Home » Eclipse Projects » Web Tools Project (WTP) » NPE when switching to XHTML file
NPE when switching to XHTML file [message #234162] Mon, 27 July 2009 10:27
Michael Giroux is currently offline Michael Giroux
Member
Using Eclipse 3.4.2 J2EE install. All works well for a few hours, then
after a while of running, I start getting "Unhandled event loop
exceptions" due to a NPE. The problem always occurs when I switch active
editor to one of the open xhtml documents.
Shutting down Eclipse and restarting solves the problem for another couple
of hours.
It is difficult to reproduce, but the problem seems to be related to
running eclipse for a long time.
1. start eclipse
2. open several files, some java files, some xhtml files
3. modify files, save changes, do builds, start/stop the Tomcat server to
test
repeat steps 2,3 several times. Eventually, eclipse starts reporting the
Unhandled event loop exceptions on files that are already open, and I have
been able to edit these same files in the same instance of eclipse
previously.
-- Error Details --
Date: Mon Jul 27 07:08:12 GMT-07:00 2009
Message: Unhandled event loop exception
Severity: Error
Plugin: org.eclipse.ui
Session Data:
eclipse.buildId=M20090211-1700
java.version=1.6.0_14
Framework arguments: -showlocation Trunk
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data
c:/EclipseWorkspace/Trunk -showlocation Trunk
Exception Stack Trace:
org.eclipse.jst.pagedesigner.editors.actions.DesignPageActio nContributor.setActiveEditor(DesignPageActionContributor.jav a:199)
org.eclipse.jst.pagedesigner.editors.actions.PageDesignerAct ionBarContributor2.activateSourcePage(PageDesignerActionBarC ontributor2.java:290)
org.eclipse.jst.pagedesigner.editors.actions.PageDesignerAct ionBarContributor2.setInnerActivePage(PageDesignerActionBarC ontributor2.java:212)
org.eclipse.jst.pagedesigner.ui.common.sash.NestedEditorActi onBarContributor.setActivePage(NestedEditorActionBarContribu tor.java:34)
org.eclipse.jst.pagedesigner.ui.common.sash.SashEditorPart.a ctiveEditorChanged(SashEditorPart.java:373)
org.eclipse.jst.pagedesigner.ui.common.sash.SashEditorPart$1 .handleEvent(SashEditorPart.java:99)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:13 53)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2443)
at org.eclipse.swt.widgets.Widget.wmSetFocus(Widget.java:2266)
at org.eclipse.swt.widgets.Control.WM_SETFOCUS(Control.java:441 4)
at org.eclipse.swt.widgets.Canvas.WM_SETFOCUS(Canvas.java:443)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3855 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4528 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:974)
at org.eclipse.swt.widgets.Control.setSavedFocus(Control.java:3 080)
at org.eclipse.swt.widgets.Decorations.restoreFocus(Decorations .java:808)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations. java:1617)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2013)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3784 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.internal.win32.OS.DestroyWindow(Native Method)
at org.eclipse.swt.widgets.Control.destroyWidget(Control.java:6 63)
at org.eclipse.swt.widgets.Shell.destroyWidget(Shell.java:657)
at org.eclipse.swt.widgets.Widget.release(Widget.java:814)
at org.eclipse.swt.widgets.Widget.dispose(Widget.java:441)
at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java :446)
at org.eclipse.swt.widgets.Shell.dispose(Shell.java:674)
at org.eclipse.jface.window.Window.close(Window.java:335)
at org.eclipse.jface.dialogs.Dialog.close(Dialog.java:979)
at org.eclipse.jface.dialogs.TrayDialog.close(TrayDialog.java:1 43)
at org.eclipse.jface.dialogs.Dialog.okPressed(Dialog.java:940)
at org.eclipse.jface.dialogs.Dialog.buttonPressed(Dialog.java:4 72)
org.eclipse.ui.statushandlers.WorkbenchStatusDialogManager$I nternalDialog.buttonPressed(WorkbenchStatusDialogManager.jav a:266)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
Previous Topic:Debugging JSP's in Eclipse/WebSphere 6.1
Next Topic:How to change publishing setting to "Never publish automatically" by default when providin
Current Time: Sat May 25 19:32:48 EDT 2013
Powered by FUDForum. Page generated in 0.02001 seconds
