Home » Eclipse Projects » GEF » 2 problems with PolylineConnection
2 problems with PolylineConnection [message #242319] Thu, 10 April 2008 07:38 Go to next message
Eclipse User
Originally posted by: fmacloud.gmx.de
Right now I'm trying to work with some PolylineConnection.
I'm facing two problems which I can't figure out properly.
1. I'm adding a label to each PolylineConnection. Unfortunatelly when I
add another polyline which crosses the first polyline the label from the
first line is below the new line. So I would prefer the labels to be on
a diffent layer which is above the lines. And I have no clue how to
achieve this. Any kind of help would be much appreciated.
2. Some polylines will have the same starting- and endpoint. In this
case the line should not just be a dot but rather a small loop. I'm also
clueless on this problem.
Thanks in advance for any help,
I'm really stuck here,
Frank
Re: 2 problems with PolylineConnection [message #242514 is a reply to message #242319] Wed, 23 April 2008 06:39 Go to previous message
Eclipse User
Hm seems like the problems are not really solved easily. I'm still in
need of a solution. So help would be most welcome.
Frank
> Frank
Previous Topic:firePropertyChange & MultiPageEditor (EMF/GEF)
Next Topic:Clone GEF file
Current Time: Sat May 25 12:23:27 EDT 2013
Powered by FUDForum. Page generated in 0.01509 seconds
