| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #234001 is a reply to message #233921] |
Wed, 22 July 2009 09:16   |
Originally posted by: dcarver.starstandard.org
WTP has a DOM Level 1 implementation that you can use. If you do some
web searches on WTP DOM you should find some tutorials that will show
you how to get a WTP DOM and then use it to add your particular items.
Dave
Runzhou Li wrote:
> Just like how we can manually add an HTML file in a project with some
> prefilled content, how can this be done programmatically?
> Thank you in advance.
> Runzhou Li
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #234009 is a reply to message #234001] |
Wed, 22 July 2009 09:51   |
Originally posted by: runzhou.li.gmail.com
Actually even simpler, can I directly make use of the Eclipse built-in one?
Just want to programmatically call it.
Runzhou Li
"David Carver" <dcarver@starstandard.org> wrote in message
news:h473fd$hc2$1@build.eclipse.org...
> web searches on WTP DOM you should find some tutorials that will show you
> Dave
> Runzhou Li wrote:
>> Runzhou Li
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #234022 is a reply to message #234009] |
Wed, 22 July 2009 13:32   |
If you already have a template, you can contribute that template, to the
HTML templates, through the standard Template extension point.
Take a look at the org.eclipse.wst.html.ui plugin.xml for examples.
Dave
> Runzhou Li
>> Dave
>> Runzhou Li wrote:
>>> Hi,
>>> Runzhou Li
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #234122 is a reply to message #234022] |
Fri, 24 July 2009 09:28   |
Is there a direct way of getting the template and make use of it? Because I
don't need to have my own template.
Runzhou Li
news:4A674D32.5010007@starstandard.org...
> Dave
>> one? Just want to programmatically call it.
>> Runzhou Li
>>> Dave
>>> Runzhou Li wrote:
>>>> Hi,
>>>> Runzhou Li
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #367698 is a reply to message #272663] |
Tue, 28 July 2009 10:29   |
Thank you so much Nitin.
I'm also trying to avoid using internal classes, so about creating my own
template, say I create a template through
"org.eclipse.ui.editors.templates -> template" called my_html_new but
instead of creating my own contextType, I reuse html_new as contextTypeId.
How can I get access to this template and use it to serve my original
purpose?
"Nitin Dahyabhai" <nitind@us.ibm.com> wrote in message
news:h4l80t$tef$1@build.eclipse.org...
>> I don't need to have my own template.
> Yes, but only with internals. We don't guarantee to keep the same
> templates and template names from release to release, so it's recommended
> you create your own.
> TemplateStore templateStore =
> HTMLUIPlugin.getDefault().getTemplateStore();
> Template template = templateStore.findTemplate(nameOftemplate);
> TemplateContextType contextType =
> HTMLUIPlugin.getDefault().getTemplateContextRegistry().getCo ntextType(template.getContextTypeId());
> IDocument document = new Document();
> TemplateContext context = new DocumentTemplateContext(contextType,
> document, 0, 0);
> TemplateBuffer buffer = context.evaluate(template);
> templateString = buffer.getString();
> Then you would write the string into a file using IFile.setContents().
> Nitin Dahyabhai
> Eclipse WTP Source Editing
> IBM Rational
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #369116 is a reply to message #367698] |
Tue, 28 July 2009 13:00   |
Nitin Dahyabhai Messages: 1857 Registered: July 2009 |
> purpose?
Unless you want your template visible in our wizard, content assist,
and preference page, there's no reason to use an HTML context
type--it's perfectly fine to declare your own. I didn't work on
this myself, so there's not a lot of advice I can give past
examining how it's implemented in our plug-ins and those from the
Platform.
One piece of advice I *can* give is to avoid accidentally declaring
the same ID for a context type as anyone else. JSDT has a bug open
due to its contexts colliding with those of JDT (266680), causing
unpredictably incorrect behavior in the preferences UI and content
assist when both are installed.
Nitin Dahyabhai
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
| Re: How To Programmatically Create An HTML File Using The Eclipse Standard HTML Template [message #369125 is a reply to message #369116] |
Tue, 28 July 2009 14:00  |
I see, I'll take a look at how content type is done, and how to make use of
it.
Thank you for your valuable help :)
news:h4naqs$j2k$1@build.eclipse.org...
>> contextTypeId. How can I get access to this template and use it to serve
>> my original purpose?
> Unless you want your template visible in our wizard, content assist, and
> preference page, there's no reason to use an HTML context type--it's
> perfectly fine to declare your own. I didn't work on this myself, so
> there's not a lot of advice I can give past examining how it's implemented
> in our plug-ins and those from the Platform.
> One piece of advice I *can* give is to avoid accidentally declaring the
> same ID for a context type as anyone else. JSDT has a bug open due to its
> contexts colliding with those of JDT (266680), causing unpredictably
> incorrect behavior in the preferences UI and content assist when both are
> installed.
> Nitin Dahyabhai
> IBM Rational
FUDForum. Page generated in 0.03977 seconds
