Home » Eclipse Projects » GEF » [GEF] bug and crash under linux
| [GEF] bug and crash under linux [message #243187] |
Wed, 28 May 2008 06:03  |
Originally posted by: ftordi.smaeur.com
Hi there,
I have some problems with GEF and Draw2d. When I draw figures with
gradient header. My application crashes when a figure with a gradient
header has a size greater than 65535px. So I have another problem like
this I have an alternation between painted or not. It's as if the
application repaint is not made because if I move a window over the
figure. White zone is brushed.
a link to the capture. The capture is made without the gradient header to
the figure to avoid crash.
I there a way to avoid this or I must block size over 65535.
The "grey area" happens before the 65535 value but I don't really know
when exactly
Fabien
http://dl.free.fr/ekzNDdm8w/Capture-1.png
When the application crashed I have a java error : there is the dump of
the error
# An unexpected error has been detected by Java Runtime Environment:
# SIGFPE (0x8) at pc=0x9bfcaab0, pid=10594, tid=3084868496
# Java VM: Java HotSpot(TM) Server VM (10.0-b22 mixed mode linux-x86)
# Problematic frame:
# C [libgdk_pixbuf-2.0.so.0+0x10ab0]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x08059000): JavaThread "main" [_thread_in_native,
id=10598, stack(0xb7da5000,0xb7df6000)]
siginfo:si_signo=SIGFPE: si_errno=0, si_code=1 (FPE_INTDIV),
si_addr=0x9bfcaab0
Registers:
EAX=0x00007fff, EBX=0x9bfd1b70, ECX=0x00000000, EDX=0x00000000
ESP=0xb7df2510, EBP=0xb7df26b8, ESI=0x00000010, EDI=0x00000010
EIP=0x9bfcaab0, CR2=0xb7f9c000, EFLAGS=0x00010256
Top of Stack: (sp=0xb7df2510)
0xb7df2510: 855477ee c0dfffee 00000000 9c46c324
0xb7df2520: 9a9261bc 40df2618 b7df2548 9c45fb5e
0xb7df2530: 9bfd1b70 994826e0 b7df2578 b7f838c5
0xb7df2540: 9b2a11d8 9a377540 b7e87d91 9b29eed5
0xb7df2550: 00000003 9c2ff248 b7df25b8 b7f838c5
0xb7df2560: 9b2a11d8 00000001 b7f80531 9b29eed5
0xb7df2570: 00000003 9c300040 00000010 00000008
0xb7df2580: 00000021 9bfcdb08 99cb1608 99cb13f0
Instructions: (pc=0x9bfcaab0)
0x9bfcaaa0: fa 01 0f 8e b2 05 00 00 83 ea 01 89 d0 c1 fa 1f
0x9bfcaab0: f7 f9 8b 7d 08 89 c6 2b bd 04 ff ff ff 2b b5 04
Stack: [0xb7da5000,0xb7df6000], sp=0xb7df2510, free space=309k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native
code)
C [libgdk_pixbuf-2.0.so.0+0x115d2]
C [libgdk_pixbuf-2.0.so.0+0xae60] gdk_pixbuf_scale+0x150
C [libgdk_pixbuf-2.0.so.0+0xaf82] gdk_pixbuf_scale_simple+0xd2
C [libswt-pi-gtk-3442.so+0x35d1d]
Java_org_eclipse_swt_internal_gtk_OS__1gdk_1pixbuf_1scale_1s imple+0x24
v ~BufferBlob::Interpreter
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.eclipse.draw2d.Figure.paintChildren(Lorg/eclipse/draw2d/ Graphics;)V
J
org.eclipse.swt.widgets.EventTable.sendEvent(Lorg/eclipse/sw t/widgets/Event;)V
v ~BufferBlob::StubRoutines (1)
J org.eclipse.draw2d.DeferredUpdateManager.repairDamage()V
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x09212400 JavaThread "Worker-3" [_thread_blocked, id=12066,
stack(0x9a121000,0x9a172000)]
0x08147c00 JavaThread "Worker-2" [_thread_blocked, id=11617,
stack(0x9a444000,0x9a495000)]
0x08f3fc00 JavaThread "Worker-1" [_thread_blocked, id=11454,
stack(0x9a25e000,0x9a2af000)]
0x98fa3c00 JavaThread "Worker-0" [_thread_blocked, id=11425,
stack(0x9a2af000,0x9a300000)]
0x9a7a5000 JavaThread "PoolManagerCleanup-6026788" daemon
[_thread_blocked, id=11278, stack(0x9a495000,0x9a4e6000)]
0x9a97dc00 JavaThread "jTDS TimerThread" daemon [_thread_blocked,
id=11157, stack(0x9a80d000,0x9a85e000)]
0x9c318c00 JavaThread "PoolManagerCleanup-27994965" daemon
[_thread_blocked, id=11150, stack(0x9a85e000,0x9a8af000)]
0x9a966c00 JavaThread "PoolManagerCleanup-5761618" daemon
[_thread_blocked, id=11148, stack(0x9a8af000,0x9a900000)]
0x9c321400 JavaThread "EventDispatchThread-1" daemon [_thread_blocked,
id=11136, stack(0x9aa1a000,0x9aa6b000)]
0x9acffc00 JavaThread "EventDispatchThread-0" daemon [_thread_blocked,
id=11135, stack(0x9aa6b000,0x9aabc000)]
0x9c315400 JavaThread "EventDispatchThread-4" daemon [_thread_blocked,
id=11116, stack(0x9aabc000,0x9ab0d000)]
0x9c314400 JavaThread "EventDispatchThread-3" daemon [_thread_blocked,
id=11115, stack(0x9ab0d000,0x9ab5e000)]
0x9c305400 JavaThread "EventDispatchThread-2" daemon [_thread_blocked,
id=11114, stack(0x9ab5e000,0x9abaf000)]
0x9c305000 JavaThread "EventDispatchThread-1" daemon [_thread_blocked,
id=11113, stack(0x9abaf000,0x9ac00000)]
0x9c306000 JavaThread "EventDispatchThread-0" daemon [_thread_blocked,
id=11112, stack(0x9ad28000,0x9ad79000)]
0x9c3ce400 JavaThread "Start Level Event Dispatcher" daemon
[_thread_blocked, id=10701, stack(0x9b55e000,0x9b5af000)]
0x9c3eb800 JavaThread "Framework Event Dispatcher" daemon
[_thread_blocked, id=10700, stack(0x9b5af000,0x9b600000)]
0x9c3bbc00 JavaThread "State Data Manager" daemon [_thread_blocked,
id=10687, stack(0x9b70e000,0x9b75f000)]
0x080fe400 JavaThread "Low Memory Detector" daemon [_thread_blocked,
id=10617, stack(0x9c518000,0x9c569000)]
0x080fcc00 JavaThread "CompilerThread1" daemon [_thread_blocked,
id=10616, stack(0x9c569000,0x9c5ea000)]
0x080fa400 JavaThread "CompilerThread0" daemon [_thread_blocked,
id=10615, stack(0x9c5ea000,0x9c66b000)]
0x080f9000 JavaThread "Signal Dispatcher" daemon [_thread_blocked,
id=10614, stack(0x9c66b000,0x9c6bc000)]
0x080dd400 JavaThread "Finalizer" daemon [_thread_blocked, id=10607,
stack(0x9c6fb000,0x9c74c000)]
