Home » Language IDEs » Java Development Tools (JDT) » How can I do "javac -source 1.5 -target 1.1" in Eclipse 3.2 JDT?
How can I do "javac -source 1.5 -target 1.1" in Eclipse 3.2 JDT? [message #232911] Tue, 18 July 2006 20:47 Go to next message
Eclipse User
Originally posted by: benh.ibsglobalweb.com
Hi all,
As I understand it, the new Java 1.5 extensions can be compiled to run
on older VMs, using a compile command like "javac -source 1.5 -target 1.1".
However, its not clear how/if I can acheive the same thing using the JDT
compiler. When I tried, I received a message telling me my classfile
level must be equal or greater than source level.
This would this seem defeat the whole purpose of ensuring the Java 5.0
language changes were backwards-compatible at the classfile level, or
did I misunderstand it?
Ben Hutchison
Re: How can I do "javac -source 1.5 -target 1.1" in Eclipse 3.2 JDT? [message #232919 is a reply to message #232911] Tue, 18 July 2006 22:07 Go to previous message
Olivier Thomann is currently offline Olivier Thomann
Ben Hutchison a écrit :
> Hi all,
> 1.1".
This should not work even with javac. The best you can do is to use the
jsr14 target with javac. But this doesn't handle all the 1.5 constructs
and you only get a 1.4 target.
This is on purpose.
Why would you want to get backwarks-compatibility? This has never been
part of the contract even for 1.4 .class files.
The .class files are upwards-compatible.
Hope this clarify it.
Olivier
Previous Topic:Re: Specific Q about extension schema
Next Topic:Javadoc Tooltip and Javadoc View are blank?
Current Time: Sat May 25 23:17:25 EDT 2013
Powered by FUDForum. Page generated in 0.01575 seconds
