| Problems with scrolling [message #238126] |
Tue, 28 August 2007 08:46  |
René Messages: 45 Registered: July 2009 |
Member |
--------------050805010500000902080701
i use a editor sub classed from the GraphicalEditorWithPalette (with a
XYLayout). It works mostly like the shapes editor example. The diagram
have components and between these are connections. For the connections i
use a ShortesPathConnectionRouter.
Everything with these things are ok until you have to scroll. If this
happened the connection make crazy things. Now they are totally
displaced (shot1.png). But it is not a problem only with the
connections. When i scroll a bit and try to paint a new connection the
dashed pre-connection-line will be also displaced (shot2.png).
It seems to me that there is something wrong with the anchors (I use
XYAnchors) ?! But why? Everything is fine when I dont scroll?
Has anybody an idea? Im very thankful for any hint!
Ren
| Re: Problems with scrolling [message #238362 is a reply to message #238202] |
Fri, 07 September 2007 08:36  |
Member |
Hi guys,
I had solved the problem. The solution is to implement a class derived
from the AbstractConnectionAnchor. For this anchor type you can specify
a owner figure and on every move or resize of this figure the location
will be updated by itself. To do this you have to implement the
AbstractConnectionAnchor#getLocation() method. This is also the point
where you have to translate the relative coordinates into world
coordinates (getOwner().translateToWorld(p)). For example have a look at
the FixedConnectionAnchor class in the logic example.
I had seen that this is one of the common gef/draw2d mistakes
(http://wiki.eclipse.org/index.php/GEF_Troubleshooting_Guide). Dont
worry when you got the same :)
best regards,
René
René wrote:
> Hi all,
> I had searched the internet a bit more and get some new ideas about my
> problem. I think it is really a problem with the anchors positions.
> There a exist a relative and absolute coordinate system. Until yet I
> only use the relative system. The trick is to translate these relative
> coords into world coords. But with this I still have trouble:
> Im not sure which figure in my diagram i have to use to translate the
> coords to world coords. I had tried to use the my component-figure (the
> componeten figure has-subfigures connectors which have the XYAnchors)
> but unsuccessful. Maybe somebody had an idea which figure I have to use
> for to correct translation.
> Thanks!
> René
> René schrieb:
>> i use a ShortesPathConnectionRouter.
>> Best regards,
>> René
FUDForum. Page generated in 0.01618 seconds
