| sequence in extesion type ignored [message #26547] |
Fri, 22 August 2003 09:48  |
Originally posted by: ugh.gmx.at
hi, i defined the following complextype:
<xs:complexType name="TaxonomyNodeType">
<xs:sequence>
<xs:element name="Characterization"
type="abc:CharacterizationType"/>
</xs:sequence>
</xs:complexType>
and refer to it like this:
<xs:element name="Lib" minOccurs="0">
<xs:complexType>
<xs:complexContent>
<xs:extension base="abc:TaxonomyNodeType">
<xs:sequence>
<xs:element name="Port" type="abc:TaxonomyNodeType" minOccurs="0"/>
<xs:element name="Opt" type="abc:TaxonomyNodeType" minOccurs="0"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:element>
As you see the second type refers uses the first type as a base type.
The sequence of the base type is included correctly when loaded.
The elements within the sequence of the extension are ignored.
The sequence exists but it is empty.
Any suggestions?
cheers
Didier
| Re: sequence in extesion type ignored [message #26637 is a reply to message #26547] |
Fri, 22 August 2003 14:04  |
--------------91A69E549F2D0AE4F1048F5F
Content-Type: text/plain; charset=us-ascii
Dedier,
If I load this schema in the sample editor
<?xml version="1.0"?>
<xs:schema targetNamespace="http:///simple/MySchema.xsd"
xmlns:abc="http:///simple/MySchema.xsd"
xmlns:xs="http://www.w3.org/2001/XMLSchema">
<xs:sequence>
<xs:element name="Characterization" type="xs:string"/>
</xs:sequence>
</xs:complexType>
<xs:element name="Lib">
<xs:complexType>
<xs:complexContent>
<xs:sequence>
<xs:element minOccurs="0" name="Port"
type="abc:TaxonomyNodeType"/>
<xs:element minOccurs="0" name="Opt"
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:element>
</xs:schema>
it shows in the "Semantics" view like this:
[Image]
so it appears to be taking the base type into account properly, i.e., there is a
sequence containing the sequence from the base type and the sequence from the
derived type.
Can you elaborate on what are you doing to draw your conclusions?
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:element>
> Any suggestions?
> cheers
> Didier
Content-Type: multipart/related;
boundary="------------8D81936A571BB4684566B8E7"
--------------8D81936A571BB4684566B8E7
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Dedier,
<p>If I load this schema in the sample editor
<blockquote><tt><?xml version="1.0"?></tt>
<br><tt><xs:schema targetNamespace="<A HREF="http:///simple/MySchema.xsd">http:///simple/MySchema.xsd</A>"</tt>
<br><tt> xmlns:abc="<A HREF="http:///simple/MySchema.xsd">http:///simple/MySchema.xsd</A>" xmlns:xs="<A HREF="http://www.w3.org/2001/XMLSchema">http://www.w3.org/2001/XMLSchema</A>"></tt>
<br><tt> <xs:complexType name="TaxonomyNodeType"></tt>
<br><tt> <xs:sequence></tt>
<br><tt>
<xs:element name="Characterization" type="xs:string"/></tt>
<br><tt> </xs:sequence></tt>
<br><tt> </xs:complexType></tt>
<br><tt> <xs:element name="Lib"></tt>
<br><tt> <xs:complexType></tt>
<br><tt>
<xs:complexContent></tt>
<br><tt>
<xs:extension base="abc:TaxonomyNodeType"></tt>
<br><tt>
<xs:sequence></tt>
<br><tt>
<xs:element minOccurs="0" name="Port" type="abc:TaxonomyNodeType"/></tt>
<br><tt>
<xs:element minOccurs="0" name="Opt" type="abc:TaxonomyNodeType"/></tt>
<br><tt>
</xs:sequence></tt>
<br><tt>
</xs:extension></tt>
<br><tt>
</xs:complexContent></tt>
<br><tt> </xs:element></tt>
<br><tt></xs:schema></tt></blockquote>
<blockquote><img SRC="cid:part1.3F465B30.6605DD@ca.ibm.com" height=162 width=230></blockquote>
is a sequence containing the sequence from the base type and the sequence
from the derived type.
<p>Can you elaborate on what are you doing to draw your conclusions?