0x080dc400 JavaThread "Reference Handler" daemon [_thread_blocked,
id=10606, stack(0x9c74c000,0x9c79d000)]
=>0x08059000 JavaThread "main" [_thread_in_native, id=10598,
Other Threads:
0x080d9000 VMThread [stack: 0x9c79d000,0x9c81e000] [id=10605]
0x080ffc00 WatcherThread [stack: 0x9c497000,0x9c518000] [id=10618]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
PSYoungGen total 22848K, used 2181K [0xb2fe0000, 0xb4c20000,
0xb4c50000)
eden space 19328K, 11% used [0xb2fe0000,0xb3201538,0xb42c0000)
from space 3520K, 0% used [0xb4610000,0xb4610000,0xb4980000)
to space 3392K, 0% used [0xb42c0000,0xb42c0000,0xb4610000)
PSOldGen total 20160K, used 10687K [0xa4c50000, 0xa6000000,
0xb2fe0000)
object space 20160K, 53% used [0xa4c50000,0xa56bffd8,0xa6000000)
PSPermGen total 131072K, used 23980K [0x9cc50000, 0xa4c50000,
0xa4c50000)
object space 131072K, 18% used [0x9cc50000,0x9e3bb138,0xa4c50000)
Dynamic libraries:
06000000-0665d000 r-xp 00000000 08:04 20178
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/server/libjvm. so
0665d000-066a1000 rwxp 0065c000 08:04 20178
066a1000-06ac3000 rwxp 066a1000 00:00 0
08048000-08052000 r-xp 00000000 08:04 20156
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/bin/java
08052000-08053000 rwxp 00009000 08:04 20156
08053000-09974000 rwxp 08053000 00:00 0 [heap]
97f63000-989e8000 rwxp 97f63000 00:00 0
989e8000-98a00000 ---p 989e8000 00:00 0
98a00000-98aff000 rwxp 98a00000 00:00 0
98aff000-98b00000 ---p 98aff000 00:00 0
98b00000-98bfd000 rwxp 98b00000 00:00 0
98bfd000-98c00000 ---p 98bfd000 00:00 0
98c50000-98c56000 r-xp 00000000 08:03 258806
/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.core/E nterpriseManager.product/org.eclipse.osgi/bundles/57/1/.cp/l ibswt-atk-gtk-3442.so
98c56000-98c57000 rwxp 00005000 08:03 258806
98c57000-98c5a000 rwxs 00000000 00:09 1081369 /SYSV00000000 (deleted)
98d00000-98efc000 rwxp 98d00000 00:00 0
98efc000-98f00000 ---p 98efc000 00:00 0
98f00000-98ffe000 rwxp 98f00000 00:00 0
98ffe000-99000000 ---p 98ffe000 00:00 0
99000000-99100000 rwxp 99000000 00:00 0
99100000-991fe000 rwxp 99100000 00:00 0
991fe000-99200000 ---p 991fe000 00:00 0
99200000-993f8000 rwxp 99200000 00:00 0
993f8000-99400000 ---p 993f8000 00:00 0
99400000-99600000 rwxp 99400000 00:00 0
99600000-996f9000 rwxp 99600000 00:00 0
996f9000-99700000 ---p 996f9000 00:00 0
99700000-99800000 rwxp 99700000 00:00 0
99800000-99900000 rwxp 99800000 00:00 0
99a00000-99abf000 rwxp 99a00000 00:00 0
99abf000-99b00000 ---p 99abf000 00:00 0
99c00000-99cfe000 rwxp 99c00000 00:00 0
99cfe000-99d00000 ---p 99cfe000 00:00 0
99d00000-99dfe000 rwxp 99d00000 00:00 0
99dfe000-99e00000 ---p 99dfe000 00:00 0
99e00000-99f00000 rwxp 99e00000 00:00 0
99f0b000-99f56000 r-xp 00000000 08:04 64834 /lib/libgcrypt.so.11.2.3
99f56000-99f58000 rwxp 0004a000 08:04 64834 /lib/libgcrypt.so.11.2.3
99f58000-99f61000 r-xp 00000000 08:04 82342
/lib/tls/i686/cmov/libcrypt-2.7.so
99f61000-99f63000 rwxp 00008000 08:04 82342
99f63000-99f8a000 rwxp 99f63000 00:00 0
99f8a000-99ffb000 r-xp 00000000 08:04 17051
/usr/lib/libgnutls.so.13.9.1
99ffb000-9a000000 rwxp 00071000 08:04 17051
9a000000-9a0fe000 rwxp 9a000000 00:00 0
9a0fe000-9a100000 ---p 9a0fe000 00:00 0
9a10f000-9a121000 r-xp 00000000 08:04 139143
/usr/share/fonts/type1/gsfonts/n019004l.pfb
9a121000-9a124000 ---p 9a121000 00:00 0
9a124000-9a172000 rwxp 9a124000 00:00 0
9a172000-9a181000 r-xp 00000000 08:04 82366
/lib/tls/i686/cmov/libresolv-2.7.so
9a181000-9a183000 rwxp 0000f000 08:04 82366
9a183000-9a185000 rwxp 9a183000 00:00 0
9a185000-9a1a7000 r-xp 00000000 08:04 18052
/usr/lib/libk5crypto.so.3.1
9a1a7000-9a1a8000 rwxp 00022000 08:04 18052
9a1a8000-9a233000 r-xp 00000000 08:04 18058 /usr/lib/libkrb5.so.3.3
9a233000-9a235000 rwxp 0008a000 08:04 18058 /usr/lib/libkrb5.so.3.3
9a235000-9a25d000 r-xp 00000000 08:04 17927
/usr/lib/libgssapi_krb5.so.2.2
9a25d000-9a25e000 rwxp 00028000 08:04 17927
9a25e000-9a261000 ---p 9a25e000 00:00 0
9a261000-9a2af000 rwxp 9a261000 00:00 0
9a2af000-9a2b2000 ---p 9a2af000 00:00 0
9a2b2000-9a3fc000 rwxp 9a2b2000 00:00 0
9a3fc000-9a400000 ---p 9a3fc000 00:00 0
9a401000-9a410000 r-xp 00000000 08:04 18302
/usr/lib/libtasn1.so.3.0.12
9a410000-9a411000 rwxp 0000e000 08:04 18302
9a411000-9a442000 r-xp 00000000 08:04 17677 /usr/lib/libcups.so.2
9a442000-9a444000 rwxp 00031000 08:04 17677 /usr/lib/libcups.so.2
9a444000-9a447000 ---p 9a444000 00:00 0
9a447000-9a495000 rwxp 9a447000 00:00 0
9a495000-9a498000 ---p 9a495000 00:00 0
9a498000-9a4e6000 rwxp 9a498000 00:00 0
9a4e6000-9a545000 r-xp 00000000 08:04 17100
/usr/lib/libgio-2.0.so.0.0.0
9a545000-9a547000 rwxp 0005e000 08:04 17100
9a547000-9a660000 r-xp 00000000 08:04 18367 /usr/lib/libxml2.so.2.6.31
9a660000-9a665000 rwxp 00119000 08:04 18367 /usr/lib/libxml2.so.2.6.31
9a665000-9a666000 rwxp 9a665000 00:00 0
9a666000-9a698000 r-xp 00000000 08:04 17667
/usr/lib/libcroco-0.6.so.3.0.1
9a698000-9a69b000 rwxp 00031000 08:04 17667
9a69b000-9a6cb000 r-xp 00000000 08:04 17921
/usr/lib/libgsf-1.so.114.0.7
9a6cb000-9a6ce000 rwxp 0002f000 08:04 17921
9a6ce000-9a6cf000 rwxp 9a6ce000 00:00 0
9a6cf000-9a6ff000 r-xp 00000000 08:04 18244
/usr/lib/librsvg-2.so.2.22.2
9a6ff000-9a700000 rwxp 00030000 08:04 18244
9a700000-9a7fb000 rwxp 9a700000 00:00 0
9a7fb000-9a800000 ---p 9a7fb000 00:00 0
9a80d000-9a810000 ---p 9a80d000 00:00 0
9a810000-9a85e000 rwxp 9a810000 00:00 0
9a85e000-9a861000 ---p 9a85e000 00:00 0
