| Eclipse Webtools servers.xml file [message #233341] |
Mon, 06 July 2009 20:26  |
Originally posted by: ssullivan.aravo.com
I am using Eclipse 3.4.2 (Ganymede SR2) with Eclipse Webtools 3.0.4
When I add a server (File --> New --> Server), the new server is added
to the servers.xml file.
The servers.xml file is located in
$WORKSPACE/.metadata/.plugins/org.eclipse.wst.server.core
Since the servers.xml file is treated as workspace metadata, I don't
have an easy way to store the file in version control.
Is there a way to store servers.xml in an Eclipse project (in the
Servers project?) and store the file under version control?
Thanks in advance.
| Re: Eclipse Webtools servers.xml file [message #233349 is a reply to message #233341] |
Mon, 06 July 2009 23:13   |
Originally posted by: dcarver.starstandard.org
If you look in your Workspace in the Project Explorer, you should see a
Servers project. You should be able to share that project as it
contains the server.xml file that is copied during deployment to the
location you mentioned in your .metadata hidden folder.
Dave
> Thanks in advance.
| Re: Eclipse Webtools servers.xml file [message #233376 is a reply to message #233341] |
Tue, 07 July 2009 09:44  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
> Thanks in advance.
Right-click on the server in the Servers view and select Properties. In
the dialog that appears, click Switch Location. This will move the
definition of that server to a file under the Servers project in your
workspace.
Larry
FUDForum. Page generated in 0.01535 seconds
