Home » Eclipse Projects » GEF » Ruler and graph centering questions
Ruler and graph centering questions [message #238504] Sun, 16 September 2007 05:39
Lillo is currently offline Lillo
Hi all,
I need help about the following problems:
- how to display a ruler that shows meter as unit: my graph represents an
irrigation network and centimeter/inch isn't the right unit
- how to display in the status bar the cursor coordinates (x,y) in meters: x
and y are double and I need to show the first two decimals too: do I have to
perform coordinates transformation in order to get meters as (x,y) values?
- how to center the whole graph inside the graph editor
Could you help me giving also code samples, if there are any?
Thank you so much in advance!
Best Regards
Previous Topic:plugin runs in SWT Eclipse 3.2 but in Europa doesn't
Next Topic:Display a Figure in front of the others
Current Time: Thu May 23 13:01:01 EDT 2013
Powered by FUDForum. Page generated in 0.01509 seconds