9a861000-9a8af000 rwxp 9a861000 00:00 0
9a8af000-9a8b2000 ---p 9a8af000 00:00 0
9a8b2000-9aa00000 rwxp 9a8b2000 00:00 0
9aa07000-9aa0a000 r-xp 00000000 08:04 64836 /lib/libgpg-error.so.0.3.0
9aa0a000-9aa0b000 rwxp 00002000 08:04 64836 /lib/libgpg-error.so.0.3.0
9aa0b000-9aa0d000 r-xp 00000000 08:04 64842 /lib/libkeyutils-1.2.so
9aa0d000-9aa0e000 rwxp 00001000 08:04 64842 /lib/libkeyutils-1.2.so
9aa1a000-9aa1d000 ---p 9aa1a000 00:00 0
9aa1d000-9aa6b000 rwxp 9aa1d000 00:00 0
9aa6b000-9aa6e000 ---p 9aa6b000 00:00 0
9aa6e000-9aabc000 rwxp 9aa6e000 00:00 0
9aabc000-9aabf000 ---p 9aabc000 00:00 0
9aabf000-9ab0d000 rwxp 9aabf000 00:00 0
9ab0d000-9ab10000 ---p 9ab0d000 00:00 0
9ab10000-9ab5e000 rwxp 9ab10000 00:00 0
9ab5e000-9ab61000 ---p 9ab5e000 00:00 0
9ab61000-9abaf000 rwxp 9ab61000 00:00 0
9abaf000-9abb2000 ---p 9abaf000 00:00 0
9abb2000-9ad00000 rwxp 9abb2000 00:00 0
9ad00000-9ad07000 r-xp 00000000 08:04 18060
/usr/lib/libkrb5support.so.0.1
9ad07000-9ad08000 rwxp 00006000 08:04 18060
9ad08000-9ad0a000 r-xp 00000000 08:04 64816 /lib/libcom_err.so.2.1
9ad0a000-9ad0b000 rwxp 00001000 08:04 64816 /lib/libcom_err.so.2.1
9ad0b000-9ad17000 r-xp 00000000 08:04 51250
/usr/lib/gtk-2.0/2.10.0/printbackends/libprintbackend-cups.s o
9ad17000-9ad18000 rwxp 0000b000 08:04 51250
9ad18000-9ad27000 r-xp 00000000 08:04 64806 /lib/libbz2.so.1.0.4
9ad27000-9ad28000 rwxp 0000f000 08:04 64806 /lib/libbz2.so.1.0.4
9ad28000-9ad2b000 ---p 9ad28000 00:00 0
9ad2b000-9ad79000 rwxp 9ad2b000 00:00 0
9ad79000-9ae00000 r-xp 00000000 08:04 139075
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans-Bold.ttf
9ae00000-9afdf000 rwxp 9ae00000 00:00 0
9afdf000-9b000000 ---p 9afdf000 00:00 0
9b000000-9b0c1000 rwxp 9b000000 00:00 0
9b0c1000-9b100000 ---p 9b0c1000 00:00 0
9b101000-9b104000 r-xp 00000000 08:04 51251
/usr/lib/gtk-2.0/2.10.0/printbackends/libprintbackend-file.s o
9b104000-9b105000 rwxp 00002000 08:04 51251
9b105000-9b108000 r-xs 0001c000 08:03 289760
/home/fab/worspace/com.sma.ui.pert/lib/org.eclipse.zest.layo uts_1.0.0.v20080226.jar
9b108000-9b112000 r-xp 00000000 08:03 258815
/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.core/E nterpriseManager.product/org.eclipse.osgi/bundles/57/1/.cp/l ibswt-cairo-gtk-3442.so
9b112000-9b113000 rwxp 00009000 08:03 258815
9b113000-9b114000 r-xp 00000000 08:04 48693
/usr/lib/gtk-2.0/2.10.0/loaders/svg_loader.so
9b114000-9b115000 rwxp 00000000 08:04 48693
9b115000-9b118000 r-xp 00000000 08:04 197692
/usr/share/locale-langpack/fr/LC_MESSAGES/atk10.mo
9b118000-9b11d000 r-xp 00000000 08:04 51226
/usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-gif.so
9b11d000-9b11e000 rwxp 00005000 08:04 51226
9b11f000-9b121000 r-xp 00000000 08:04 49528
/usr/lib/pango/1.6.0/modules/pango-basic-fc.so
9b121000-9b122000 rwxp 00001000 08:04 49528
9b122000-9b1b3000 r-xp 00000000 08:04 139076
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
9b1b3000-9b1b9000 r-xs 00000000 08:04 348192
/var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-x86.c ache-2
9b1b9000-9b1bc000 r-xs 00000000 08:04 348202
/var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-x86.c ache-2
9b1bc000-9b1bd000 r-xs 00000000 08:04 348194
/var/cache/fontconfig/c69f04ab05004e31a6d5e715764f16d8-x86.c ache-2
9b1bd000-9b1be000 r-xs 00000000 08:04 348187
/var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-x86.c ache-2
9b1be000-9b1c1000 r-xs 00000000 08:04 348193
/var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-x86.c ache-2
9b1c1000-9b1c4000 r-xs 00000000 08:04 348189
/var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-x86.c ache-2
9b1c4000-9b1c7000 r-xs 00000000 08:04 348199
/var/cache/fontconfig/de156ccd2eddbdc19d37a45b8b2aac9c-x86.c ache-2
9b1c7000-9b1cf000 r-xs 00000000 08:04 348203
/var/cache/fontconfig/e3de0de479f42330eadf588a55fb5bf4-x86.c ache-2
9b1cf000-9b1d7000 r-xs 00000000 08:04 348182
/var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-x86.c ache-2
9b1d7000-9b1d8000 r-xs 00000000 08:04 348185
/var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-x86.c ache-2
9b1d8000-9b1db000 r-xs 00000000 08:04 348200
/var/cache/fontconfig/de9486f0b47a4d768a594cb4198cb1c6-x86.c ache-2
9b1db000-9b1e2000 r-xs 00000000 08:04 348197
/var/cache/fontconfig/d52a8644073d54c13679302ca1180695-x86.c ache-2
9b1e2000-9b1e8000 r-xs 00000000 08:04 348181
/var/cache/fontconfig/089dead882dea3570ffc31a9898cfb69-x86.c ache-2
9b1e8000-9b1ea000 r-xs 00000000 08:04 350123
/var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-x86.c ache-2
9b1ea000-9b24a000 rwxs 00000000 00:09 1048600 /SYSV00000000 (deleted)
9b24a000-9b24b000 r-xp 00000000 08:04 51240
/usr/lib/gtk-2.0/2.10.0/immodules/im-cedilla.so
9b24b000-9b24c000 rwxp 00000000 08:04 51240
9b24c000-9b24f000 r-xs 00027000 08:04 20305
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/ext/sunjce_provider .jar
9b24f000-9b255000 r-xs 00091000 08:04 20304
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/jsse.jar
9b255000-9b27a000 r-xs 001d0000 08:03 257543
/home/fab/worspace/com.sma.core/lib/cayenne-server-3.0M3.jar
9b27a000-9b280000 r-xs 0004f000 08:03 257547
/home/fab/worspace/com.sma.core/lib/velocity-1.3.jar
9b280000-9b283000 r-xs 00045000 08:03 257549
/home/fab/worspace/com.sma.core/lib/jtds-1.2.2.jar
9b283000-9b287000 r-xs 0002f000 08:03 257546
/home/fab/worspace/com.sma.core/lib/commons-lang-2.1.jar
9b287000-9b294000 r-xs 0007c000 08:03 257544
/home/fab/worspace/com.sma.core/lib/commons-collections-3.1. jar
