Home » Newcomers » Newcomers » Scrapbook page - Code assist not working...
Scrapbook page - Code assist not working... [message #267732] Thu, 15 January 2009 01:12 Go to next message
Eclipse User
Originally posted by: zerocode.gmx.com
Question: I'm running 3.4.1 to dev in Java. In a new project I wanted to
create a Scrapbook page to run some tests. I added my project in to test
some code. That is when I noticed code suggestion tool (Ctrl+Space)
after typing "new", "new - create new object" doesn't appear.
Re: Scrapbook page - Code assist not working... [message #267745 is a reply to message #267732] Thu, 15 January 2009 13:16 Go to previous messageGo to next message
Darin Swanson is currently offline Darin Swanson
I do not believe scrapbook pages support templates.
The proposal for "new - create new object" is a code assist template
HTH
Darins
http://runnerwhocodes.blogspot.com
"Jimmy Dean" <zerocode@gmx.com> wrote in message
news:gkmk4h$g6t$1@build.eclipse.org...
> some code. That is when I noticed code suggestion tool (Ctrl+Space) after
Re: Scrapbook page - Code assist not working... [message #267759 is a reply to message #267745] Thu, 15 January 2009 20:38 Go to previous messageGo to next message
Eclipse User
Darin,
Thank you very much for your response. I was following Eclipse and Java
for Total Beginners video's they show using code assist with a
scrapbook. When I hit (CTRL+Space) it shows Java Class Objects.
http://www.eclipse.org/resources/resource.php?id=392
The videos are great. I had done it once but lost my laptop. After a
reinstall and a new HD it did not work. :(
Any ideas?
> HTH
> Darins
Re: Scrapbook page - Code assist not working... [message #267804 is a reply to message #267759] Fri, 16 January 2009 14:38 Go to previous messageGo to next message
Which lesson?
Darins
news:gkooec$86t$1@build.eclipse.org...
> Darin,
> for Total Beginners video's they show using code assist with a scrapbook.
> Any ideas?
>> HTH
>> Darins
Re: Scrapbook page - Code assist not working... [message #267808 is a reply to message #267804] Fri, 16 January 2009 21:55 Go to previous messageGo to next message
Eclipse User
Lession 9 Time: 2min 27Sec
in the scrapbook he types in:
new(Then CTRL+SPACE and his shows new - create new object, NEW -
com.sun.org.acpache Etc)
> Which lesson?
> Darins
>> Darin,
>> Any ideas?
>>> HTH
>>> Darins
Re: Scrapbook page - Code assist not working... [message #505459 is a reply to message #267732] Wed, 30 December 2009 18:46 Go to previous messageGo to next message
Geoff Ringent is currently offline Geoff Ringent
Eclipse User wrote on Thu, 15 January 2009 01:12
Nearly one year later with no solution ????
I have the same issue ... perhaps its a matter of 'preferences'?? ... but i cannot find where it is.
Can somebody please enlighten me ... because i can see 'code assist' templates working in Eclipse Scrapbook in the Video Tutorial @ "Eclipse And Java For Total Beginners" video tutorial >>> http://eclipsetutorial.sourceforge.net/.
Re: Scrapbook page - Code assist not working... [message #506475 is a reply to message #505459] Thu, 07 January 2010 11:27 Go to previous messageGo to next message
Dani Megert is currently offline Dani Megert
>> to create a Scrapbook page to run some tests. I added my project in
>> to test some code. That is when I noticed code suggestion tool
>> (Ctrl+Space) after typing "new", "new - create new object" doesn't
>> appear.
You should start by entering a feature request for it (there seems to be
none).
Dani
Re: Scrapbook page - Code assist not working... [message #540100 is a reply to message #506475] Mon, 14 June 2010 17:47 Go to previous messageGo to next message
Micheal  is currently offline Micheal
I'm also having this issue, CTRL-Space will not give me anything about a new object as this tutorial obviously shows.
What am I missing here?
Re: Scrapbook page - Code assist not working... [message #637811 is a reply to message #267732] Mon, 08 November 2010 18:45 Go to previous messageGo to next message
Brian  is currently offline Brian
I am now doing this tutorial, and experience the same issue. HELP PLEASE!
Re: Scrapbook page - Code assist not working... [message #650646 is a reply to message #637811] Tue, 25 January 2011 14:45 Go to previous messageGo to next message
Marco  is currently offline Marco
Under Preferences => Java => Editor => Templates
find the 'new'entry under name, select it, click 'edit..' and change the context from 'java statements' to 'java', click ok.
Code assist in your scrapbook page should display the entry for new object now.
Re: Scrapbook page - Code assist not working... [message #702573 is a reply to message #650646] Tue, 26 July 2011 10:35 Go to previous messageGo to next message
abd.developer is currently offline abd.developer
Thank you. This info was very helpful.
icon14.gif  Re: Scrapbook page - Code assist not working... [message #759144 is a reply to message #650646] Sat, 26 November 2011 16:39 Go to previous messageGo to next message
Chris is currently offline Chris
Thanks Marco! you solved this issue for me and many others
Re: Scrapbook page - Code assist not working... [message #759620 is a reply to message #650646] Tue, 29 November 2011 06:34 Go to previous messageGo to next message
> object now.
I've changed the context for that template so that it should work out of
the box in the future.
Dani
Re: Scrapbook page - Code assist not working... [message #780678 is a reply to message #267732] Wed, 18 January 2012 19:09 Go to previous messageGo to next message
Todd S is currently offline Todd S
>Dani
This problem still exists in the latest version (at the time of this writing) of Eclipse IDE for Java Developers
Version: Indigo (v3.7) Service Release 1
Build id: 20110916-0149
downloaded from www.eclipse.org/downloads/
You still have to perform the changes suggested by Marco in message 650646 above namely:
> Under Window => Preferences => Java => Editor => Templates
> find the 'new' entry under name, select it, click 'Edit...' and change
> the Context: from 'Java statements' to 'Java', click OK.
> Code assist in your scrapbook page should now display the template for new
> object now.
Re: Scrapbook page - Code assist not working... [message #780679 is a reply to message #267732] Wed, 18 January 2012 19:11 Go to previous messageGo to next message
>Dani
> object now.
Re: Scrapbook page - Code assist not working... [message #780680 is a reply to message #267732] Wed, 18 January 2012 19:14 Go to previous messageGo to next message
>Dani
> object now.
Re: Scrapbook page - Code assist not working... [message #782799 is a reply to message #780680] Tue, 24 January 2012 08:26 Go to previous messageGo to next message
>> Dani
Yes of course. My comment was made on November 29, so it's obvious that
the fix isn't in a build from September. Try 3.8/4.2 M4.
Dani
>> for new
>> object now.
Re: Scrapbook page - Code assist not working... [message #903887 is a reply to message #782799] Mon, 27 August 2012 03:01 Go to previous messageGo to next message
Joe Rue is currently offline Joe Rue
Problem exists in Eclipse IDE for Java Developers
Version: Helios Service Release 2
Build id: 20110218-0911
Re: Scrapbook page - Code assist not working... [message #904379 is a reply to message #903887] Tue, 28 August 2012 06:50 Go to previous message
Please read my previous comment again ;-)
Dani
Previous Topic:Eclipse custom errors
Next Topic:Eclipse BIRT in spanish?
Current Time: Sun May 26 01:18:08 EDT 2013
Powered by FUDForum. Page generated in 0.02381 seconds
