Home » Eclipse Projects » GEF » Zest: How to style connections? Compartments?
Zest: How to style connections? Compartments? [message #240567] Thu, 10 January 2008 23:39 Go to next message
Miles Parker is currently offline Miles Parker
This is kind of embarrasing question to ask :) but I cannot figure out
how to implement styled connections and entities. I see the
IConnectionStyleProvider interface and there seems to be a factory, but
that is located in .internals, i.e. presumably not for extension. I
can't find any hooks in GraphiViewer or any of the providers either..
Also is there any built-in support for compartments?
Links to more example code would be great. I've seen both of these
features in screenshots but I can't find any code eamples except for
the two simple examples on the Wiki page.
Zest is great! GMF was huge overkill / complexity for what I wanted and
GEF alone would involve a lot of custom work -- you've saved me a ton
of work and allowed me to offer a tool to users right away that I was
planning for months from now.
Re: Zest: How to style connections? Compartments? [message #240638 is a reply to message #240567] Fri, 11 January 2008 21:15 Go to previous message
Eclipse User
No this is not an embarrassing question, I really should have better
code examples.
For this to work, simply have your label provider implement
IConnectionStyleProvider. Then implement the methods. This provides a
few simply styles you can add to your graph.
I may change the API slightly (to make it easier to add new styles) but
I will try not to break any backwards compatibility. I have opened a
bug to remind myself to add a new snippet for this:
215101: Add a code snippet to show how to use style providers
https://bugs.eclipse.org/bugs/show_bug.cgi?id=215101
There is limited support. You should be able to add a GraphContainer to
your graph. Currently graph containers cannot contain other containers.
Take a look at this snippet for an example:
ttp://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gef/test /org.eclipse.zest.tests/src/org/eclipse/zest/tests/swt/Neste dGraphSnippet.java?revision=1.3&root=Tools_Project&v iew=markup
> features in screenshots but I can't find any code eamples except for the
There are a few in the CVS repository
eclipse.org/home/tools/gef/test/org.eclipse.zest.tests
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.gef/tes t/org.eclipse.zest.tests/src/org/eclipse/zest/tests/swt/?roo t=Tools_Project
> GEF alone would involve a lot of custom work -- you've saved me a ton of
Thanks for the kind words.
ian
Previous Topic:Zest Graph nodes - vertically align Text and Image on node Label
Next Topic:GEF parent child problem
Current Time: Thu May 23 12:55:22 EDT 2013
Powered by FUDForum. Page generated in 0.01505 seconds