9b294000-9b298000 r-xs 00017000 08:03 257548
/home/fab/worspace/com.sma.core/lib/ashwood-1.1.jar
9b298000-9b29c000 r-xp 00000000 08:04 17563 /usr/lib/libXtst.so.6.1.0
9b29c000-9b29d000 rwxp 00003000 08:04 17563 /usr/lib/libXtst.so.6.1.0
9b29d000-9b2a1000 r-xp 00000000 08:04 17188
/usr/lib/libgthread-2.0.so.0.1600.3
9b2a1000-9b2a2000 rwxp 00003000 08:04 17188
9b2a2000-9b2a5000 r-xs 00013000 08:04 20308
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/jce.jar
9b2a5000-9b2a9000 r-xp 00000000 08:04 51231
/usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-png.so
9b2a9000-9b2aa000 rwxp 00003000 08:04 51231
9b2aa000-9b2ae000 rwxp 9b2aa000 00:00 0
9b2ae000-9b303000 r-xp 00000000 08:03 258789
/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.core/E nterpriseManager.product/org.eclipse.osgi/bundles/57/1/.cp/l ibswt-pi-gtk-3442.so
9b303000-9b305000 rwxp 00054000 08:03 258789
9b305000-9b306000 rwxp 9b305000 00:00 0
9b306000-9b309000 r-xp 00000000 08:03 258788
/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.core/E nterpriseManager.product/org.eclipse.osgi/bundles/57/1/.cp/l ibswt-gtk-3442.so
9b309000-9b30a000 rwxp 00002000 08:03 258788
9b30a000-9b30b000 rwxp 9b30a000 00:00 0
9b30b000-9b30f000 r-xs 00011000 08:03 226946
/home/fab/eclipse/dropins/BIRT/plugins/org.w3c.dom.svg_1.1.0 .v200803081811.jar
9b30f000-9b310000 r-xs 00003000 08:03 227269
/home/fab/eclipse/dropins/BIRT/plugins/org.w3c.dom.smil_1.0. 0.v200803081811.jar
9b310000-9b312000 r-xs 00005000 08:03 227275
/home/fab/eclipse/dropins/BIRT/plugins/org.w3c.css.sac_1.3.0 .v200803081811.jar
9b312000-9b338000 r-xs 00212000 08:03 227270
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.model_2.3.0.v20080424.jar
9b338000-9b33d000 r-xs 00031000 08:03 227209
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.item.crosstab.core_2.3.0.v20080424.jar
9b33d000-9b33f000 r-xs 00004000 08:03 227284
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.engine.emitter.pdf_2.3.0.v20080424.jar
9b33f000-9b341000 r-xs 0000f000 08:03 227257
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.engine.emitter.html_2.3.0.v20080428.jar
9b341000-9b363000 r-xs 001c0000 08:03 226879
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.engine_2.3.0.v20080505.jar
9b363000-9b367000 r-xs 0001c000 08:03 227255
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.repo rt.data.adapter_2.3.0.v20080425.jar
9b367000-9b36b000 r-xs 00017000 08:03 226948
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.data .aggregation_2.3.0.v20080429.jar
9b36b000-9b385000 r-xs 0012f000 08:03 226942
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.data _2.3.0.v20080424.jar
9b385000-9b38c000 r-xs 00049000 08:03 227287
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.core _2.3.0.v20080505.jar
9b38c000-9b391000 r-xs 0002a000 08:03 226865
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.char t.reportitem_2.3.0.v20080424.jar
9b391000-9b395000 r-xs 00037000 08:03 226950
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.char t.engine.extension_2.3.0.v20080417.jar
9b395000-9b3a4000 r-xs 00117000 08:03 226897
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.char t.engine_2.3.0.v20080424.jar
9b3a4000-9b3a5000 r-xs 0000b000 08:03 227264
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.char t.device.swt_2.3.0.v20080424.jar
9b3a5000-9b3a7000 r-xs 00019000 08:03 227262
/home/fab/eclipse/dropins/BIRT/plugins/org.eclipse.birt.char t.device.extension_2.3.0.v20080424.jar
9b3a7000-9b3a8000 r-xs 00007000 08:03 226943
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.xml_ 1.6.0.v200803061811.jar
9b3a8000-9b3ae000 r-xs 00021000 08:03 226969
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.util .gui_1.6.0.v200803061811.jar
9b3ae000-9b3b1000 r-xs 00015000 08:03 227289
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.util _1.6.0.v200803061811.jar
9b3b1000-9b3b4000 r-xs 00010000 08:03 226878
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.tran scoder_1.6.0.v200803061811.jar
9b3b4000-9b3b9000 r-xs 00028000 08:03 227280
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.svgg en_1.6.0.v200803061811.jar
9b3b9000-9b3bc000 r-xs 0000a000 08:03 227294
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.pars er_1.6.0.v200803061811.jar
9b3bc000-9b3c4000 r-xs 00058000 08:03 226912
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.ext. awt_1.6.0.v200803061811.jar
9b3c4000-9b3cf000 r-xs 00065000 08:03 227288
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.dom. svg_1.6.0.v200803061811.jar
9b3cf000-9b3d2000 r-xs 00016000 08:03 227266
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.dom_ 1.6.0.v200803061811.jar
9b3d2000-9b3d9000 r-xs 00039000 08:03 227276
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.css_ 1.6.0.v200803061811.jar
9b3d9000-9b3e3000 r-xs 00073000 08:03 226938
/home/fab/eclipse/dropins/BIRT/plugins/org.apache.batik.brid ge_1.6.0.v200803061811.jar
9b3e3000-9b3e7000 r-xs 00020000 08:03 227293
/home/fab/eclipse/dropins/BIRT/plugins/javax.wsdl_1.5.1.v200 803061910.jar
9b3e7000-9b3ee000 r-xs 000a4000 08:03 256232
/home/fab/eclipse/plugins/org.mortbay.jetty_5.1.14.v20080422 1617.jar
9b3ee000-9b431000 r-xs 0037a000 08:03 257187
/home/fab/eclipse/plugins/org.eclipse.ui.workbench_3.4.0.I20 080501-0100.jar
9b431000-9b435000 r-xs 0001d000 08:03 256298
/home/fab/eclipse/plugins/org.eclipse.ui.views.log_1.0.0.v20 080422-0800.jar
