Home » Eclipse Projects » GEF » Tooltip extra large
Tooltip extra large [message #234860] Thu, 31 May 2007 11:15 Go to next message
Eclipse User
Originally posted by: bch.openbluelab.org
When I create a tool tip on an element with a label, the tool tip is
very big.
Label labelView = new Label(text);
labelView.setSize(10, 10);
((ClasseFigure) getFigure()).setToolTip(labelView);
Have you an idea ?
Re: Tooltip extra large [message #235145 is a reply to message #234860] Tue, 05 June 2007 19:59 Go to previous messageGo to next message
Anthony Hunter is currently offline Anthony Hunter
Hi Benjamin,
What platform are you using? setSize() on windows has no affect on the
tooltip.
Cheers...
Anthony
"Benjamin CHEVALLEREAU" <bch@openbluelab.org> wrote in message
news:f3mopv$vdd$1@build.eclipse.org...
> very big.
> Have you an idea ?
> Thanks
Re: Tooltip extra large [message #235158 is a reply to message #235145] Wed, 06 June 2007 03:30 Go to previous messageGo to next message
Eclipse User
I use Windows XP so I understand why the tooltip is not resized. So have
you a solution to reduce the size of my tooltip ?
Anthony Hunter a écrit :
> Hi Benjamin,
> tooltip.
> Cheers...
> Anthony
>> very big.
>> Have you an idea ?
>> Thanks
Re: Tooltip extra large [message #235188 is a reply to message #235158] Wed, 06 June 2007 09:24 Go to previous messageGo to next message
Hi Benjamin,
I tried your snippet and it worked as I expected on windows XP. What is the
question? Perhaps a screenshot of what you are looking for?
Cheers...
Anthony
news:f45nr6$vpo$1@build.eclipse.org...
> Thanks
> Anthony Hunter a
Re: Tooltip extra large [message #235201 is a reply to message #235188] Wed, 06 June 2007 10:52 Go to previous messageGo to next message
Eclipse User
--------------020109010302030108000409
The question is why I have a big tooltip ?
Thanls
Anthony Hunter a
Re: Tooltip extra large [message #235260 is a reply to message #235201] Thu, 07 June 2007 13:50 Go to previous messageGo to next message
Hi Benjamin,
I cannot duplicate this with the GEF examples I have. What is special about
the diagram? Can you duplicate this somewhere other than your code? (This
may be a stretch, but are you using GMF?)
Cheers...
Anthony
news:f46ho6$8nb$1@build.eclipse.org...
> Hi
> Thanls
> Anthony Hunter a
Re: Tooltip extra large [message #235298 is a reply to message #235260] Fri, 08 June 2007 04:22 Go to previous messageGo to next message
Eclipse User
I use Topcased wich permit to generate simply an editor; topcased is
based on GEF and the team Topcased say me that I must post my question
on GEF. The team topcased have never used tool tip so they don't know if
they have the same problem.
> Hi Benjamin,
> Cheers...
> Anthony
>> Hi
>> Thanls
>>> Hi Benjamin,
>>> the
>>> Cheers...
>>> Anthony
>>>> Thanks
>>>>> Hi Benjamin,
>>>>> tooltip.
>>>>> Cheers...
>>>>> Anthony
>>>>>> Hi,
>>>>>> very big.
>>>>>> Have you an idea ?
>>>>>> Thanks
Re: Tooltip extra large [message #240350 is a reply to message #235298] Mon, 24 December 2007 09:25 Go to previous messageGo to next message
Eclipse User
Originally posted by: trommas.yahoo.com
How can the size of the tooltip be set?
I get a long line of characters, when really what I want is a box
(textarea) - like eclipse makes.
Merry Christmas,
Tomas Zijdemans
Benjamin CHEVALLEREAU wrote:
> Hi
> Thanks
>> Hi Benjamin,
>> about the diagram? Can you duplicate this somewhere other than your
>> code? (This may be a stretch, but are you using GMF?)
>> Cheers...
>> Anthony
>>> Hi
>>> Thanls
>>>> Hi Benjamin,
>>>> is the
>>>> Cheers...
>>>> Anthony
>>>>> have
>>>>> Thanks
>>>>>> Hi Benjamin,
>>>>>> the
>>>>>> tooltip.
>>>>>> Cheers...
>>>>>> Anthony
>>>>>>> Hi,
>>>>>>> very big.
>>>>>>> Have you an idea ?
>>>>>>> Thanks
Re: Tooltip extra large [message #240541 is a reply to message #235298] Wed, 09 January 2008 13:28 Go to previous message
Jacques LESCOT is currently offline Jacques LESCOT
Benjamin,
while trying to add a Tooltip label using Topcased, I also noticed that
the default tooltip size was very large by default. But this might be
easily fixed by using a org.eclipse.draw2d.Label instead of the one
redefined at the Topcased level which inherits from the GMF WrapLabel
causing such a big size.
Benjamin CHEVALLEREAU a écrit :
> Hi
> Thanks
>> Hi Benjamin,
>> Cheers...
>> Anthony
>>> Hi
>>> Thanls
>>>> Hi Benjamin,
>>>> is the
>>>> Cheers...
>>>> Anthony
>>>>> have
>>>>> Thanks
>>>>>> Hi Benjamin,
>>>>>> the
>>>>>> tooltip.
>>>>>> Cheers...
>>>>>> Anthony
>>>>>>> Hi,
>>>>>>> very big.
>>>>>>> Have you an idea ?
>>>>>>> Thanks
Previous Topic:Right-aligned text
Next Topic:How does one get the current mouse location for a ContexMenuProvider?
Current Time: Sat May 25 06:45:59 EDT 2013
Powered by FUDForum. Page generated in 0.05251 seconds
