| Publishing failed/Resource is out of sync [message #232390] |
Thu, 11 June 2009 11:12  |
Kevin A. Roll Messages: 5 Registered: July 2009 |
Junior Member |
I'm having a recurring problem when generating a web service. The process
fails with the error message
Publishing failed with multiple errors
Resource is out of sync with the file system:
'/com.verani.web.backPage/web/WEB-INF/lib/axis.jar'.
'/com.verani.web.backPage/web/WEB-INF/lib/jaxrpc.jar'.
I understand this to mean that Eclipse's cache is out of sync with those
resources, which normally calls for a refresh. However, Eclipse itself is
the one that copied those jars over as part of the web service creation,
and there's no way to force a refresh in the middle of the process. Also,
I don't particularly want those jars copied anyway as I can add them to my
resources project. Can somebody point me in the right direction? Thanks!
| Re: Publishing failed/Resource is out of sync [message #232417 is a reply to message #232390] |
Fri, 12 June 2009 03:24   |
Originally posted by: mauro.molinari.cardinis.com
> process fails with the error message
> is the one that copied those jars over as part of the web service
> creation, and there's no way to force a refresh in the middle of the
> process. Also, I don't particularly want those jars copied anyway as I
> can add them to my resources project. Can somebody point me in the right
> direction? Thanks!
I don't know if I understood your problem correctly, however try to
press F5 (or Right-click=>Refresh) on
/com.verani.web.backPage/web/WEB-INF/lib/ to issue a refresh from the
file system.
Mauro.
| Re: Publishing failed/Resource is out of sync [message #232440 is a reply to message #232424] |
Fri, 12 June 2009 09:26   |
> That's exactly the problem - there is no way to issue a refresh. When I
> press 'Finish' on the web service dialog, Eclipse chugs away,
> automatically generating the files for the web service. As part of this
> process it wants to copy some jar files into WEB-INF\lib, and it then
> immediately complains that the resources are out of sync while the
> wizard is still running. There's no way I can tell it to refresh while
> the wizard is still going, and I don't even want those jars copied in
> the first place because I can set up that dependency myself.
Now I understand it better. Unfortunately, I can't be of much help,
because, when I was working with web services, I preferred the use of a
fine tuned Ant script to perform the operations I needed.
Mauro.
| Re: Publishing failed/Resource is out of sync [message #232557 is a reply to message #232424] |
Mon, 15 June 2009 16:22  |
Nitin Dahyabhai Messages: 1847 Registered: July 2009 |
That definitely sounds like a bug. It should be using the workspace
APIs to write those files whenever possible.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
FUDForum. Page generated in 0.02472 seconds