9b435000-9b43b000 r-xs 00043000 08:03 257138
/home/fab/eclipse/plugins/org.eclipse.ui.forms_3.3.100.v2008 0414.jar
9b43b000-9b440000 r-xs 0001f000 08:03 256499
/home/fab/eclipse/plugins/org.eclipse.ui_3.4.0.I20080501-130 0a.jar
9b440000-9b452000 r-xs 001d6000 08:03 256294
/home/fab/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.4. 0.v3442.jar
9b452000-9b453000 r-xs 00003000 08:03 257064
/home/fab/eclipse/plugins/org.eclipse.swt_3.4.0.v3442a.jar
9b453000-9b456000 r-xs 0000d000 08:03 256399
/home/fab/eclipse/plugins/org.eclipse.osgi.services_3.1.200. v20071203.jar
9b456000-9b45c000 r-xs 0002a000 08:03 256234
/home/fab/eclipse/plugins/org.eclipse.jface.databinding_1.2. 0.I20080501-1300.jar
9b45c000-9b470000 r-xs 000ea000 08:03 256229
/home/fab/eclipse/plugins/org.eclipse.jface_3.4.0.I20080501- 1300a.jar
9b470000-9b476000 r-xs 00066000 08:03 257053
/home/fab/eclipse/plugins/org.eclipse.help.webapp_3.3.100.v2 0080430.jar
9b476000-9b480000 r-xs 00069000 08:03 256398
/home/fab/eclipse/plugins/org.eclipse.help.ui_3.3.100.v20080 425.jar
9b480000-9b486000 r-xs 0004d000 08:03 256412
/home/fab/eclipse/plugins/org.eclipse.help.base_3.3.100.v200 80429.jar
9b486000-9b488000 r-xs 00003000 08:03 256281
/home/fab/eclipse/plugins/org.eclipse.help.appserver_3.1.200 .v20070510.jar
9b488000-9b48c000 r-xs 00031000 08:03 256301
/home/fab/eclipse/plugins/org.eclipse.help_3.3.100.v20080429 .jar
9b48c000-9b49d000 r-xs 000b7000 08:03 257312
/home/fab/eclipse/plugins/org.eclipse.gef_3.4.0.v20080423.ja r
9b49d000-9b49e000 r-xs 00002000 08:03 257007
/home/fab/eclipse/plugins/org.eclipse.equinox.jsp.jasper.reg istry_1.0.0.v20080427-0830.jar
9b49e000-9b4a0000 r-xs 00004000 08:03 256306
/home/fab/eclipse/plugins/org.eclipse.equinox.jsp.jasper_1.0 .100.v20080427-0830.jar
9b4a0000-9b4a2000 r-xs 00007000 08:03 256896
/home/fab/eclipse/plugins/org.eclipse.equinox.http.servlet_1 .0.100.v20080427-0830.jar
9b4a2000-9b4a4000 r-xs 00007000 08:03 256446
/home/fab/eclipse/plugins/org.eclipse.equinox.http.registry_ 1.0.100.v20080427-0830.jar
9b4a4000-9b4a6000 r-xs 00004000 08:03 256316
/home/fab/eclipse/plugins/org.eclipse.equinox.http.jetty_1.1 .0.v20080425.jar
9b4a6000-9b4a9000 r-xs 00032000 08:03 257017
/home/fab/eclipse/plugins/org.eclipse.emf.ecore.xmi_2.4.0.v2 00805121800.jar
9b4a9000-9b4b8000 r-xs 000ee000 08:03 257147
/home/fab/eclipse/plugins/org.eclipse.emf.ecore_2.4.0.v20080 5121800.jar
9b4b8000-9b4bc000 r-xs 0002a000 08:03 256242
/home/fab/eclipse/plugins/org.eclipse.emf.common_2.4.0.v2008 05121800.jar
9b4bc000-9b4c5000 r-xs 00078000 08:03 257309
/home/fab/eclipse/plugins/org.eclipse.draw2d_3.4.0.v20080401 .jar
9b4c5000-9b4c8000 r-xs 0001b000 08:03 257068
/home/fab/eclipse/plugins/org.eclipse.core.resources.compati bility_3.4.0.v20071204.jar
9b4c8000-9b4d2000 r-xs 000a1000 08:03 257071
/home/fab/eclipse/plugins/org.eclipse.core.resources_3.4.0.v 20080430-0005.jar
9b4d2000-9b4d3000 r-xs 00001000 08:03 257175
/home/fab/eclipse/plugins/org.eclipse.core.filesystem.linux. x86_1.2.0.v20071207.jar
9b4d3000-9b4d5000 r-xs 00009000 08:03 256449
/home/fab/eclipse/plugins/org.eclipse.core.filesystem_1.2.0. v20080421-1805.jar
9b4d5000-9b4d8000 r-xs 00012000 08:03 256239
/home/fab/eclipse/plugins/org.eclipse.core.expressions_3.4.0 .v20080430-0100.jar
9b4d8000-9b4e1000 r-xs 0004c000 08:03 256892
/home/fab/eclipse/plugins/org.eclipse.core.databinding_1.1.0 .I20080425-1551.jar
9b4e1000-9b4e4000 r-xs 00013000 08:03 256891
/home/fab/eclipse/plugins/org.eclipse.core.contenttype_3.3.0 .v20080414.jar
9b4e4000-9b4e7000 r-xs 00017000 08:03 256455
/home/fab/eclipse/plugins/org.eclipse.core.commands_3.4.0.v2 0080408-0800.jar
9b4e7000-9b4eb000 r-xs 00047000 08:03 256431
/home/fab/eclipse/plugins/org.apache.xml.serializer_2.7.1.v2 00803061811.jar
9b4eb000-9b4ee000 r-xs 00017000 08:03 256462
/home/fab/eclipse/plugins/org.apache.xml.resolver_1.2.0.v200 803061910.jar
9b4ee000-9b506000 r-xs 00126000 08:03 257123
/home/fab/eclipse/plugins/org.apache.xerces_2.9.0.v200803061 910.jar
9b506000-9b508000 r-xs 00010000 08:03 257119
/home/fab/eclipse/plugins/org.apache.lucene.analysis_1.9.1.v 200803061811.jar
9b508000-9b510000 r-xs 00065000 08:03 257177
/home/fab/eclipse/plugins/org.apache.lucene_1.9.1.v200803061 811.jar
9b510000-9b521000 r-xs 00194000 08:03 256479
/home/fab/eclipse/plugins/org.apache.jasper_5.5.17.v20080306 1811.jar
9b521000-9b523000 r-xs 00009000 08:03 256998
/home/fab/eclipse/plugins/org.apache.commons.logging_1.0.4.v 200803061811.jar
9b523000-9b526000 r-xs 0001d000 08:03 257101
/home/fab/eclipse/plugins/org.apache.commons.el_1.0.0.v20080 3061811.jar
9b526000-9b528000 r-xs 0000c000 08:03 256289
/home/fab/eclipse/plugins/org.apache.commons.codec_1.3.0.v20 0803061910.jar
9b528000-9b530000 r-xs 00033000 08:03 256476
/home/fab/eclipse/plugins/javax.xml_1.3.4.v2008041723.jar
9b530000-9b532000 r-xs 0000e000 08:03 257173
/home/fab/eclipse/plugins/javax.servlet.jsp_2.0.0.v200803061 910.jar
9b532000-9b535000 r-xs 00018000 08:03 256274
/home/fab/eclipse/plugins/javax.servlet_2.4.0.v200803061910. jar
9b535000-9b551000 r-xs 00427000 08:03 256445
/home/fab/eclipse/plugins/com.ibm.icu_3.8.1.v20080402.jar
9b551000-9b553000 r-xs 00004000 08:03 225071
/home/fab/eclipse/dropins/DTP/plugins/org.eclipse.datatools. connectivity.oda.profile_3.0.6.v200804300102.jar
9b553000-9b555000 r-xs 00017000 08:03 225079
/home/fab/eclipse/dropins/DTP/plugins/org.eclipse.datatools. connectivity.oda.consumer_3.1.2.v200804300102.jar
