Home » Eclipse Projects » SWTBot » Recent Junit 4.5 issues and some explanations
Recent Junit 4.5 issues and some explanations [message #24880] Fri, 27 February 2009 23:06
Ketan Padegaonkar is currently offline Ketan Padegaonkar
I've been very busy for the last few weeks to provide any support on the
forums and spend time on SWTBot in general.
The short story:
I've just fixed all junit 4.x related issues. Revision 176 on the update
site is a good build that's been tested for good measure, please do test
it out and provide feedback.
The long story:
The recent issues were caused because of conflicting API on junit 4.3
and 4.5 available with eclipse 3.4 and 3.5 respectively.
SWTBot tried to be intelligent enough to resolve these issues using some
internal hacks using the update site etc. (Hey I'm lazy to do it the
hard way) but that did not work as expected.
I've now simplified the process which means a bit more work when
publishing builds. There will now be two update sites: one for eclipse
3.3/3.4 and another for 3.5.
I've currently pushed builds that'll work with eclipse 3.3/3.4 with
JUnit 4.3. Next I'll push builds based on 3.5 when I'm done with some
bit of automation around being able to generate two artifacts as part of
one build process.
-- Ketan
Previous Topic:Need help for using swtbot for automating an exe flow
Next Topic:How to identify keystroke
Current Time: Wed May 22 02:46:34 EDT 2013
Powered by FUDForum. Page generated in 0.01553 seconds
