins of plugin you are working in, &nbsp;check the heirarchy
if any base plugin causing circular.</font>
--=_alternative 000D41008825726E_=--
Re: Can't Select... or Add... references [message #27802 is a reply to message #27322] Thu, 25 January 2007 18:51 Go to previous message
Member
------=_NextPart_000_0018_01C74098.A7663B10
There's no doubt now that I created circular references and that caused =
my problems. I suspect I created bidirectional references between my =
plugins, or in a loop.=20
Whatever the cause, the symptoms were catastrophic: The UI was offering =
only partial lists of available plugins for reference, and although it =
showed at least some of the culprits, the errant check boxes were filled =
with a hash rather than a check and I couldn't uncheck them.
My solution? I copied all the content of the base plugin I created into =
a new one, broke all the links I could manually and deleted it.=20
Then I had missing reference errors that I chased down to one remaining =
one that I couldn't resolve, and swallowed hard and went in to the xmi =
file and deleted the problem line.
Then I reconnected all my children plugins to the base (from the base).
Needless to say, I won't intentionally create any more circular =
references, but I'd sure be happier if I knew the tool was looking out =
for me be checking for them when I select new plugin references.
Rob
<kannoori@xyz.xyz> wrote in message =
news:ep94f0$l43$1@utils.eclipse.org...
Looked at bugzilla record, seems like the plugin's reference is =
causing circular dependency, usually UI prevents and check circular =
dependency at time of reference plugin selection, can you please =
recollect the steps you did earlier which landed into circular plugin =
references. =20
You might know the steps i want you to try but in case, Open =
MethodPlugin editor of the content element (Task) you are editing, and =
check the plugin reference, which other words called as base plugins of =
plugin you are working in, check the heirarchy if any base plugin =
causing circular.
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
<DIV><FONT face=3DArial size=3D2>There's no doubt now that I created =
circular=20
references and that caused my problems. I suspect I created =
bidirectional=20
references between my plugins, or in a loop. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Whatever the cause, the symptoms were =
catastrophic:=20
The UI was offering only partial lists of available plugins for =
reference, and=20
although it showed at least some of the culprits, the errant check boxes =
were=20
filled with a hash rather than a check and I couldn't uncheck =
them.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>My solution? I copied all the content =
of the base=20
plugin I created into a new one, broke all the links I could manually =
and=20
deleted it. </FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Then I had missing reference errors =
that I chased=20
down to one remaining one that I couldn't resolve, and swallowed hard =
and went=20
in to the xmi file and deleted the problem line.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Then I reconnected all my children =
plugins to the=20
base (from the base).</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Needless to say, I won't intentionally =
create any=20
more circular references, but I'd sure be happier if I knew the tool was =
looking=20
out for me be checking for them when I select new plugin=20
references.</FONT></DIV>
<BLOCKQUOTE=20
<DIV>&lt;<A href=3D"mailto:kannoori@xyz.xyz">kannoori@xyz.xyz</A>&gt; =
wrote in=20
message <A=20
href=3D"news:ep94f0$l43$1@utils.eclipse.org">news:ep94f0$l43$1@utils.ecli=
face=3Dsans-serif size=3D2>&nbsp;Looked at bugzilla record, seems like =
the=20
plugin's reference is causing circular dependency, usually UI prevents =
and=20
check circular dependency at time of reference plugin selection, can =
you=20
please recollect the steps you did earlier which landed into circular =
plugin=20
references. &nbsp;</FONT> <BR><FONT face=3Dsans-serif size=3D2>You =
might know the=20
steps i want you to try but in case, Open MethodPlugin editor of the =
content=20
element (Task) you are editing, and check the plugin reference, which =
other=20
words called as base plugins of plugin you are working in, &nbsp;check =
the=20
heirarchy if any base plugin causing =
circular.</FONT></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_0018_01C74098.A7663B10--
Re: Can't Select... or Add... references [message #575168 is a reply to message #26939] Tue, 23 January 2007 16:33 Go to previous message
Shilpa Toraskar is currently offline Shilpa Toraskar
Shilpa
Re: Can't Select... or Add... references [message #575253 is a reply to message #26939] Tue, 23 January 2007 20:32 Go to previous message
open it.
Re: Can't Select... or Add... references [message #575330 is a reply to message #27136] Wed, 24 January 2007 16:17 Go to previous message
Member
Rob
unable to open it.
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
171336 (<A=20
screwed up,=20
<BLOCKQUOTE=20
<DIV>&lt;<A =
".log" file=20
&lt;document=20
file=20
dialog=20
Re: Can't Select... or Add... references [message #575411 is a reply to message #27214] Wed, 24 January 2007 21:25 Go to previous message
Eclipse User
Re: Can't Select... or Add... references [message #575450 is a reply to message #27322] Thu, 25 January 2007 18:51 Go to previous message
Member
Rob
references. =20
causing circular.
<HTML><HEAD>
<STYLE></STYLE>
</HEAD>
circular=20
bidirectional=20
catastrophic:=20
reference, and=20
were=20
them.</FONT></DIV>
of the base=20
and=20
that I chased=20
and went=20
plugins to the=20
create any=20
looking=20
<BLOCKQUOTE=20
wrote in=20
message <A=20
the=20
and=20
you=20
plugin=20
might know the=20
content=20
other=20
the=20
Previous Topic:Struggling with how to use CVS... Please help me!!
Next Topic:Q: How do I avoid circular references and get the job done
Current Time: Sat May 25 03:44:03 EDT 2013
Powered by FUDForum. Page generated in 0.02536 seconds