9b555000-9b558000 r-xs 00014000 08:03 225034
/home/fab/eclipse/dropins/DTP/plugins/org.eclipse.datatools. connectivity.oda_3.1.2.v200804300102.jar
9b558000-9b55c000 r-xs 00032000 08:03 224670
/home/fab/eclipse/dropins/DTP/plugins/org.eclipse.datatools. connectivity_1.1.0.v200804300102.jar
9b55c000-9b55e000 r-xs 00012000 08:03 257067
/home/fab/eclipse/plugins/org.eclipse.equinox.app_1.1.0.v200 80421-2006.jar
9b55e000-9b561000 ---p 9b55e000 00:00 0
9b561000-9b5af000 rwxp 9b561000 00:00 0
9b5af000-9b5b2000 ---p 9b5af000 00:00 0
9b5b2000-9b700000 rwxp 9b5b2000 00:00 0
9b700000-9b703000 r-xs 00012000 08:03 256943
/home/fab/eclipse/plugins/org.eclipse.core.jobs_3.4.0.v20080 310.jar
9b703000-9b706000 r-xs 00017000 08:03 256424
/home/fab/eclipse/plugins/org.eclipse.equinox.preferences_3. 2.200.v20080421-2006.jar
9b706000-9b707000 r-xs 00002000 08:03 257026
/home/fab/eclipse/plugins/org.eclipse.core.runtime.compatibi lity.registry_3.2.200.v20070717/runtime_registry_compatibili ty.jar
9b707000-9b70a000 r-xs 00027000 08:03 257018
/home/fab/eclipse/plugins/org.eclipse.equinox.registry_3.4.0 .v20080421-2006.jar
9b70a000-9b70c000 r-xs 0000f000 08:03 257182
/home/fab/eclipse/plugins/org.eclipse.core.runtime_3.4.0.v20 080421-1805.jar
9b70c000-9b70e000 r-xs 00016000 08:03 256302
/home/fab/eclipse/plugins/org.eclipse.update.configurator_3. 2.200.v20080417.jar
9b70e000-9b711000 ---p 9b70e000 00:00 0
9b711000-9b75f000 rwxp 9b711000 00:00 0
9b75f000-9b766000 r-xp 00000000 08:04 20196
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/libnio.so
9b766000-9b767000 rwxp 00006000 08:04 20196
9b767000-9b77a000 r-xp 00000000 08:04 20195
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/libnet.so
9b77a000-9b77b000 rwxp 00013000 08:04 20195
9b77b000-9b78a000 r-xs 000e4000 08:03 256312
/home/fab/eclipse/plugins/org.eclipse.osgi_3.4.0.v20080427-0 830.jar
9b78a000-9b7ea000 rwxs 00000000 00:09 1015831 /SYSV00000000 (deleted)
9b7ea000-9b86e000 rwxp 9b7ea000 00:00 0
9b86e000-9b871000 r-xp 00000000 08:04 51225
/usr/lib/gtk-2.0/2.10.0/loaders/libpixbufloader-bmp.so
9b871000-9b872000 rwxp 00002000 08:04 51225
9b872000-9b87c000 r-xp 00000000 08:04 197779
/usr/share/locale-langpack/fr/LC_MESSAGES/glib20.mo
9b87c000-9b887000 r-xp 00000000 08:04 48648
/usr/lib/gtk-2.0/2.10.0/engines/libmist.so
9b887000-9b888000 rwxp 0000a000 08:04 48648
9b888000-9b8b0000 r-xp 00000000 08:04 48642
/usr/lib/gtk-2.0/2.10.0/engines/libclearlooks.so
9b8b0000-9b8b1000 rwxp 00028000 08:04 48642
9b8b1000-9b8d3000 r-xp 00000000 08:04 197858
/usr/share/locale-langpack/fr/LC_MESSAGES/libc.mo
9b8d3000-9b8da000 r-xp 00000000 08:04 51223
/usr/lib/gtk-2.0/2.10.0/engines/libpixmap.so
9b8da000-9b8db000 rwxp 00007000 08:04 51223
9b8db000-9b900000 r-xp 00000000 08:04 197826
/usr/share/locale-langpack/fr/LC_MESSAGES/gtk20-properties.m o
9b900000-9b911000 r-xp 00000000 08:04 197827
/usr/share/locale-langpack/fr/LC_MESSAGES/gtk20.mo
9b911000-9b9f2000 r-xp 00000000 08:04 48994
/usr/lib/locale/fr_FR.utf8/LC_COLLATE
9b9f2000-9ba0a000 r-xp 00000000 08:04 17598
/usr/lib/libatk-1.0.so.0.2209.1
9ba0a000-9ba0c000 rwxp 00018000 08:04 17598
9ba0c000-9bd7c000 r-xp 00000000 08:04 17852
/usr/lib/libgtk-x11-2.0.so.0.1200.9
9bd7c000-9bd82000 rwxp 00370000 08:04 17852
9bd82000-9bd83000 rwxp 9bd82000 00:00 0
9bd83000-9bd87000 r-xp 00000000 08:04 17531 /usr/lib/libXdmcp.so.6.0.0
9bd87000-9bd88000 rwxp 00003000 08:04 17531 /usr/lib/libXdmcp.so.6.0.0
9bd88000-9bd9f000 r-xp 00000000 08:04 18361 /usr/lib/libxcb.so.1.0.0
9bd9f000-9bda0000 rwxp 00016000 08:04 18361 /usr/lib/libxcb.so.1.0.0
9bda0000-9bda2000 r-xp 00000000 08:04 17520 /usr/lib/libXau.so.6.0.0
9bda2000-9bda3000 rwxp 00001000 08:04 17520 /usr/lib/libXau.so.6.0.0
9bda3000-9bdc2000 r-xp 00000000 08:04 17757 /usr/lib/libexpat.so.1.5.2
9bdc2000-9bdc4000 rwxp 0001e000 08:04 17757 /usr/lib/libexpat.so.1.5.2
9bdc4000-9bdce000 r-xp 00000000 08:04 64832 /lib/libgcc_s.so.1
9bdce000-9bdcf000 rwxp 0000a000 08:04 64832 /lib/libgcc_s.so.1
9bdcf000-9beb7000 r-xp 00000000 08:04 18298
/usr/lib/libstdc++.so.6.0.9
9beb7000-9beba000 r-xp 000e8000 08:04 18298
9beba000-9bebc000 rwxp 000eb000 08:04 18298
9bebc000-9bec2000 rwxp 9bebc000 00:00 0
9bec2000-9beea000 r-xp 00000000 08:04 18189
/usr/lib/libpixman-1.so.0.10.0
9beea000-9beeb000 rwxp 00027000 08:04 18189
9beeb000-9bf0d000 r-xp 00000000 08:04 18193
/usr/lib/libpng12.so.0.15.0
9bf0d000-9bf0e000 rwxp 00022000 08:04 18193
9bf0e000-9bf22000 r-xp 00000000 08:04 18373 /usr/lib/libz.so.1.2.3.3
9bf22000-9bf23000 rwxp 00013000 08:04 18373 /usr/lib/libz.so.1.2.3.3
9bf23000-9bf8f000 r-xp 00000000 08:04 17773
/usr/lib/libfreetype.so.6.3.16
9bf8f000-9bf93000 rwxp 0006b000 08:04 17773
9bf93000-9bfb9000 r-xp 00000000 08:04 18165
/usr/lib/libpangoft2-1.0.so.0.2000.1
9bfb9000-9bfba000 rwxp 00026000 08:04 18165
9bfba000-9bfd1000 r-xp 00000000 08:04 17193
/usr/lib/libgdk_pixbuf-2.0.so.0.1200.9
9bfd1000-9bfd2000 rwxp 00016000 08:04 17193
9bfd2000-9bfd6000 r-xp 00000000 08:04 17537
/usr/lib/libXfixes.so.3.1.0
9bfd6000-9bfd7000 rwxp 00003000 08:04 17537
9bfd7000-9bfd9000 r-xp 00000000 08:04 17529
/usr/lib/libXdamage.so.1.1.0
9bfd9000-9bfda000 rwxp 00001000 08:04 17529
9bfda000-9bfdc000 r-xp 00000000 08:04 17525
/usr/lib/libXcomposite.so.1.0.0
9bfdc000-9bfdd000 rwxp 00001000 08:04 17525
9bfdd000-9bfe5000 r-xp 00000000 08:04 17527
/usr/lib/libXcursor.so.1.0.2
9bfe5000-9bfe6000 rwxp 00007000 08:04 17527
