Home » Eclipse Projects » Web Tools Project (WTP) » Ganamede, Galileo, and Tomcat 6
| Ganamede, Galileo, and Tomcat 6 [message #233233] |
Thu, 02 July 2009 14:57  |
Dan Thurman Messages: 55 Registered: July 2009 |
Member |
I have successfully used Tomcat before so I am not
a total noob, just a semi/advanced-noob, perhaps. ;)
Lately however, I have "all of a sudden" lost
my tomcat connectivity with Eclipse on a Fedora
Linux distro.
It seems, that all of my problems started after
I downloaded, installed, and ran Eclipse Galileo,
having previously used Ganemede SR2, which no longer
works nor does Galileo.
There are several problems that showed up, but
the most significant error that I ran into was
that the Tomcat server could not start since
it could not locate tomcat-juli.jar file.
The error reported is:
Exception in thread "main" java.lang.NoClassDefFoundError: org/apache/juli/
logging/LogFactory
at org.apache.catalina.startup.Bootstrap.<clinit>
(Bootstrap.java:54)
Caused by: java.lang.ClassNotFoundException:
org.apache.juli.logging.LogFactory
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336 )
... 1 more
So, at this point, I have looked into the Tomcat
Server Launch configuration (double-clicked the tomcat6
server in the Servers tab, then clicked in "Overview",
the link: "Open launch configuration",) and clicked the
Classpath tab, and noted the following entries:
Bootstrap Entries:
+ JRE System Libraries [java-1.6.0-openjdk-1.6.0.0]
User Entries:
+ bootstrap.jar - /usr/share/tomcat6/bin
+ tools.jar - /usr/lib/vm/java-1.6.0-openjdk-1.6.0.0/lib/
The above configuration used to work, but now it does not,
the Tomcat server fails to start. I guess, "something"
has changed...
Scratching my head, I added to the above list, under
the User Entries of Classpath:
+ commons-logging.jar - /usr/share/tomcat6/bin
+ tomcat-juli.jar - /usr/share/tomcat6/bin
The tomcat server now runs, however, the applications
will not run:
HTTP Status 404 - /WebDbTest/
type: Status report
message: /WebDbTest/
description: The requested resource (/WebDbTest/) is not available.
Since I am trying to resolve the tomcat issue,
I have as a test created a new dynamic web
application with a simple index.jsp file:
1) Created a new 'Dynamic Web Application': 'Hello'
2) Created a new index.jsp file under Webcontent->WEB-INF
and changed the title to "Hello World" and added
"Hello World" to the <body> and saved the changes.
3) Clicked "Run As", selected "Run on server"
and the server started, but the web-browser displayed
a HTTP 404 error, similarly as before but with 'Hello'
application.
Can anyone offer any suggestions what I can do to resolve
this issue?
Kind regards!
Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233241 is a reply to message #233233] |
Thu, 02 July 2009 15:20   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
> Linux distro.
> logging/LogFactory
> (Bootstrap.java:54)
> at java.security.AccessController.doPrivileged(Native Method)
> ... 1 more
> Bootstrap Entries:
> User Entries:
> has changed...
It looks like you have addressed the issue described in the 4th
paragraph (starts with "Another use case...") of:
http://wiki.eclipse.org/WTP_Tomcat_FAQ#What_does_it_mean_if_ WTP_says_my_server_.22failed_to_start.22.3F
This is not unusual for a packaged Linux install. Using a binary
download from Apache shouldn't have this problem.
> will not run:
> type: Status report
This may not indicate a problem. By default, current Tomcats return 404
for a URL ending with "/" when no welcome file is found since directory
listings are disabled by default for security reasons.
> application.
Did you really put the index.jsp in WEB-INF? The servlet spec forbids
servers to directly serve WEB-INF content to browsers. You have to
forward to such JSP pages to access them. The index.jsp will should
work as expected if placed in the WebContent folder.
Larry
> this issue?
> Kind regards!
> Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233264 is a reply to message #233241] |
Thu, 02 July 2009 23:01   |
Member |
On Thu, 02 Jul 2009 15:20:27 -0400, Larry Isaacs wrote:
> Dan Thurman wrote:
>> I have successfully used Tomcat before so I am not a total noob, just a
>> Lately however, I have "all of a sudden" lost my tomcat connectivity
>> with Eclipse on a Fedora Linux distro.
>> It seems, that all of my problems started after I downloaded,
>> installed, and ran Eclipse Galileo, having previously used Ganemede
>> SR2, which no longer works nor does Galileo.
