Home » Eclipse Projects » Web Tools Project (WTP) » Validate a project facet
Validate a project facet [message #232478] Mon, 15 June 2009 09:26 Go to next message
Steve is currently offline Steve
I have a FacetedProject. Is there an API to determine if another facet
can be installed into this FacetedProject? I've looked through the
methods in ProjectFacetsManager and IProjectFacetVersion (isValidFor and
conflictsWith), but they don't appear to be what I am looking for. I
thought it might be a method in FacetedProject, but I couldn't find it
there either. For example, let's say I have an EJB project. I want to
know if I can install the Web facet into this project. I don't want to
install it at this time, I just want to know if this new facet is valid
for an existing faceted project.
Steve
Re: Validate a project facet [message #232512 is a reply to message #232478] Mon, 15 June 2009 12:36 Go to previous messageGo to next message
Konstantin Komissarchik is currently offline Konstantin Komissarchik
Yes, there is definitely a way to do this. The best approach is to get a
working copy from your IFacetedProject, add the facet in question to it
and then validate the working copy. Like this:
IFacetedProject fpj = ...
IFacetedProjectWorkingCopy fpjwc = fpj.createWorkingCopy();
try
fpjwc.addProjectFacet( ... );
IStatus result = fpjwc.validate();
finally
fpjwc.dispose();
You can use this technique to try out any type of change to the project.
Operations you perform on the working copy are not persisted unless you
call fpjwc.commitChanges().
- Konstantin
Re: Validate a project facet [message #232528 is a reply to message #232512] Mon, 15 June 2009 13:14 Go to previous message
> try
> finally
> fpjwc.dispose();
> - Konstantin
Konstantin,
Thank you very much. This is exactly what I was looking for.
Steve
Previous Topic:Custom Facet Installation fails when no InstallDelegate class is created
Next Topic:Tomcat server timeout
Current Time: Wed May 22 08:02:15 EDT 2013
Powered by FUDForum. Page generated in 0.02120 seconds