9bfe6000-9bfeb000 r-xp 00000000 08:04 17555
/usr/lib/libXrandr.so.2.1.0
9bfeb000-9bfec000 rwxp 00005000 08:04 17555
9bfec000-9bff3000 r-xp 00000000 08:04 17543 /usr/lib/libXi.so.6.0.0
9bff3000-9bff4000 rwxp 00006000 08:04 17543 /usr/lib/libXi.so.6.0.0
9bff4000-9c0d8000 r-xp 00000000 08:04 17514 /usr/lib/libX11.so.6.2.0
9c0d8000-9c0db000 rwxp 000e4000 08:04 17514 /usr/lib/libX11.so.6.2.0
9c0db000-9c104000 r-xp 00000000 08:04 17765
/usr/lib/libfontconfig.so.1.3.0
9c104000-9c105000 rwxp 00029000 08:04 17765
9c105000-9c165000 r-xp 00000000 08:04 17633
/usr/lib/libcairo.so.2.17.3
9c165000-9c167000 rwxp 0005f000 08:04 17633
9c167000-9c1a2000 r-xp 00000000 08:04 18161
/usr/lib/libpango-1.0.so.0.2000.1
9c1a2000-9c1a4000 rwxp 0003a000 08:04 18161
9c1a4000-9c225000 r-xp 00000000 08:04 17190
/usr/lib/libgdk-x11-2.0.so.0.1200.9
9c225000-9c228000 rwxp 00080000 08:04 17190
9c228000-9c24e000 r-xp 00000000 08:04 18179 /usr/lib/libpcre.so.3.12.1
9c24e000-9c24f000 rwxp 00026000 08:04 18179 /usr/lib/libpcre.so.3.12.1
9c24f000-9c2ff000 r-xp 00000000 08:04 17145
/usr/lib/libglib-2.0.so.0.1600.3
9c2ff000-9c300000 rwxp 000b0000 08:04 17145
9c300000-9c3ff000 rwxp 9c300000 00:00 0
9c3ff000-9c400000 ---p 9c3ff000 00:00 0
9c400000-9c401000 r-xs 00003000 08:03 257545
/home/fab/worspace/com.sma.core/lib/jcl104-over-slf4j-1.4.3. jar
9c401000-9c403000 r-xp 00000000 08:04 17545
/usr/lib/libXinerama.so.1.0.0
9c403000-9c404000 rwxp 00001000 08:04 17545
9c404000-9c40b000 r-xp 00000000 08:04 17557
/usr/lib/libXrender.so.1.3.0
9c40b000-9c40c000 rwxp 00007000 08:04 17557
9c40c000-9c419000 r-xp 00000000 08:04 17535 /usr/lib/libXext.so.6.4.0
9c419000-9c41a000 rwxp 0000d000 08:04 17535 /usr/lib/libXext.so.6.4.0
9c41a000-9c422000 r-xp 00000000 08:04 18163
/usr/lib/libpangocairo-1.0.so.0.2000.1
9c422000-9c423000 rwxp 00008000 08:04 18163
9c423000-9c43a000 r-xp 00000000 08:04 64893 /lib/libselinux.so.1
9c43a000-9c43c000 rwxp 00016000 08:04 64893 /lib/libselinux.so.1
9c43c000-9c477000 r-xp 00000000 08:04 17187
/usr/lib/libgobject-2.0.so.0.1600.3
9c477000-9c478000 rwxp 0003b000 08:04 17187
9c478000-9c47b000 r-xs 00015000 08:03 256591
/home/fab/eclipse/plugins/org.eclipse.equinox.common_3.4.0.v 20080421-2006.jar
9c47b000-9c47c000 r-xp 00000000 08:04 49484
/usr/lib/locale/fr_FR.utf8/LC_NUMERIC
9c47c000-9c47d000 r-xp 00000000 08:04 49482
/usr/lib/locale/fr_FR.utf8/LC_MONETARY
9c47d000-9c47e000 r-xp 00000000 08:04 56696
/usr/lib/locale/fr_FR.utf8/LC_MESSAGES/SYS_LC_MESSAGES
9c47e000-9c47f000 r-xp 00000000 08:04 49001
/usr/lib/locale/fr_FR.utf8/LC_PAPER
9c47f000-9c480000 r-xp 00000000 08:04 49461
/usr/lib/locale/fr_FR.utf8/LC_NAME
9c480000-9c481000 r-xp 00000000 08:04 49466
/usr/lib/locale/fr_FR.utf8/LC_ADDRESS
9c481000-9c482000 r-xp 00000000 08:04 49467
/usr/lib/locale/fr_FR.utf8/LC_TELEPHONE
9c482000-9c483000 r-xp 00000000 08:04 48997
/usr/lib/locale/fr_FR.utf8/LC_MEASUREMENT
9c483000-9c484000 r-xp 00000000 08:04 49469
/usr/lib/locale/fr_FR.utf8/LC_IDENTIFICATION
9c484000-9c48f000 r-xp 00000000 08:03 257157
/home/fab/eclipse/plugins/org.eclipse.equinox.launcher.gtk.l inux.x86_1.0.100.v20080428-1330/eclipse_1113.so
9c48f000-9c490000 rwxp 0000a000 08:03 257157
9c490000-9c497000 r-xs 00110000 08:04 20240
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/resources.jar
9c497000-9c498000 ---p 9c497000 00:00 0
9c498000-9c518000 rwxp 9c498000 00:00 0
9c518000-9c51b000 ---p 9c518000 00:00 0
9c51b000-9c569000 rwxp 9c51b000 00:00 0
9c569000-9c56c000 ---p 9c569000 00:00 0
9c56c000-9c5ea000 rwxp 9c56c000 00:00 0
9c5ea000-9c5ed000 ---p 9c5ea000 00:00 0
9c5ed000-9c66b000 rwxp 9c5ed000 00:00 0
9c66b000-9c66e000 ---p 9c66b000 00:00 0
9c66e000-9c6bc000 rwxp 9c66e000 00:00 0
9c6bc000-9c6fb000 r-xp 00000000 08:04 49112
/usr/lib/locale/fr_FR.utf8/LC_CTYPE
9c6fb000-9c6fe000 ---p 9c6fb000 00:00 0
9c6fe000-9c74c000 rwxp 9c6fe000 00:00 0
9c74c000-9c74f000 ---p 9c74c000 00:00 0
9c74f000-9c79d000 rwxp 9c74f000 00:00 0
9c79d000-9c79e000 ---p 9c79d000 00:00 0
9c79e000-9c850000 rwxp 9c79e000 00:00 0
9c850000-9c9db000 r-xs 02df0000 08:04 20260
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/rt.jar
9c9db000-9c9dc000 ---p 9c9db000 00:00 0
9c9dc000-9ca5c000 rwxp 9c9dc000 00:00 0
9ca5c000-9ca5d000 ---p 9ca5c000 00:00 0
9ca5d000-9cb27000 rwxp 9ca5d000 00:00 0
9cb27000-9cb8f000 rwxp 9cb27000 00:00 0
9cb8f000-9cbd9000 rwxp 9cb8f000 00:00 0
9cbd9000-9cc40000 rwxp 9cbd9000 00:00 0
9cc40000-9cc4f000 rwxp 9cc40000 00:00 0
9cc4f000-a6000000 rwxp 9cc4f000 00:00 0
a6000000-b2fe0000 rwxp a6000000 00:00 0
b2fe0000-b4c20000 rwxp b2fe0000 00:00 0
b4c20000-b4c50000 rwxp b4c20000 00:00 0
b4c50000-b4c51000 r-xp 00000000 08:04 49473
/usr/lib/locale/fr_FR.utf8/LC_TIME
b4c51000-b4c58000 r-xs 00000000 08:04 33319
/usr/lib/gconv/gconv-modules.cache
b4c58000-b4c61000 rwxp b4c58000 00:00 0
b4c61000-b4d18000 rwxp b4c61000 00:00 0
b4d18000-b4f58000 rwxp b4d18000 00:00 0
b4f58000-b7d18000 rwxp b4f58000 00:00 0
b7d18000-b7d27000 r-xp 00000000 08:04 20191
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/libzip.so
b7d27000-b7d29000 rwxp 0000e000 08:04 20191
b7d29000-b7d4c000 r-xp 00000000 08:04 20188
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/libjava.so
b7d4c000-b7d4e000 rwxp 00023000 08:04 20188
b7d4e000-b7d59000 r-xp 00000000 08:04 20187
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/libverify.so
b7d59000-b7d5a000 rwxp 0000b000 08:04 20187
b7d5a000-b7d63000 r-xp 00000000 08:04 82355