<br>
<p>"D. Hooven" wrote:
<blockquote TYPE=CITE>hi, i defined the following complextype:
<p><xs:complexType name="TaxonomyNodeType">
<br> <xs:sequence>
<br> <xs:element name="Characterization"
<br>type="abc:CharacterizationType"/>
<br> </xs:sequence>
<br></xs:complexType>
<p>and refer to it like this:
<p><xs:element name="Lib" minOccurs="0">
<br> <xs:complexType>
<br> <xs:complexContent>
<br> <xs:extension base="abc:TaxonomyNodeType">
<br> <xs:sequence>
<br> <xs:element
<br> <xs:element
<br> </xs:sequence>
<br> </xs:extension>
<br> </xs:complexContent>
<br> </xs:complexType>
<br></xs:element>
<p>As you see the second type refers uses the first type as a base type.
<br>The sequence of the base type is included correctly when loaded.
<br>The elements within the sequence of the extension are ignored.
<br>The sequence exists but it is empty.
<br>Any suggestions?
<p>cheers
<br> Didier</blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.3F465B30.6605DD@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailJB.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CACiAOYDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDdkcomQMnIABOOpxTN0iHL ImGYZw3rgelP
lUsmFxkEHn2OarpaorfuraCI5GWQYOMg+lAFiUlYnYdQpIqpPeRwXAheWTcc E4C8Z/U/hmrT
xjynCKASpAwPb/8AVVaSAvcecI50YgBtrgbgDxnmmrdRMsQsxMgYk7WwCfoK hF4WvWt1EOVY
DDS4YjAJIXHv69qmgDDzCyldzZAJHoKYsMyXEjpLGEkcMVMZJ6Adc+3pSGNt 71JIoS5w7opO
FO0EgHGeg69Ce49adHe28m3azfNjBKMOvTqO/b17VBDpixPGcxttC5ZogWyo A4PYcDt6809L
HaiL5mdqRLnb/cbP60ASG9twpbc2BjHyN82SB8vHzckdM9RSfbYzNHGoc7w3 8DZUgrwRjI+9
1P8AWoYtMWIBVMahSuCsQDEBgfmPc8e30qYWpW6adJAGZiSCuRtIUEdevyDn 9KAJYp0mz5e4
gdypAP0J6/hUlV7S2Nvvyy/NjCIpVF+i5OOvNWKACiiigAooooAKKKKACiii gAooooAKKKKA
CiiigAooooAKKKKACmr95/r/AEFOpq/ef6/0FADqh3SOcqiYVjjLemR6VNVR rVXJMltbynJw
z8nBJPp70AWI3LpkjByQQDnocVBc3AgSSSSRlVWCgKB3A9aljiAT94qliST3 6k/41Dcw+crx
tG5BYMGVgCCAPX6U0JhBcCbynR2KsxUhsdgfSp5ZfLeFcZ8x9uc9PlJ/pUMU bhogVkwrElnY
E8g1JcQvKYmjdUaN9wLLuB4I9R60MERPehLvyiCVAbOxGY5AQjoP9r+X0q0r B1DKQykZBB4I
qp9kmW4M6TRhznOYyRyEH97/AGP1qzDGIYY4lJKooUZ64ApDH0UUUAFFFFAB RRRQAUUUUAFF