>> There are several problems that showed up, but the most significant
>> error that I ran into was that the Tomcat server could not start since
>> ========================================== Exception in thread "main"
>> java.lang.NoClassDefFoundError: org/apache/juli/ logging/LogFactory
>> (Bootstrap.java:54)
>> at java.net.URLClassLoader$1.run(URLClassLoader.java:217) at
>> java.security.AccessController.doPrivileged(Native Method) at
>> java.net.URLClassLoader.findClass(URLClassLoader.java:205) at
>> java.lang.ClassLoader.loadClass(ClassLoader.java:323) at
>> sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 ) at
>> java.lang.ClassLoader.loadClass(ClassLoader.java:268) at
>> java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336 ) ... 1
>> more
>> So, at this point, I have looked into the Tomcat Server Launch
>> configuration (double-clicked the tomcat6 server in the Servers tab,
>> then clicked in "Overview", the link: "Open launch configuration",) and
>> clicked the Classpath tab, and noted the following entries:
>> ================================================== Bootstrap Entries:
>> User Entries:
>> + bootstrap.jar - /usr/share/tomcat6/bin + tools.jar -
>> The above configuration used to work, but now it does not, the Tomcat
>> server fails to start. I guess, "something" has changed...
WTP_Tomcat_FAQ#What_does_it_mean_if_WTP_says_my_server_.22fa iled_to_start.22.3F
So... are you saying that for Fedora, I have to add the two
missing jars in order to fix this problem? If so, why did it
work with Ganamede (i.e. I did not have to add the two "missing"
jars as it *seemed* to work before)? Well, in any case adding
the two missing jars seems to fix things for Fedora.
>> Scratching my head, I added to the above list, under the User Entries
>> of Classpath:
>> + commons-logging.jar - /usr/share/tomcat6/bin + tomcat-juli.jar -
>> The tomcat server now runs, however, the applications will not run:
>> type: Status report
Yup... because I put the index.jsp in the wrong place...
as you explained further down...
>> Since I am trying to resolve the tomcat issue, I have as a test created
>> a new dynamic web application with a simple index.jsp file:
>> 1) Created a new 'Dynamic Web Application': 'Hello' 2) Created a new
>> and changed the title to "Hello World" and added "Hello World" to
>> and the server started, but the web-browser displayed a HTTP 404
>> error, similarly as before but with 'Hello' application.
Yup! You are RIGHT! I am really blind, ahh! Moving the
application files to WebContent solved this problem!
Many thanks for responding and now I can proceed happily!
> Cheers,
> Larry
>> Can anyone offer any suggestions what I can do to resolve this issue?
>> Kind regards!
>> Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233289 is a reply to message #233233] |
Sat, 04 July 2009 13:06   |
Member |
> It seems, that all of my problems started after I downloaded, installed,
> and ran Eclipse Galileo, having previously used Ganemede SR2, which no
> (Bootstrap.java:54)
> more
> User Entries:
> Scratching my head, I added to the above list, under the User Entries of
> Classpath:
> type: Status report
> and changed the title to "Hello World" and added "Hello World" to the
> Kind regards!
> Dan
The above for Ganamede is resolved:
(1) Add two missing jar files to server classpath: commons-logging.jar
& tomcat-juli.jar
(2) Move the web-application under Webcontents, not WEB-INF
and it works.
However, the same project does not run in
Galileo. Seems that there is an invoker issue
in the application's web.xml file. Why does
the same application work in Ganamede but not
in Galileo since both are using tomcat6. Is
there something different in the way Galileo
works?
Please note, however, that tomcat6 server does
run in Galileo, but the application fails
to start/run due to a 404 - status error...
and I checked to ensure that the index.jsp
file is under the Webcontext directory as
I goofed earlier...
I wonder if under Galileo, we now have to add
invoker rules manually in order for the application
to run, i.e. it is not longer done automatically,
and if so, how does this differ under Ganamede?