/lib/tls/i686/cmov/libnss_files-2.7.so
b7d63000-b7d65000 rwxp 00008000 08:04 82355
b7d65000-b7d6d000 r-xp 00000000 08:04 82359
/lib/tls/i686/cmov/libnss_nis-2.7.so
b7d6d000-b7d6f000 rwxp 00007000 08:04 82359
b7d6f000-b7d76000 r-xp 00000000 08:04 82351
/lib/tls/i686/cmov/libnss_compat-2.7.so
b7d76000-b7d78000 rwxp 00006000 08:04 82351
b7d78000-b7d8c000 r-xp 00000000 08:04 82349
/lib/tls/i686/cmov/libnsl-2.7.so
b7d8c000-b7d8e000 rwxp 00013000 08:04 82349
b7d8e000-b7d90000 rwxp b7d8e000 00:00 0
b7d90000-b7d93000 r-xp 00000000 08:04 17162
/usr/lib/libgmodule-2.0.so.0.1600.3
b7d93000-b7d94000 rwxp 00002000 08:04 17162
b7d94000-b7d9c000 rwxs 00000000 08:04 323908 /tmp/hsperfdata_fab/10594
b7d9c000-b7da3000 r-xp 00000000 08:04 82368
/lib/tls/i686/cmov/librt-2.7.so
b7da3000-b7da5000 rwxp 00006000 08:04 82368
b7da5000-b7da8000 ---p b7da5000 00:00 0
b7da8000-b7df6000 rwxp b7da8000 00:00 0
b7df6000-b7e19000 r-xp 00000000 08:04 82346
/lib/tls/i686/cmov/libm-2.7.so
b7e19000-b7e1b000 rwxp 00023000 08:04 82346
b7e1b000-b7e1c000 rwxp b7e1b000 00:00 0
b7e1c000-b7f65000 r-xp 00000000 08:04 82338
/lib/tls/i686/cmov/libc-2.7.so
b7f65000-b7f66000 r-xp 00149000 08:04 82338
b7f66000-b7f68000 rwxp 0014a000 08:04 82338
b7f68000-b7f6b000 rwxp b7f68000 00:00 0
b7f6b000-b7f6d000 r-xp 00000000 08:04 82344
/lib/tls/i686/cmov/libdl-2.7.so
b7f6d000-b7f6f000 rwxp 00001000 08:04 82344
b7f6f000-b7f76000 r-xp 00000000 08:04 20190
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/jli/libjli.so
b7f76000-b7f78000 rwxp 00006000 08:04 20190
b7f78000-b7f79000 rwxp b7f78000 00:00 0
b7f79000-b7f8d000 r-xp 00000000 08:04 82364
/lib/tls/i686/cmov/libpthread-2.7.so
b7f8d000-b7f8f000 rwxp 00013000 08:04 82364
b7f8f000-b7f91000 rwxp b7f8f000 00:00 0
b7f91000-b7f92000 r-xp 00000000 08:04 18359
/usr/lib/libxcb-xlib.so.0.0.0
b7f92000-b7f93000 rwxp 00000000 08:04 18359
b7f93000-b7f94000 r-xs 0000a000 08:03 256307
/home/fab/eclipse/plugins/org.eclipse.equinox.launcher_1.0.1 00.v20080501.jar
b7f94000-b7f9a000 r-xp 00000000 08:04 20176
/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386/native_threads /libhpi.so
b7f9a000-b7f9b000 rwxp 00006000 08:04 20176
b7f9b000-b7f9c000 rwxp b7f9b000 00:00 0
b7f9c000-b7f9d000 r-xp b7f9c000 00:00 0
b7f9d000-b7f9f000 rwxp b7f9d000 00:00 0
b7f9f000-b7fa0000 r-xp b7f9f000 00:00 0 [vdso]
b7fa0000-b7fba000 r-xp 00000000 08:04 64787 /lib/ld-2.7.so
b7fba000-b7fbc000 rwxp 00019000 08:04 64787 /lib/ld-2.7.so
bfaa4000-bfab9000 rwxp bffeb000 00:00 0 [stack]
VM Arguments:
jvm_args: -XX:PermSize=128m -Xmx256m -Dfile.encoding=UTF-8
java_command: org.eclipse.equinox.launcher.Main -launcher
/home/fab/eclipse/eclipse -name Eclipse -showsplash 600 -product
com.sma.ui.em.product -data
/home/fab/worspace/../runtime-EnterpriseManager.product -configuration
file:/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.c ore/EnterpriseManager.product/
-dev
file:/home/fab/worspace/.metadata/.plugins/org.eclipse.pde.c ore/EnterpriseManager.product/dev.properties
-os linux -ws gtk -arch x86 -nl fr_FR -nl en_US
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin :/bin:/usr/games
USERNAME=fab
LD_LIBRARY_PATH=/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i38 6/server:/usr/lib/jvm/java-6-sun-1.6.0.06/jre/lib/i386:/usr/ lib/jvm/java-6-sun-1.6.0.06/jre/../lib/i386:/usr/lib/jvm/jav a-6-sun-1.6.0.06/jre/lib/i386/client:/usr/lib/jvm/java-6-sun -1.6.0.06/jre/lib/i386:/usr/lib/xulrunner-addons:/usr/lib/xu lrunner-addons
SHELL=/bin/bash
DISPLAY=:0.0
Signal Handlers:
SIGSEGV: [libjvm.so+0x5edbc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGBUS: [libjvm.so+0x5edbc0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGFPE: [libjvm.so+0x4fc630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGPIPE: SIG_IGN, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGXFSZ: [libjvm.so+0x4fc630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGILL: [libjvm.so+0x4fc630], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000
SIGUSR2: [libjvm.so+0x4fe670], sa_mask[0]=0x00000004, sa_flags=0x10000004
SIGHUP: [libjvm.so+0x4fe410], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGINT: [libjvm.so+0x4fe410], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGTERM: [libjvm.so+0x4fe410], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
SIGQUIT: [libjvm.so+0x4fe410], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004
--------------- S Y S T E M ---------------
OS:lenny/sid
uname:Linux 2.6.24-17-generic #1 SMP Thu May 1 14:31:33 UTC 2008 i686
libc:glibc 2.7 NPTL 2.7
rlimit: STACK 8192k, CORE 0k, NPROC 16374, NOFILE 1024, AS infinity
load average:3,55 1,66 0,86
CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15
stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3
Memory: 4k page, physical 2074536k(647604k free), swap 0k(0k free)
vm_info: Java HotSpot(TM) Server VM (10.0-b22) for linux-x86 JRE
(1.6.0_06-b02), built on Mar 25 2008 00:26:44 by "java_re" with gcc
3.2.1-7a (J2SE release)
time: Wed May 28 09:10:22 2008
elapsed time: 29 seconds
| Re: [GEF] bug and crash under linux [message #243197 is a reply to message #243187] |
Wed, 28 May 2008 09:16  |
it appears that the bug with a non well painted zone happens when the size
in pixels exceed 32767 ( the half of 65535).
Have you got a solution or an explanation?
Fabien
Current Time: Sun May 19 11:10:57 EDT 2013
Powered by FUDForum. Page generated in 0.02041 seconds