FFABRRRQAUUUUAFFFFABRRRQAUUUUAFNX7z/AF/oKdTV+8/1/oKAHUUUUAFR u7B1VFBJBPJx
0x7e9SVDPF5pGY45FwQVfoeQfQ+lACxs6ssbKo+Xgg56Y9h60s0hjiLqu4jH H41HDbrG42wx
RoAflTueOeg9KbdwFlDRopCK3y468DH8qT8gI7Mxzb0a3UNGBkkZJz+FT2wC tMoGAJOAO3Aq
tZmRFdhatuJAz93IA44Y1at1ceYzrsLvkAnPYD+lOzW4lsQy3pXT0uVVQ0kZ dVYk87C2Pfp7
VYinSbOzcCOoZSp/I1UOnyPaJbyToVjXapWMg42FeeffP4VMFlhZpnUzyOAu IlCgAZP8Te57
+lAyzUNxcC3MW5WYO+35QSRwT0A56UK8rfvDHIgUEeUduWPGDkH6j8ajbzbh kxDJA0Z3q0m1
lzgjBAbPQmgCR7qFI/MZ8Lllzg9Vzn/0E/lSfa4dpOXBBxtMbBj9Fxk9D27H 0qC4tWkF66p8
zxlEGfvEqMn8cKP+A+9LLYmc75njeTIxmL5MDd1Unn7x7+n4gFuN1kQOhyDT qjgiEMKxjbx/
dUKPXgDpUlABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTV+8/wBf6CnU1fvP 9f6CgB1FFFAB
RRRQAU2RtkbPjO0E4p1MlUvE6jqykDNAELTOjyfIhZEDMAx6c47exqzVE2am aWRbeFZHXG7P
Trz93qc8/hVqSING4VVDEEA478/4mgCnJOPtQEluGDMIwWPTnr0qw8aRzwbE VcsQcDGflNUx
G6XaobbeAQ2VBAyBkc9OtW8yyzRFoSgQkklgexHb60kn1ELcTTRSxLHFG4kO 0FpCuDgn0PYU
9riNZCjbwwGfuNg8ZwDjk+wpZYvMeFs48t92MdflI/rVY2JF0J1ePcrMwZos uSQRgtnkDPT0
AFMZObqEAkPuHH3AWzkZGMdeOeO3NNN7bggbm6bidjYUZI5OOOh69MU37Iyh fLl5R96l1z8x
BDZxjOck9sH24posf3U6+ZzNGUJ29CSxJ/NuntQBK15Ahfc5AQEk7TjjqAcY JGDwPQ+lJ9tt
wCSzKFBJ3IwxgZxyOuOcdcc1FLYGVHjMoEZLso28hmDA5OeR8x4wO1S/Zf3/ AJm//lr5mMf7
GzH9aAG3d6tsyrt3HI3842rhiW9+FPFON2ivIjhso+0BVLE/KDnAH+1/nNR2 1nsigJGxlfzC
vXHylQufYYGe+Pemw2D27Fopl3ZIXcmQEIUAdR02jnNAEk96ihBEd5Z0GQpK 4YjuOBwc9fSn
i5WUEQYd8ZUPlQw9Qccj3Ge3rUIsDGqxxSgRBkYhlyxK7e+R/dHb1p1nYrat lRHgLtBWMKxH
+0e549v8AB9rcmaOJpFVGlTeqhi3y8d8D1FCXtvIwCMxzj5tjBeQCOcY7j86 jks82lvbY3hM
KzdMAKQePcZHtuz2oFtK9xMWZVhaVXA2/McBe+eOV9KAJ4riKZtqMScZGVID D1BPUe49RUtV
LOxW1bKiPAXaCsYViP8AaPc8e3+FugAooooAKKKKACmr95/r/QU6mr95/r/Q UAOooooAKKKK
ACmyNsjZ8Z2gnFOpkql4nUdWUgZoAjdpUDyGNOF5w/p+FSSsyxOyDLBSQPU1 Xa1Ul2W1t1kY
H5x1yepzirOxQchRn1x/n1P50AU0vzHEGukKMzEABSOOOefrV6obi3W4aPef lQ5K461HBDcJ
dySSSboznau4nHPHFAdiZ50SRYzuLN2VS2Prjp+NMF5AQTvOAMjKkbh/s8fN 1HTPUetJNbGW
4SUMqbcZKqQ5wc43Z6e2Kgi0xYk2qY12gbGWIA8EEbj36Dpjv7YALMV1FM+x C27n5WQqeMZ6
j/aH50i3kDlNrkhwCDtOOegJxgE5HB9R61BHa3AmlmMkYl3nDbMqVKp23ZHK +vrSQ6YsTxnM
bbQuWaIFsqAOD2HA7evNAE6Xtu6bwzAY3DcjDcPbI56jp6j1pTdwqAWLjIyc xsNo9W4+UcHk