Anyway, here are the errors:
SEVERE: End event threw exception
java.lang.reflect.InvocationTargetException
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.apache.tomcat.util.IntrospectionUtils.callMethodN
(IntrospectionUtils.java:953)
at org.apache.catalina.startup.CallMethodMultiRule.end
(WebRuleSet.java:789)
at org.apache.tomcat.util.digester.Rule.end(Rule.java:229)
at org.apache.tomcat.util.digester.Digester.endElement
(Digester.java:1140)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .endElement
(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanEndElement
(Unknown Source)
$FragmentContentDriver.next(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next
(Unknown Source)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument
(Unknown Source)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse
(Unknown Source)
(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse
(Unknown Source)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl
$JAXPSAXParser.parse(Unknown Source)
at org.apache.tomcat.util.digester.Digester.parse
(Digester.java:1644)
org.apache.catalina.startup.ContextConfig.processDefaultWebC onfig
(ContextConfig.java:687)
at org.apache.catalina.startup.ContextConfig.defaultWebConfig
(ContextConfig.java:624)
at org.apache.catalina.startup.ContextConfig.start
(ContextConfig.java:1065)
at org.apache.catalina.startup.ContextConfig.lifecycleEvent
(ContextConfig.java:261)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent
(LifecycleSupport.java:117)
at org.apache.catalina.core.StandardContext.start
(StandardContext.java:4252)
at org.apache.catalina.core.ContainerBase.start
(ContainerBase.java:1045)
at org.apache.catalina.core.StandardHost.start
(StandardHost.java:719)
at org.apache.catalina.core.StandardEngine.start
(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start
(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start
(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:578 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:41 3)
Caused by: java.lang.IllegalArgumentException: Servlet mapping specifies
an unknown servlet name invoker
at org.apache.catalina.core.StandardContext.addServletMapping
(StandardContext.java:2393)
(StandardContext.java:2373)
... 38 more
Jul 4, 2009 8:44:23 AM org.apache.catalina.startup.ContextConfig
processDefaultWebConfig
SEVERE: Parse error in default web.xml
java.lang.IllegalArgumentException: Servlet mapping specifies an unknown
at org.apache.tomcat.util.digester.Digester.createSAXException
(Digester.java:2808)
(Digester.java:2834)
(Digester.java:1143)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
SEVERE: Occurred at line 365 column 23
Jul 4, 2009 8:44:23 AM org.apache.catalina.startup.ContextConfig start
SEVERE: Marking this application unavailable due to previous error(s)
Jul 4, 2009 8:44:23 AM org.apache.catalina.core.StandardContext start
SEVERE: Error getConfigured
SEVERE: Context [] startup failed due to previous errors
Jul 4, 2009 8:44:24 AM org.apache.tomcat.util.digester.Digester endElement
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
... 38 more
Jul 4, 2009 8:44:24 AM org.apache.catalina.startup.ContextConfig
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
Jul 4, 2009 8:44:24 AM org.apache.catalina.startup.ContextConfig start
Jul 4, 2009 8:44:24 AM org.apache.catalina.core.StandardContext start
SEVERE: Context [/WebDbSearch1] startup failed due to previous errors
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
... 38 more
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
(Unknown Source)
Source)
SEVERE: Context [/WebDb1] startup failed due to previous errors
Jul 4, 2009 8:44:24 AM org.apache.coyote.http11.Http11AprProtocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Jul 4, 2009 8:44:24 AM org.apache.coyote.ajp.AjpAprProtocol start
INFO: Starting Coyote AJP/1.3 on ajp-8009
Jul 4, 2009 8:44:24 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 1064 ms
| Re: Ganamede, Galileo, and Tomcat 6 [message #233299 is a reply to message #233289] |
Sat, 04 July 2009 14:30   |
Member |
>> (Bootstrap.java:54)
>> more
>> User Entries:
>> of Classpath:
>> type: Status report
>> Kind regards!
>> Dan
> & tomcat-juli.jar
> and it works.
> However, the same project does not run in Galileo. Seems that there is
> an invoker issue in the application's web.xml file. Why does the same
> application work in Ganamede but not in Galileo since both are using
> tomcat6. Is there something different in the way Galileo works?
> Please note, however, that tomcat6 server does run in Galileo, but the
> application fails to start/run due to a 404 - status error... and I
> checked to ensure that the index.jsp file is under the Webcontext
> directory as I goofed earlier...
> I wonder if under Galileo, we now have to add invoker rules manually in
> order for the application to run, i.e. it is not longer done
> automatically, and if so, how does this differ under Ganamede?
> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
> at java.lang.reflect.Method.invoke(Method.java:616) at
> at org.apache.tomcat.util.digester.Rule.end(Rule.java:229) at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> at org.apache.catalina.startup.Catalina.start(Catalina.java:578 ) at
> org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 88) at
> ... 38 more
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> SEVERE: Occurred at line 365 column 23 Jul 4, 2009 8:44:23 AM
> SEVERE: Context [] startup failed due to previous errors Jul 4, 2009
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> ... 38 more
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> SEVERE: Occurred at line 365 column 23 Jul 4, 2009 8:44:24 AM
> endElement
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> ... 38 more
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> at
> (Unknown Source)
> (Unknown Source)
> at
(Unknown
> Source)
> at
> SEVERE: Context [/WebDb1] startup failed due to previous errors Jul 4,
> INFO: Starting Coyote HTTP/1.1 on http-8080 Jul 4, 2009 8:44:24 AM
> org.apache.coyote.ajp.AjpAprProtocol start INFO: Starting Coyote AJP/1.3
> on ajp-8009 Jul 4, 2009 8:44:24 AM org.apache.catalina.startup.Catalina
> start
I have resolved all, but two issues:
1) Galileo no longer prompts me for my workspace
location when starting Eclipse, so how do I get
this back?
