Home » Eclipse Projects » Web Tools Project (WTP) » WSDLValidator is internal
WSDLValidator is internal [message #232170] Thu, 04 June 2009 15:43 Go to next message
Ravikanth Somayaji is currently offline Ravikanth Somayaji
Member
Hello there,
I need to use the WSDLValidator, and have a test case that runs fine using
it. However, the org.eclipse.wst.wsdl.validation.internal.WSDLValidator is
internal, and I'm warned against discouraged access. Is there a better way
of invoking the WSDLValidator. Suggestions would be appreciated.
Thanks, Ravi
Re: WSDLValidator is internal [message #232271 is a reply to message #232170] Wed, 10 June 2009 06:11 Go to previous message
Member
Discovered that the
org.eclipse.wst.validation.ValidationFramework.validate can be used
instead.
Previous Topic:js library file - what is the format?
Next Topic:Servers and debugging javascript
Current Time: Mon May 20 08:22:39 EDT 2013
Powered by FUDForum. Page generated in 0.02176 seconds