46VEbH91AvmcwxhAdvUgqQfzXp70k1gZ3Ekphdyu1i0OeAT93JODz3z2oAu0 UUUAFFFFABRR
RQAUUUUAFFFFABRRRQAU1fvP9f6CnU1fvP8AX+goAdRRRQAUUUUAFFFFABRR RQBCzO7MqopC
sOS30PpT43LbgygFTjg57A/1qCa3V3YyQQzAtld/JHAHofSpIYQoO5EHI2he QBge3tQBC9zM
l4UaP9woJL7T0xnrU9vcJcxl484Bwc09l/dlVwvGBxwPwqlLZSpBHHaybMZ3 HcQSeOeKOgbI
uyOsaF3OAKiN3CoBYuMjJzGw2j1bj5RweTjpT54/OhaPEZz2kTcv4iqjaaG2 lnSRtu1mlj3n
GSflyeOp656D05AJ3vbeNiHZhjPzbGK8Ak84x2P5U+S4iiYqzHcADtCkk5zj AHXofyqrPZSO
Uj3g25dywC4Zdytk5z6t6Uslg87mSeSJ2+XaDF8vG7qCefvHuOgoAmN7bggb m6bidjYUZI5O
OOh69MU43UQLjLfJ1Ow4znGAcYJzxgc5qEWAEM0YdV82Ly/lQAL945AH+909 uppXsy8ckJdD
CzFwpTJ3bt3PPIz2wOO9AFiKVJV3ITwcEEEEH3B5FPqG1gFvGVAjGTkiNAi/ gKmoAKKKKACi
iigAooooAKKKKACmr95/r/QU6mr95/r/AEFADqKKKACiiigAooooAKKKKAGv yo+o/nTqa/Kj
6j+dOoAZI5XaFUEsccnHYn+lRRSk7cKu1nZcg9CM57DuDT54zIFG1WAPKt0I wR/WoILNYcBI
YkUsWbHU5zx0HAz+VAFmUkJwcHIGfxqp9sj+1/ZvNk3g7ScLjP8AP8cYq1In yHYmTkHjvzn/
ABqssBW4aZY513HcyCQBScYz1pqwmWYGLxZY5OSP1NMWaSR/3UaGIMVLM5By Dg4GD/Tp+NOt
1ZYgGGDknH4mmrDJG/7qRBEWLFWQk5JycHI/r1/CkMZaXqz26O24OYw7LsYZ 45256/hntTxe
QFkXeQ7kgKVIORjtjI6g/TnpURscwwx+Z/qovL+7w33eo9Pl5HcGi1sfs8xk 3R87vljj2qM7
egyf7v60ATG6iBcMWUr2ZCM844455x0z1HrTFvYzMUIdVCB9zIwAGWznI4+7 3qBdMxJu3xgg
YDCPDMdysCxz83K89OpqZ7V5N/mSqfNj8uTamMjnGOePvH1oAcb23ABZmUk7 QrIwJOCRwRnn
Bx69KBeRAgNuGXKAhGK53FeuMDmo4bERuj/ulKvuxFEEB+Vh6/7X6UqWkiTK yzIUDM21kJwW
Yk4564OM8/qaAHTXscQbhyysAVKMCQWAJHHOM9vb1pftkQLZ3ZBwFVGLdAeR jI6j9PpVddMx
Ju3xggYDCPDMdysCxz83K89OpqUWkizNMkyCVickoSuCFB4z/sDvQBILyBpN iuTyBuCnbkgE
fNjHOR371PVSOxEcJiVzt3xsMjnCheP/AB39at0AFFFFABTV+8/1/oKdTV+8 /wBf6CgB1FFF
ABRRRQAUUUUAFFFFAELM7syqikKw5LfQ+lPjctuDKAVOODnsD/WoZbZZHYyQ QygnI8ztwB6H
0p8MIUHciDkbQvIAwPb2oAhe5mS8KNH+4UEl9p6Yz1qe3uEuYy8ecA4Oaey/ uyq4XjA44H4V
SlspUgjjtZNmM7juIJPHPFHQNkXZHWNC7nAFRG7hUAsXGRk5jYbR6tx8o4PJ x0p88fnQtHiM
57SJuX8RVRtNDbSzpI23azSx7zjJPy5PHU9c9B6cgE73tvGxDswxn5tjFeAS ecY7H8qfJcRR
MVZjuAB2hSSc5xgDr0P5VVnspHKR7wbcu5YBcMu5Wyc59W9KWSwedzJPJE7f LtBi+Xjd1BPP
3j3HQUATG9twQNzdNxOxsKMkcnHHQ9emKcbqIFxlvk6nYcZzjAOME54wOc1C LACGaMOq+bF5