2) Galileo recognized in server.xml, the required
authentication code but Ganamede somehow ignores
this requirement and immediately goes into anonymous
authentication (no prompts).
I had a problem getting the application to run for both
Ganemede & Galileo:
Initially I had the following code:
<%@ page
import = "java.io.*"
import = "java.lang.*"
import = "java.sql.*"
<%@ taglib uri="http://java.sun.com/jsp/jstl/core" prefix="c"%>
<%@ taglib uri="http://java.sun.com/jsp/jstl/sql" prefix="s"%>
Ganemede was happy with this, but Galileo was complaining
of unresolved tablib uri paths for both of the above tablibs.
So, to fix this for Galileo, I had to add:
import = "java.util.*"
and both tablibs were resolved for Gamamede & Galileo
FWIW,
Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233317 is a reply to message #233299] |
Mon, 06 July 2009 10:10   |
<snip>
</snip>
> this back?
Window -> Preferences -> General -> Startup and Shutdown.
I'm not sure exactly what "Galileo recognized in server.xml" means.
It's not clear exactly how your Galileo and Ganymede environments are
set up. Since I don't have a system that can duplicate your setup I can
only guess what might be wrong.
Can we assume you are running Galileo and Ganymede on separate workspaces?
Larry
P.S. You may want to download a binary version of Tomcat from the Apache
site and use that. Packaged versions of Tomcat are notorious for having
various usage issues due to choices the package designers made.
> Ganemede & Galileo:
> <%@ page
> FWIW,
> Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233333 is a reply to message #233317] |
Mon, 06 July 2009 14:45   |
Member |
On Mon, 06 Jul 2009 10:10:20 -0400, Larry Isaacs wrote:
> <snip>
> </snip>
>> location when starting Eclipse, so how do I get this back?
Ganymede works fine.
Galileo seems stuck and I cannot unstuck it. I tried
removing all workspaces in the list, and it seems stuck
at the last workspace setting of which I am forced to use
a two-step method to change it to something other via
the File->Switch Workspace menu.
>> authentication code but Ganymede somehow ignores this requirement
>> and immediately goes into anonymous authentication (no prompts).
What I am saying here is that tomcat6->conf->server.xml can be
configured for controlling authentication and what was odd is
that Ganymede ignored the required authentication code which
resulted in anonymous access, and yet, Galileo did not ignore
the authentication code and prompted for a username/password
to grant access the application.
> are set up. Since I don't have a system that can duplicate your
> setup I can only guess what might be wrong.
> workspaces?
Yes, of course, otherwise "collisions" & permissions problems
can result.
> Cheers,
> Larry
Yes, I did that. I have three versions:
(1) Fedora tomcat-6 RPM installed
(2) Netbeans tomcat-6 installed
(3) Apache tomcat-6 installed.
All three seems to work well so far.
>> run for both Ganymede & Galileo:
>> <%@ page
>> Ganymede was happy with this, but Galileo was complaining of unresolved
>> and both tablibs were resolved for Ganymede & Galileo
>> FWIW,
>> Dan
| Re: Ganamede, Galileo, and Tomcat 6 [message #233369 is a reply to message #233333] |
Tue, 07 July 2009 09:43  |
>> <snip>
>> </snip>
The WTP Tomcat support only uses tomcat6->conf->server.xml when it
creates the server. After that its the copy of server.xml under the
Servers project in your workspace that gets used. If it helps, see the
WTP Tomcat FAQ for details about how the WTP Tomcat support works:
http://wiki.eclipse.org/WTP_Tomcat_FAQ.
Also, in case you are using the internal browser in Eclipse, be aware
that once the internal browser is displayed, it is never closed.
"Closing" the internal browser window only hides the window and doesn't
actually close it. This implies that if you are using basic
authentication, once authenticated, the browser will remember those
credentials for the remainder of the Eclipse session. There isn't
enough detail to determine if this could explain the odd behavior with
authentication, but it might.
Larry
>> workspaces?
> can result.
>> Cheers,
>> Larry
>>> <%@ page
>>> FWIW,
>>> Dan
Current Time: Sun May 19 19:32:34 EDT 2013
Powered by FUDForum. Page generated in 0.02329 seconds
