| FlowLayout questions [message #247127] |
Thu, 05 February 2009 03:01  |
Sebastian Bota Messages: 8 Registered: July 2009 |
Junior Member |
Hello every one. I have a nice graphical editor used to edit C/c++ source
code in a nassy schniderman diagram way. ok, my problem is as follows.
i will try to draw a simple scenario and explain what my problems are:
supose we have :
| label here |
|if i enter a long label here|
| | | <= this wont resize
I hope you understand what i mean. So all children from the same level
will be resized but inner children of another figure wont be resized. Why
Can anyone help me please on this issue ?
Thank you very much.
| Re: FlowLayout questions [message #247140 is a reply to message #247127] |
Thu, 05 February 2009 04:06   |
Originally posted by: lifesting.gmail.com
> source code in a nassy schniderman diagram way. ok, my problem is as
> follows.
> supose we have :
> | label here | |if i enter a long label here|
> | | | | | | <= this wont resize
> Why ?
Hi, Sebastian.
Every Figure(label is derived from Figure) can register FigureListener
to notify other figure(here, your if/else part) that its bound has been
changed. Code demo:
class WholeEditPart
Figure labelFigure;
Figure ifelseFigure;
public FigureListener resize = new FigureListener()
pubic void figureMoved(Figure label)
resizeIfElsePart(label.getBounds());
private resizeIfElsePart(Rectangle r)
..... resize here
protected void createFigure()
labelFigure = ...;
ifelseFigure = ...;
labelFigure.addFigurListener(resize);
protected void deactivate()
labelFigure.removeListener(resize);
| Re: FlowLayout questions [message #247164 is a reply to message #247145] |
Fri, 06 February 2009 03:00  |
Junior Member |
Hello i have tryed your ideea but i does not work. I forgot to mention that
i use flow layout ..
Mabye this helps ....
"Sebastian Bota" <sebastian.bota@hotmail.com> wrote in message
news:gmebj5$mq7$1@build.eclipse.org...
> Thank you i will try this and come back to you.
> "David BY Chan" <lifesting@gmail.com> wrote in message
> news:gmea62$5ce$1@build.eclipse.org...
>>> follows.
>>> supose we have :
>>> | | | | | | <= this wont resize
>>> Why ?
>> Hi, Sebastian.
>> Every Figure(label is derived from Figure) can register FigureListener to
>> changed. Code demo:
>> class WholeEditPart
>> Figure labelFigure;
>> ..... resize here
>> labelFigure = ...;
>> ifelseFigure = ...;
FUDForum. Page generated in 0.02438 seconds