fyoAF+8cgD/e6e3U0r2ZeOSEuhhZi4Upk7t27nnkZ7YHHegCxFKkq7kJ4OCC CCD7g8in1Daw
C3jKgRjJyRGgRfwFTUAFFFFABRRRQAUUUUAFFFFABTV+8/1/oKdTV+8/1/oK AHUUUUAFFFFA
BRRRQAUUUUAFFFFADJHK7Qqgljjk47E/0qKKUnbhV2s7LkHoRnPYdwafPGZA o2qwB5VuhGCP
61Bb2iRYCQxou9mbHU9eOg4549qALMpITg4OQM/jVT7ZH9r+zebJvB2k4XGf 5/jjFSXjiFEI
McYd8NI4+VepyeR39+9QwrHk3Ik8uRl8x4jLtAbaM54z3Gfwpq3URcgYvFlj k5I/U1Al4d2Z
URIi7oH385XdyRjgfKe9PsZBNZQyDb86hjtPAJ6/rmmrYQiKZSq7pt4aRVAb DEnGfx/SkMcb
23ABZmUk7QrIwJOCRwRnnBx69Kdb3AnD4VlKOynIODgkcHHPTtUYtXNwk8sq s6kfdTAIAYDu
f75qWCIw7xuBQsWUY5BJJOT35NAEtFFFABRRRQAUUUUAFFFFABRRRQAU1fvP 9f6CnU1fvP8A
X+goAdRRRQAUUUUAFFFFABRRRQAUUUUAMkcrtCqCWOOTjsT/AEqKKUnbhV2s 7LkHoRnPYdwa
fPGZAo2qwB5VuhGCP61BBZrDgJDEilizY6nOeOg4GfyoAsykhODg5Az+NVPt kf2v7N5sm8Ha
ThcZ/n+OMVJeOIUQgxxh3w0jj5V6nJ5Hf371DCseTciTy5GXzHiMu0Btoznj PcZ/CmrdRFyB
i8WWOTkj9TUTXRAeQRg28ZId93PHBIGOQPr2OAeMrYyCayhkG351DHaeAT1/ XNI1qSHjEgFv
ISXTbzzyQDngH6dzgjjCGJLfxJHKy7mMYY4KlQxXOQCRg9D09KsRuJEDKGAP 95Sp/I1SWykl
jaOdwI98hVVX5vmLDOckdGPb0q7GHCASMrN3Krgflk0AOooooAKKKKACiiig AooooAKKKKAC
kAAzgdetFFAC0UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFAH/2Q==
--------------8D81936A571BB4684566B8E7--
--------------91A69E549F2D0AE4F1048F5F--
| Re: sequence in extesion type ignored [message #576115 is a reply to message #26547] |
Ed Merks Messages: 24550 Registered: July 2009 |
Dedier,
<xs:sequence>
</xs:sequence>
</xs:complexType>
<xs:complexType>
<xs:complexContent>
<xs:sequence>
</xs:sequence>
</xs:extension>
</xs:complexType>
</xs:element>
</xs:schema>
[Image]
derived type.
> <xs:sequence>
> </xs:sequence>
> </xs:complexType>
> <xs:complexType>
> <xs:complexContent>
> <xs:sequence>
> </xs:sequence>
> </xs:extension>
> </xs:complexType>
> </xs:element>
> Any suggestions?
> cheers
> Didier
<html>
Dedier,
<br><tt>
<br><tt>
<br><tt>
<br><tt>
<xs:sequence></tt>
<br><tt>
<br><tt>
<br><tt>
</xs:sequence></tt>
<br><tt>
<br><tt>
<br>
<br> <xs:sequence>
<br> </xs:sequence>
<br> <xs:sequence>
<br> <xs:element
<br> <xs:element
<br> </xs:sequence>
<br></xs:element>
<p>cheers
</html>
FUDForum. Page generated in 0.25951 seconds
