| Schedule Nightly Product Exports - Eclipse 3.4SDK [message #260539] |
Wed, 09 July 2008 12:51  |
Originally posted by: ron.byressecurity.com
Hello all,
I have searched google far and wide, and I can't find any material that
seems appropriate for my situation. My situation is the following, I am
not a java programmer, but I am the lucky IT guy whose task is to sent up
a system that automates the product exports from eclipse. I set up the
current developer environment and was taught how they do their export.
Basically the current setup, they have a .product file in one particular
package, and they export from there using a wizard. Overall there are 25+
packages in the same workspace, yet I cannot find a simple way to schedule
exports on a nightly basis. ANT might work, but over multiple packages, I
have yet to see any simple documentation or a good howto. Are there
plugins that can schedule this? or can you pass eclipse on startup to run
the export?
Any help, suggestions would be great!
Ron
| Re: Schedule Nightly Product Exports - Eclipse 3.4SDK [message #260598 is a reply to message #260548] |
Wed, 09 July 2008 17:02  |
AN output of this results:
C:\Documents and Settings\Administrator\Desktop>java -cp "C:\Documents and
Setti
ngs\Administrator\Desktop\eclipse-SDK-3.4-win32\eclipse\plug ins
\org.eclipse.equ
inox.launcher_1.0.100.v20080509-1800.jar" org.eclipse.core.launcher.Main
-appli
cation org.eclipse.ant.core.antRunner -buildfile "C:\Documents and
Settings\Admi
nistrator\Desktop\eclipse-SDK-3.4-win32\eclipse\plugins\org. eclipse.pde.build_3.
4.0.v20080604\scripts\productBuild\productBuild.xml"
-Dbuilder="C:\buildconfig"
Buildfile: C:\Documents and
Settings\Administrator\Desktop\eclipse-SDK-3.4-win32
\eclipse\plugins\org.eclipse.pde.build_3.4.0.v20080604\scrip ts\productBuild\prod
uctBuild.xml
main:
preBuild:
preSetup:
checkLocalMaps:
getMapFiles:
[concat] No existing resources and no nested text, doing nothing
postSetup:
checkLocalBase:
getBaseComponents:
generateFeature:
fetch:
generateFeature:
BUILD FAILED
C:\Documents and
Settings\Administrator\Desktop\eclipse-SDK-3.4-win32\eclipse \pl
ugins\org.eclipse.pde.build_3.4.0.v20080604\scripts\productB uild\productBuild.xm
l:25: The following error occurred while executing this line:
C:\Documents and
l:53: Incorrect directory entry: C:Documents and
SettingsAdministratorDesktopecl
ipse-SDK-3.4-win32eclipse.
Total time: 1 second
C:\Documents and Settings\Administrator\Desktop>pause
Press any key to continue . . .
FUDForum. Page generated in 0.05328 seconds
