| galileo: network connections proxy setup not working [message #232990] |
Thu, 25 June 2009 20:57  |
tony kerz Messages: 21 Registered: July 2009 |
Junior Member |
trying to use galileo behind corporate firewall, so i go into:
window->preferences->network connections
enter: proxy, port, user and password
for http, https and socks
then i go into:
install/update->available software sites
and i click on an update site, say, "spring ide" for example,
and click "test connection" and it just hangs...
but the analogous actions in ganymede works like a champ
with the same proxy/port/user/password quadruple.
what am i missing...?
| Re: galileo: network connections proxy setup not working [message #232998 is a reply to message #232990] |
Fri, 26 June 2009 10:43   |
I'm not sure its exactly the same issue (I didn't see "hang" mentioned) but
similar issues are being discussed in bug 281472
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281472
with some workarounds mentioned there.
And, just FYI, I think we in WTP got out of the "network connections"
are a few releases ago (trying to have single, common function), so
you'd probably
get better response from the eclipse.platform newsgroup (if that bug
doesn't help).
Good luck.
FUDForum. Page generated in 0.01799 seconds
